I’ve had confirmation from @pkozul that the new “choice” functionality works in the latest release, so those of you that want to use alternative servers can now do so. If there are any alternative servers you want to use in the future, let me know either in here or via a DM.
In other topics, I’ve been tagged in a couple of tickets about the new “energy” functionality in the Lovelace UI: Energy Cards - Home Assistant
Coincidentally, I just received my solar equipment and tried to install the integration using the HA UI this morning and it is aborting due to lack of plants found. I did register and create a plan a day before. I assume this is because the server is incorrect (likely should be https://server-us.growatt.com). Thus I landed here and according to your message 1d ago the new choice functionality works in the latest release however I am not prompted to pick an alternate server. Does HA not automatically pull the latest release at the time I attempt to add integration? Thanks.
I also only recently started using HA but I just updated core and OS and now I am presented with server option but I have a new problem. When I try to log in using “https://server-us.growatt.com” I get “Unknown error occurred”
I confirmed the server is the correct one for me by paying attention to the redirect when signing in to growatt.com via web browser.
Have you tried logging into the “https://server-us.growatt.com” web page directly?
Once you’ve logged in, can you please send a screen-grab of the bit in the top left where it tells you what system you have.
We currently only support a small subset of the system types, so it needs to appear in that list in order to work with the integration.
I am not sure this has what you ask. I am not sure what you mean by system type. Its Growatt inverters?
Currently I have 3 data loggers registered. The system is not yet live so there is no generated data. Could this be the result of not having data to present? I would expect a different reaction.
That’s odd, we definitely support Storage & Inverter types. I’ve noticed you’re using the insecure (http) version of the web page. Can you test it with the secure version (https) as well?
I’m nervous that maybe accounts either exist on one or the other, not both - that would be really odd!!!
Beyond that I may have to take a look at how your specific account works (the same goes for @chester40391 too) which we can do in a number of ways, the easiest (although most worrying, is sharing your Growatt creds with me in a DM so that I can try and run a load of debug against them).
Try the HTTPS version of the webpage first and we’ll go from there.
This functionality has been implemented now for Growatt and will be in the next release of Home-Assistant.
If you’re running the dockerised version you can upgrade to “dev” now and it will be there.
