Where can I find these settings? (Searching without success )
Open the tag in access point and change content as in screenshop.
@arganto Thanks a lot - found it
Sadly there is no option I hoped to find - is there a way to change the update / wake frequency?
Is there a way to change the transmit power - I get less than 10 meters in distance - less than 5 with a wall in between, multiple house floor completely not working
Not that Iâm aware of. But currently I have not problems with ranges. I didnât even install my second ap, which I would have to mesh such problems if they would appear. 20 meters with walls and floors do not make problems at the moment. Perhaps try to change the position and angel of the AP
Did you check for updates of the AP? I had tags âforgettingâ their settings. After the latest AP update this seems to have gone.
And: I had tags that didnât work, after resetting them (take the batteries out, shorten the battery contacts), they worked fine.
Heya, I have a problem with a code Iâm trying to send to one of my 2.9ââ displays.
The source-code is:
{% set today = now().strftime('%Y-%m-%d') %}{% set ns = namespace(counter=0) %}{% for week, menu_list in state_attr('skolmat.tunge_skola', 'calendar').items() %}
{% for menu_day in menu_list %}{% if menu_day.date >= today %}{% if ns.counter < 2 %}{% set ns.counter = ns.counter + 1 %}
{{ menu_day.weekday }} ({{ menu_day.date }})
{%- for course in menu_day.courses %}
⢠{{ course }}
{%- endfor -%}{% endif %}{% endif %}{% endfor %}{% endfor %}
And if I use this in the Dev tool > template it shows up with nice line feeds:
Onsdag (2024-04-17)
⢠Currykyckling, serveras med ris
⢠Pastagratäng med tomat och parmesan
Torsdag (2024-04-18)
⢠Krämig blomkülssoppa, serveras med mjukt brÜd och pülägg
But when I send it to my panel it only show me all the info without any line feeds!
This is the code I use in the automation, is it something wrong with that one?
In the step details in the automation it shows up like the way I want it with line feeds and everything. But on my display its wierd, check the picture.
Thank you
Please post pictures of those meals! They sound far more interesting than mine:
I took a look at one of my displays that is doing carriage returns. It has this sensor
- variables:
anniversaries_upcoming: "{{ states('sensor.anniversaries_upcoming') | string }}"
The definition for sensor.anniversaries_upcoming
is below. The {{"\n"}}
(towards the bottom) part might be helpful for you?
platform: template
sensors:
value_template: >
{%- set ns = namespace(a=[]) %}
{%- for item in expand(integration_entities('anniversaries')) |
selectattr("state", 'is_number') %}
{%- set d_h = item.attributes.get('days_until_half_anniversary', 999) %}
{%- set h = d_h < item.state | int %}
{%- set d = [item.state | int, d_h] | min %}
{%- set y = item.attributes.get('current_years') %}
{%- set y = y + (0.5 if h else 1 if d != 0 else 0) if y is not none %}
{%- set ns.a = ns.a + [ dict(n=item.name, d=d, y=y, h=h)] %}
{%- endfor %}
{%- for item in ns.a | sort(attribute='d') -%}
{%- set n, d, y, h = item.n, item.d, item.y, item.h %}
{%- if d == 0 %}Today: {{ n }}
{%-if y %} ({{ y }} year){%-endif %}{{"\n"}}
{%- elif d < 45 %}{{ d }} day{{'s' if d > 1 }} until: {{ n }}
{%- endif %}
{%- endfor %}
friendly_name: "Anniversaries Upcoming"
Thank you! Looks like this could be the solution for me
I use the multiline function and add a delimiter where I need to line break.
I love this project and Iâd like to get some tags of my own, but Iâm struggling to find anywhere that sells them in the UK (or at all for that matter!), if anyone has any links Iâd greatly appreciate it
Thx for sharing it last year. I took over several things and adjusted to my needs and taste. Big and square small one.
looks great, better than mine! would you mind sharing the code?
