Actually I’ve just found this fork which seems to fix some of the changes introduced on the climate integration:
I’ve not yet been able to check if it works, will let you know as soon as I test it.
that’s my fork
It’s updated for the climate-1.0 changes in hass 0.96.
I seem to have a stable workaround for the login/session timeout issue, you can even use the app or another instance of homeassistant and it will recover.
I had to stop it from asking the state of the device as every time that call happened it would turn on my AC and set it to fan only. Not sure how to solve that as of yet.
As a workaround I am restoring state from home-assistant, so if you restart hass, the device should keep its state. If you only change the state from home-assistant, everything should be good.
Will probably package it up into HACS when I get some more time.
This fan only issue is what I had to workaround.
I guess it didn’t happen for every AC unit with this library though?
Could add an option to query status or restore it I guess, if there’s demand for that?
Hey there,
I’ve managed to install the component, it finds the device from cloud but with some default values (i.e. Fan, Off, 17C). If I try to change anything, it comes back to default value. In the log it shows that response was never received.
Any ideas, how I could improve situation?
Thanks,
G.
I’ve been trying to install Midea for a few days following instructions on https://github.com/andersonshatch/midea-ac-py.
Unfortunately, without success.
I am getting the following error:
2019-07-30 16:49:10 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py”, line 365, in _async_add_entity
await entity.async_update_ha_state()
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 226, in async_update_ha_state
self._async_write_ha_state()
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 249, in _async_write_ha_state
state = self.state
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/climate/ init .py”, line 155, in state
return self.hvac_mode
File “/home/homeassistant/.homeassistant/custom_components/climate/climate.py”, line 207, in hvac_mode
self._device.operational_mode = ac.operational_mode_enum[self._old_state.state]
File “/usr/local/lib/python3.7/enum.py”, line 349, in getitem
return cls. member_map [name]
KeyError: ‘off’
When I checking the configuration everything is ok
homeassistant@hassbian:/home/pi $ hass --script check_config
I will just add that Midea installed from this site (https://pypi.org/project/midea/) works very well.
Thanks for the help
I’ve got the same error. No clue either.
Everything looks fine, but I can’t see on/off button! It is a thermostat card. What is the problem?
I solved it (with a facebook community help, thx to Laszlo!)
My Hassio version is 0.95.4
I need to use this version of midea ac:
A climate platform that adds support for Midea air conditioning units.
For more details about this platform, please refer to the documentation
https://github.com/NeoAcheron/midea-ac-py
This is still early work in progress
import logging
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.components.climate import ClimateDevice, PLATFORM_SCHEMA
from homeassistant.components.climate.const import (
SUPPORT_TARGET_TEMPERATURE, SUPPORT_TARGET_TEMPERATURE_HIGH, SUPPORT_TARGET_TEMPERATURE_LOW,
SUPPORT_AWAY_MODE, SUPPORT_FAN_MODE, SUPPORT_OPERATION_MODE, SUPPORT_SWING_MODE,
SUPPORT_ON_OFF)
from homeassistant.const import CONF_USERNAME, CONF_PASSWORD, TEMP_CELSIUS, TEMP_FAHRENHEIT, ATTR_TEMPERATURE
from homeassistant.util import Throttle
from datetime import timedelta
REQUIREMENTS = [‘midea==0.1.7’, ‘pycryptodome==3.7.0’]
VERSION = ‘0.1.7’
The idea of packaging this for HACS makes me very happy!
WOW! You’ve already added it to HACS!
I’ve installed and have it communicating!
Yep, it’s in the HACS store now
Few fixes added for restore state bugs.
Working very nicely with air conditioner from HTW that also uses midea cloud. Installed and configured through HACS, really, thanks a lot, years without being able to control my AC through home assistant.
