Any experience with Utility Meter functions?
I’m really sorry, I’m a noob.
I did take a copy from yours configuration:
- platform: rest
  name: Shelly EM Wifi
  resource: http://10.1.1.24/status
  username: !secret shelly_usr
  password: !secret shelly_pwd
  authentication: basic
  value_template: '{{ value_json.wifi_sta.rssi }}'
  scan_interval: 180
  unit_of_measurement: dB
- platform: rest
  name: Shelly T31 Total Energy # lights and power
  value_template: '{{ (value_json.emeters.0.total | float /1000)|round(3) }}' # Wh to kWh
  scan_interval: 300 # no point updating faster than this. The Shelly only updates every 5 minutes
  unit_of_measurement: kWh
- platform: rest
  name: Shelly T41 Total Energy # heating and hot water
  value_template: '{{ (value_json.emeters.1.total | float /1000)|round(3) }}'
  scan_interval: 300
- platform: mqtt
  name: "Tariff 31 Power"
  state_topic: "shellies/shellyem-B9E940/emeter/0/power"
  value_template: '{{ value|round(1) }}'
  qos: 1
  unit_of_measurement: "W"
  icon: mdi:gauge
- platform: mqtt
  name: "Tariff 41 Power"
  state_topic: "shellies/shellyem-B9E940/emeter/1/power"
  qos: 1
  icon: mdi:gauge
On the entities I can find only the shelly’s sensor of power, voltage and reactive power but not energy
The following are your energy sensors:
sensor.shelly_casa
sensor.shelly_pdc
Hi there - I’m brand new to HA. What are you using to produce those graphs and stats in those two views you’ve attached there? Looks awesome.
The graphs can now be made with sensor cards, and ask it to do a line.
There is also a custom bar-card available.
Get the HACS installed, that will help you wth the custom cards.
Thank’s a lot @tom_l
your explanations are very detailed and I understood a lot with your examples.
Could you gave more information about the cards you’ve used for Energy use and the graphs with colors & night / day?
Regards
https://community.home-assistant.io/t/daily-energy-monitoring/143436/17?u=tom_l
and
https://community.home-assistant.io/t/daily-energy-monitoring/143436?u=tom_l
Thanks @tom_l
BTW I’ve just received my Shelly EM so I can compare from the values on the official meter :slight_smile:
@fribse sorry for jumping into this old conversation. I’m trying to setup something like you were doing here, work out the kWh of multiple sensors that report real-time power consumption. My end goal is to track cost of the individual items.
I’ve got to the same point as you are here and I’m also getting W not kWh.
I’m tracking hourly, daily, weekly and monthly usage through utility meter for the individual sensors. What’s strange is the hourly, daily and monthly totals are showing W but weekly is correctly showing kWh.
Did you find out what was causing you to also get W reported?
I’ve actually put it aside for now, I have to redo it when I get the time (yeah one should think there were a lot of time at the moment, but noooo), but I get the daily summations from ESPHome. I would also like to push all the info to influxdb and grafana, but that’s next step after that.
I did the integration sensors like this (integration over time):
  - platform: integration
    source: sensor.pool_power
    unit_time: h
That gives the Wh or kWh.
Guess this is an Old topic but here is an update nonetheless.
I setup 3 x PZEM 004T for a 3 phase supply last week.
While the device reports instant power and accumulated usage, the latter is prone to issues as the value resets after even short power outages (which unfortunately i get plenty of)
The solution (s) i am currently testing uses:
A)
  • Use the Instant power (Watts) to populate sensors in HA
  • Use the Riemann sum integration sensor in HA to calculate the power (kWH) usage for 3 X kWH sensors
  • Use the utility meter component in HA to compute daily and monthly usage
B)
Once this was done, I setup influx and grafana for the graphing
C) I also setup a local openenergymonitor (OEM) server to test it as an alternate to B)
HA has a component called open emoncms_history that allows you to send sensor feeds to it
OEM also allows you to transform power (W) readings into accumulated kWH
I think I wil do away with B) entirely as C) seems better suited for the typical logging use cases for HA (power/ temperature etc)
Hi
Would love to have more info about you C setup. I presently have my data being stored in Infuxdb but haven figured out how to use Grafana at all. Am using the utility meter component to convert W into kWh. Seems to be working. Calculatons match bill.
Look forward to trying emoncrm. Where did you download the local server.
the local server details are on github
My setup details :
what are the sensor cards in your lovelace screenshot?
https://github.com/superczar/home-assistant/blob/15d773d82b9dfd53c8e38d4ce0637ea70cd191f8/images/sensor1.jpg
Temperature sensors drawn with grafana.
Having said that, shifting away from grafana towards emoncms…
Less pretty graphs but far more easy to use!
Is it possible to bulk load old data to utility meter?
I fear it´s a “from now on, start with zero” thing, but who knows… :wink:
Background:
Integrated utility meter months after starting with HA and due to some plug trouble (Shelly erasing their memory on firmware updates - how stupid is that…) I lost all my total consumption values since the beginning.
No. There is no way to do that.
That´s what I expected.
What do you guys do with single measurements?
Do you sum single measurements up to rooms or the whole house?
Currently I use it for single power plugs only. No aggregation at the moment. Curious to see what´s possible with all that numbers provided by this great utility meter. Wish I had integrated it right from the beginning (start with HA).
I’ve set up an aggregation sensor (thanks to @tom_l I got it working :slight_smile: )
total_daily_power:
      friendly_name: Samlet forbrug for i dag
      value_template: >
        {{ expand('group.daily_power_usage')
        | rejectattr('entity_id', 'eq', 'sensor.power')
        | map(attribute='state')
        | map('float') | sum | round(3) }}
      device_class: power
That sums up the daily power. Just before midnight I store it in an input variable, so I can show ‘yesterdays’ powerusage.