Of course.
alias: EPaper Wetter groĂ
description: ""
- platform: state
entity_id:
- sensor.weather_home_daily
to: null
- platform: state
entity_id:
- platform: state
entity_id:
- sensor.moon_phase
- platform: state
entity_id:
- group.jemand_zu_hause
to: home
condition:
- condition: time
after: "05:30:00"
before: "23:30:00"
- if:
- condition: trigger
id:
- wetter_alles
- mond
then:
- condition: template
value_template: >-
{{ (as_timestamp(now()) -
as_timestamp(state_attr("automation.epaper_wetter_gross","last_triggered")
| default(0)) | int > 3600 ) }}
- service: counter.increment
metadata: {}
data: {}
entity_id: counter.epaper_wetter_update_counter
- service: open_epaper_link.drawcustom
entity_id:
- open_epaper_link.xxx
- open_epaper_link.yyy
- open_epaper_link.zzz
background: white
dry-run: false
rotate: 0
payload:
- type: text
value: "{{ ['Mo','Di','Mi','Do','Fr','Sa','So'][now().weekday()] }}"
x: 18
"y": 8
anchor: la
color: black
- type: text
value: "{{ '{:02d}'.format(now().day) }}.{{ '{:02d}'.format(now().month) }}."
x: 18
"y": 43
anchor: la
color: black
- type: text
value: >
{% set temp =
states('sensor.aussenthermometer_actual_temperature')|float %} {% if
temp < 10 %}
{% set temp = temp|round(0,"floor")|string %}
{% elif temp > 20 %}
{% set temp = temp|round(0,"ceil")|string %}
{% else %}
{% set temp = (((temp>0)-(temp<0))*(temp|abs+0.5)|int)|string %}
{% endif %}
{{ temp ~ "°" }}
x: |
{{ 93 - 93 + 18}}
"y": 147
anchor: la
color: black
- type: text
value: >-
{% set templow =
state_attr('sensor.weather_home_daily','forecast')[0].templow|float
%} {% if templow < 10 %}
{% set templow = templow|round(0,"floor")|string %}
{% elif templow > 20 %}
{% set templow = templow|round(0,"ceil")|string %}
{% else %}
{% set templow = (((templow>0)-(templow<0))*(templow|abs+0.5)|int)|string %}
{% endif %}
{% set tempmax =
state_attr('sensor.weather_home_daily','forecast')[0].temperature|float
%} {% if tempmax < 10 %}
{% set tempmax = tempmax|round(0,"floor")|string %}
{% elif tempmax > 20 %}
{% set tempmax = tempmax|round(0,"ceil")|string %}
{% else %}
{% set tempmax = (((tempmax>0)-(tempmax<0))*(tempmax|abs+0.5)|int)|string %}
{% endif %}
{{ templow ~ "° - " ~ tempmax ~ "°"}}
x: 18
"y": 229
anchor: la
- type: text
value: >-
{% set tag =
['','Mo','Di','Mi','Do','Fr','Sa','So'][as_datetime(state_attr('sensor.weather_home_daily',
'forecast')[1].datetime).strftime('%u')|int] %} {{tag}}
x: |
{{ 238 - var_temp_laenge }}
"y": 103
anchor: la
color: >-
{% set templow =
state_attr('sensor.weather_home_daily','forecast')[1].templow|float|round(0,"floor")
{% if templow < 3 %}
red
{% else %}
black
{% endif %}
- type: text
value: >-
{% set templow =
{% else %}
{% endif %}
{% set tempmax =
state_attr('sensor.weather_home_daily','forecast')[1].temperature|float
{% else %}
{% endif %}
x: |
"y": 128
anchor: la
- type: text
value: >-
{% set tag =
'forecast')[2].datetime).strftime('%u')|int] %} {{tag}}
x: |
"y": 166
anchor: la
color: >-
{% set templow =
state_attr('sensor.weather_home_daily','forecast')[2].templow|float|round(0,"floor")
red
{% else %}
black
{% endif %}
- type: text
value: >-
{% set templow =
{% else %}
{% endif %}
{% set tempmax =
state_attr('sensor.weather_home_daily','forecast')[2].temperature|float
{% else %}
{% endif %}
x: |
"y": 191
anchor: la
- type: text
value: >-
{% set tag =
'forecast')[3].datetime).strftime('%u')|int] %} {{tag}}
x: |
"y": 229
anchor: la
color: >-
{% set templow =
state_attr('sensor.weather_home_daily','forecast')[3].templow|float|round(0,"floor")
%} {% if templow < 3 %}
red
{% else %}
black
{% endif %}
- type: text
value: >-
{% set templow =
{% else %}
{% endif %}
{% set tempmax =
state_attr('sensor.weather_home_daily','forecast')[3].temperature|float
{% else %}
{% endif %}
x: |
"y": 254
anchor: la
- type: text
value: Mond
x: 339
"y": 17
anchor: ra
- type: text
value: >-
{% from 'easy_time.jinja' import count_the_days %} {% set mond_tage
= count_the_days(states('sensor.next_full_moon'))|int %} {% set
mond_datum = strptime(states('sensor.next_full_moon'),"%Y-%m-%d
%H:%M:%S") %} {% if mond_tage > 10 %}
{% set mond_tage = count_the_days(states('sensor.last_full_moon'))|int %}
{% endif %}
{% if mond_tage < -4 %}
{{ mond_datum.day }}.{{ '{:02d}'.format(mond_datum.month) }}.