Hey Josh,
Even with latest version from HACS, it’s not working. Changing any parameter of entity, agfter few moments goes back to default. And log shows this:
File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 210, in handle_service
self._platforms.values(), func, call, service_name, required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 334, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 356, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/config/custom_components/midea/climate.py", line 270, in async_set_hvac_mode
await self.apply_changes()
File "/config/custom_components/midea/climate.py", line 97, in apply_changes
await self.hass.async_add_executor_job(self._device.apply)
File "/usr/local/lib/python3.7/site-packages/midea/device.py", line 168, in apply
data = self._cloud_service.appliance_transparent_send(self.id, data)
File "/usr/local/lib/python3.7/site-packages/midea/cloud.py", line 173, in appliance_transparent_send
'applianceId': id
File "/usr/local/lib/python3.7/site-packages/midea/cloud.py", line 93, in api_request
return self.api_request(endpoint, args)
File "/usr/local/lib/python3.7/site-packages/midea/cloud.py", line 95, in api_request
raise RecursionError()
RecursionError
Any ideas what could be the issue and how I could help you to help me?
Cheers,
Giedrius
This is fantastic. I love that it works with HACS. I now have both my Danby Air Conditioners (portable and window mount) working with this without any problems. The Danby ACs are just basically Midea rebranded for Canada I suppose. Couldn’t be happier with this fork
Hmm… do state updates work even? Like if you use the remote and wait >60 seconds, does HASS reflect that?
Probably best to move to a github issue with your full log file
Thank you! This latest version is working reliably for me.
My only small issue is that when I restart HASS I get a large spike in the temperatures. This changes the scaling of the graph making it less readable.
For others wanting to use it with Hass.io, I needed to install the Custom deps deployment
addon with the following configuration:
"pypi": [
"midea-andersonshatch",
"pycryptodome"
"apk": []
Nope. It just shows this:
I even tried rpress’ method of downloading dependencies for Hass.io, the same:
Update for climate.midea_18691697713435 fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 249, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 417, in async_device_update
await self.async_update()
File "/config/custom_components/midea/climate.py", line 110, in async_update
await self.hass.async_add_executor_job(self._device.refresh)
File "/usr/local/lib/python3.7/site-packages/midea/device.py", line 146, in refresh
'applianceId': id
RecursionError
I’m using app_key from original repository, should I use something else?
Strange… if your credentials were wrong you would not even get a device in the first place so I don’t think those are at fault.
Can you turn on debug for the Midea component, so the response codes are logged too? Config yaml for that is like this:
logger:
default: info
logs:
midea: debug
Here you go…
2019-08-15 17:17:19 DEBUG (MainThread) [midea.cloud] Restarting session: '3004' - 'value is illegal.'
2019-08-15 17:17:20 DEBUG (MainThread) [midea.cloud] Retrying API call: 'homegroup/list/get'
2019-08-15 17:17:20 DEBUG (MainThread) [midea.cloud] Device list: [{'des': '', 'activeStatus': '1', 'onlineStatus': '1', 'name': 'kondicionierius', 'modelNumber': '8', 'id': '18691697713435', 'sn': '998be09af5bf4908f64518aa4c2f8e95485614d9be0eca3a9ff103bcce618595bb0284b010c2b0528159aredacted', 'type': '0xAC'}]
2019-08-15 17:18:22 DEBUG (SyncWorker_2) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac00000000000302408100ff03ff00300000000000000000000003bb8100000000000000000000000000000000
2019-08-15 17:18:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.midea_18691697713435 is taking over 10 seconds
2019-08-15 17:18:32 DEBUG (SyncWorker_2) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:18:32 DEBUG (SyncWorker_2) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:18:42 DEBUG (SyncWorker_2) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:18:42 DEBUG (SyncWorker_2) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:18:53 DEBUG (SyncWorker_2) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:18:53 DEBUG (SyncWorker_2) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:18:53 ERROR (MainThread) [homeassistant.helpers.entity] Update for climate.midea_18691697713435 fails
File "/config/custom_components/midea/climate.py", line 111, in async_update
File "/config/deps/lib/python3.7/site-packages/midea/device.py", line 146, in refresh
File "/config/deps/lib/python3.7/site-packages/midea/cloud.py", line 173, in appliance_transparent_send
'applianceId': id
File "/config/deps/lib/python3.7/site-packages/midea/cloud.py", line 93, in api_request
File "/config/deps/lib/python3.7/site-packages/midea/cloud.py", line 95, in api_request
RecursionError
