Any way to get the new T-Display-S3 AMOLED to work with ESPHome?
@clydebarrow, Hi the display was working good with the external components that you wrote, but when I went to update the display with the new release the yaml file will not validate. I replaced the spi section to match the new documentation.
spi:
  clk_pin: 47
  data_pins:
    - 18
    - 7
    - 48
    - 5
It appears the new documentation for the T3 Amoled should be the same as the T4 display, which compiles.
spi:
  type: quad
  clk_pin: 47
  data_pins: [18, 7, 48, 5]
Great work by the way, Thanks
I just got a T-Display-S3 unit. The pre-flashed code worked when I plugged the device in, so I know the hardware and display works.
Following the guide above no longer seems to work.
Would anyone be so kind as to upload a complete yaml file somewhere that works with the latest versions of everything?
Would LOVE to get this device working.
In the logs I can see the following warning emitted every second:
Component display took a long time for an operation (295 ms).
I have uploaded my sample code here, including the full log file:
The display that you show on github (from Amazon) is not an Amoled display. The Amoled display has the buttons on the sides.
Not at the bottom front.
The code I listed is still working on the display I have with the change made to the spi shown above your post.
For the non-AMOLED T-Display S3 see this PR:
Anyone have luck with the T-display s3 long? I found this: buglloc/esphome-components: A collection of my ESPHome components (github.com)
