the most complete database for esp based devices I know is templates.blakadder.com. You might want to seek your devices there (they also have a non-compatible category) but with the term " TAOCOCO" they don’t have any results (but might be just one of the many white label names for one and the same product).
But by the looks of the amazon reviews it’s also from 2020… good chances that a esp works inside
When it works it normally works great - but be ready for some experimenting
Flashing with serial is easy.
You have five pins.
3.3
gnd
tx
rx
GPIO 0 (can be labled IO0 on boards)
Connect 3.3 v and GND to the 3.3 v and GND on the serial adapter.
Connect TX to RX, and RX to TX (receive needs to talk to transmit).
Lastly hold GPIO 0 on GND while you plug in the serial adapter in the computer.
That is pretty much it. Now you can just flash a ESP yaml to it.
It’s not the same device but the same principle applies, and I find this a good video explaining how to connect and do all stuff on a device that is not “meant” to be flashed.
I couldn’t find a good related video just now.
My guess is that the front is squeezed on and it has been heated up to “melt” it together.
As long as you can glue it back together then all means is allowed to remove tuya firmware.
The bad thing if the plugs are not designed to be opened they really can break and you might/probably not be able to get them back together in good/solid manner. So might be worth to give tuya convert a try (if you have time ) before prying it open in a destructive way
Really? I’m a flash-a-holic (with iron) but never use that for flashing. Some times a helping hand (or two) comes in handy. Most of the time I just use male dupont wires and hold them on the right pads and try to keep them in place for the 20 seconds while flashing - that’s it.
Sometimes the connections does not even have holes, they might just be flush solder points, and sometimes you need to hold them on the actual ESP, and in those cases I usually put a little tin on the male headers and solder them on the boards.
It just takes a few seconds.