{% elif mond_tage < -2 %}
{{ mond_tage }}
{% elif mond_tage == -2 %}
Vorgestern
{% elif mond_tage == -1 %}
Gestern
{% elif mond_tage == 0 %}
Heute
{% elif mond_tage == 1 %}
Morgen
{% elif mond_tage == 2 %}
Ăbermorgen
{% elif mond_tage > 4 %}
{% elif mond_tage > 3 %}
{{ ' +' ~ mond_tage ~ " Tage" }}
{% endif %}
x: 339
"y": 34
anchor: ra
- type: icon
value: >-
= count_the_days(states('sensor.last_full_moon'))|int %} {% if
mond_tage == 0 %}
moon-full
{% else %}
{{ ("moon-" ~
states('sensor.moon_phase')|replace('_','-'))|replace('moon-new-moon','moon-new')|replace('moon-full-moon','moon-full')
{% endif %}
x: 346
"y": 16
anchor: la
color: black
- type: dlimg
url: >-
http://192.168.178.100:8123/local/open_epaper_link/open_epaper_arrow_down.png
x: 68
"y": 104
anchor: mm
xsize: 50
ysize: 50
rotate: >-
{{ state_attr('sensor.weather_home_daily', 'wind_bearing')|round(0)
- type: icon
value: "{{ var_icon_array[states(\"sensor.weather_home_daily\")] }}"
x: |
{{ 93 - 93 + 18}}
"y": 101
anchor: la
color: black
visible: true
- type: icon
value: >-
var_icon_array[state_attr('sensor.weather_home_daily','forecast')[1].condition]
x: 298
"y": 105
anchor: la
color: black
- type: icon
value: >-
var_icon_array[state_attr('sensor.weather_home_daily','forecast')[2].condition]
x: 298
"y": 168
anchor: la
color: black
- type: icon
value: >-
var_icon_array[state_attr('sensor.weather_home_daily','forecast')[3].condition]
x: 298
"y": 231
anchor: la
color: black
- type: text
value: >-
state_attr('sensor.weather_home_daily','forecast')[0].precipitation|float|round(0,"ceil")
~ " L" ~ " - " ~
state_attr('sensor.weather_home_daily','forecast')[0].precipitation_probability|float|round(0,"ceil")
x: |
{{ 93 - 93 + 18}}
"y": 254
anchor: la
visible: >
> -10 }}
- type: text
value: >-
state_attr('sensor.weather_home_daily','forecast')[1].precipitation|float|round(0,"ceil")
~" L" }}
x: 360
"y": 134
anchor: la
visible: >
> -10 }}
- type: text
value: >-
state_attr('sensor.weather_home_daily','forecast')[2].precipitation|float|round(0,"ceil")
~" L" }}
x: 360
"y": 197
anchor: la
visible: >
> -10 }}
- type: text
value: >-
state_attr('sensor.weather_home_daily','forecast')[3].precipitation|float|round(0,"ceil")
~" L" }}
x: 360
"y": 260
anchor: la
visible: >
> -10 }}
- type: icon
value: windsock
x: 106
"y": 15
anchor: la
color: >
{% set wind = state_attr('sensor.weather_home_daily',
'forecast')[0].wind_speed|int %} {% if wind > 74 %}
red
{% else %}
black
{% endif %}
visible: >
'forecast')[0].wind_speed|int %} {{ wind > 49 }}
- type: icon
value: windsock
x: 358
"y": 112
anchor: la
color: >
'forecast')[1].wind_speed|int %} {% if wind > 74 %}
red
{% else %}
black
{% endif %}
visible: >
'forecast')[1].wind_speed|int %} {{ wind > 49 }}
- type: icon
value: windsock
x: 358
"y": 175
anchor: la
color: >
'forecast')[2].wind_speed|int %} {% if wind > 74 %}
red
{% else %}
black
{% endif %}
visible: >
'forecast')[2].wind_speed|int %} {{ wind > 49 }}
- type: icon
value: windsock
x: 360
"y": 238
anchor: la
color: >
'forecast')[3].wind_speed|int %} {% if wind > 74 %}
red
{% else %}
black
{% endif %}
visible: >
'forecast')[3].wind_speed|int %} {{ wind > 49 }}
- type: icon
value: alert-octagon
x: >
'forecast')[0].wind_speed|int %} {% if wind > 49 %}