2019-08-15 17:19:00 DEBUG (SyncWorker_27) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac000000000003024081b16603ff00300000000000000000000003bb6900000000000000000000000000000000
2019-08-15 17:19:10 DEBUG (SyncWorker_27) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:19:10 DEBUG (SyncWorker_27) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:19:10 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/config/custom_components/midea/climate.py", line 266, in async_set_hvac_mode
File "/config/custom_components/midea/climate.py", line 98, in apply_changes
File "/config/deps/lib/python3.7/site-packages/midea/device.py", line 168, in apply
'applianceId': id
RecursionError
2019-08-15 17:19:23 DEBUG (SyncWorker_1) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac000000000003024081b16603ff00300000000000000000000003bb6900000000000000000000000000000000
2019-08-15 17:19:25 DEBUG (SyncWorker_21) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac000000000003024081b76603ff00300000000000000000000003bb6300000000000000000000000000000000
2019-08-15 17:19:27 DEBUG (SyncWorker_39) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac000000000003024081576603ff00300000000000000000000003bbc300000000000000000000000000000000
2019-08-15 17:19:33 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.midea_18691697713435 is taking over 10 seconds
2019-08-15 17:19:33 DEBUG (SyncWorker_1) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:19:33 DEBUG (SyncWorker_1) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:19:33 ERROR (MainThread) [homeassistant.helpers.entity] Update for climate.midea_18691697713435 fails
File "/config/custom_components/midea/climate.py", line 107, in async_update
'applianceId': id
RecursionError
2019-08-15 17:19:34 DEBUG (SyncWorker_28) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac000000000003024081576603ff003f0000000000000000000003a0cf00000000000000000000000000000000
2019-08-15 17:19:43 DEBUG (SyncWorker_21) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:19:43 DEBUG (SyncWorker_21) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:19:43 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 358, in _handle_service_platform_call
await func(entity, data)
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 530, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File "/config/custom_components/midea/climate.py", line 240, in async_set_temperature
'applianceId': id
RecursionError
2019-08-15 17:19:53 DEBUG (SyncWorker_39) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:19:53 DEBUG (SyncWorker_39) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:19:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
'applianceId': id
RecursionError
2019-08-15 17:20:04 DEBUG (SyncWorker_28) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:20:04 DEBUG (SyncWorker_28) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:20:04 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/config/custom_components/midea/climate.py", line 247, in async_set_swing_mode
'applianceId': id
RecursionError
2019-08-15 17:20:24 DEBUG (SyncWorker_11) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac000000000003024081576603ff003f0000000000000000000003a0cf00000000000000000000000000000000
2019-08-15 17:20:34 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.midea_18691697713435 is taking over 10 seconds
2019-08-15 17:20:34 DEBUG (SyncWorker_11) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:20:34 DEBUG (SyncWorker_11) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:20:34 ERROR (MainThread) [homeassistant.helpers.entity] Update for climate.midea_18691697713435 fails
'applianceId': id
RecursionError
2019-08-15 17:21:25 DEBUG (SyncWorker_13) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac000000000003024081576603ff003f0000000000000000000003a0cf00000000000000000000000000000000
2019-08-15 17:21:35 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.midea_18691697713435 is taking over 10 seconds
2019-08-15 17:21:35 DEBUG (SyncWorker_13) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:21:35 DEBUG (SyncWorker_13) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:21:35 ERROR (MainThread) [homeassistant.helpers.entity] Update for climate.midea_18691697713435 fails
'applianceId': id
RecursionError
2019-08-15 17:22:25 DEBUG (SyncWorker_31) [midea.cloud] Sending to 18691697713435: 5a5a01115700200000000000000000000e031214c679000000050a00000000000000000002000000aa1eac000000000003024081576603ff003f0000000000000000000003a0cf00000000000000000000000000000000
2019-08-15 17:22:35 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.midea_18691697713435 is taking over 10 seconds
2019-08-15 17:22:35 DEBUG (SyncWorker_31) [midea.cloud] Error ignored: '3176' - 'The asyn reply does not exist '
2019-08-15 17:22:35 DEBUG (SyncWorker_31) [midea.cloud] Retrying API call: 'appliance/transparent/send'
2019-08-15 17:22:35 ERROR (MainThread) [homeassistant.helpers.entity] Update for climate.midea_18691697713435 fails
'applianceId': id
RecursionError
I also occasionally see that same error, but I have not had any actual problems with it.