150
{% else %}
106
{% endif %}
"y": 15
anchor: la
color: >
{% if
states('sensor.dwd_wetterwarnung_current_warning_level')|int
== 3
or states('sensor.dwd_wetterwarnung_advance_warning_level')|int == 3
%}red{% else %}black{% endif %}
visible: >
> 0
or states('sensor.dwd_wetterwarnung_advance_warning_level')|int > 0 }}
variables:
var_icon_array: |
{% set array = {
'clearsky':'weather-sunny',
'clear-night':'weather-night',
'clear-night2':'weather-night-partly-cloudy',
'cloudy':'weather-cloudy',
'fair':'weather-sunny',
'sunny':'weather-sunny',
'fog':'weather-fog',
'heavyrain':'weather-pouring',
'heavyrainandthunder':'weather-lightning-rainy',
'heavyrainshowers':'weather-pouring',
'heavyrainshowersandthunder':'weather-lightning-rainy',
'heavysleet':'weather-snowy-heavy',
'heavysleetandthunder':'weather-snowy-heavy',
'heavysleetshowers':'weather-snowy-rainy',
'heavysleetshowersandthunder':'weather-snowy-rainy',
'heavysnow':'weather-snowy-heavy',
'heavysnowandthunder':'wweather-snowy-rainy',
'heavysnowshowers':'weather-snowy-heavy',
'heavysnowshowersandthunder':'weather-snowy-heavy',
'lightrain':'weather-rainy',
'lightrainandthunder':'weather-lightning-rainy',
'lightrainshowers':'weather-partly-rainy',
'lightrainshowersandthunder':'weather-partly-lightning',
'lightsleet':'weather-snowy-rainy',
'lightsleetandthunder':'weather-snowy-rainy',
'lightsleetshowers':'weather-snowy-rainy',
'lightsnow':'weather-snowy',
'lightsnowandthunder':'weather-snowy',
'lightsnowshowers':'weather-snowy-rainy',
'lightssleetshowersandthunder':'weather-snowy-rainy',
'lightssnowshowersandthunder':'weather-snowy-rainy',
'partlycloudy':'weather-partly-cloudy',
'rainy':'weather-rainy',
'rainandthunder':'weather-lightning-rainy',
'rainshowers':'weather-partly-rainy',
'rainshowersandthunder':'weather-lightning-rainy',
'sleet':'weather-snowy',
'sleetandthunder':'weather-snowy',
'sleetshowers':'weather-snowy',
'sleetshowersandthunder':'weather-snowy',
'snow':'weather-snowy',
'snowandthunder':'weather-snowy',
'snowshowers':'weather-snowy',
'snowshowersandthunder':'weather-snowy' }
%} {{ array }}
var_temp_laenge: >
{% set temp_laenge_max = 0 %}
{% set templow =
state_attr('sensor.weather_home_daily','forecast')[1].templow|float %} {% if
templow < 10 %}
{% else %}
{% endif %}
{% set tempmax =
state_attr('sensor.weather_home_daily','forecast')[1].temperature|float %}
{% else %}
{% endif %}
{% set temp_laenge = namespace(foo=0) %}
{% for i in range(templow|length) %}
{% set d = {
'-': 14,
'0': 15,
'1': 9,
'2': 14,
'3': 14,
'4': 16,
'5': 15,
'6': 15,
'7': 14,
'8': 15,
'9': 14 } %}
{% set temp_laenge.foo = temp_laenge.foo + d.get(templow[i]) %}
{% endfor %}
{% for i in range(tempmax|length) %}
{% set d = {
'-': 14,
'0': 15,
'1': 9,
'2': 14,
'3': 14,
'4': 16,
'5': 15,
'6': 15,
'7': 14,
'8': 15,
'9': 14 } %}
{% set temp_laenge.foo = temp_laenge.foo + d.get(tempmax[i]) %}
{% endfor %}
{% if temp_laenge.foo > temp_laenge_max %}
{% set temp_laenge_max = temp_laenge.foo %}
{% endif %}
{% set templow =
state_attr('sensor.weather_home_daily','forecast')[2].templow|float %} {% if
templow < 10 %}
{% else %}
{% endif %}
{% set tempmax =
state_attr('sensor.weather_home_daily','forecast')[2].temperature|float %}
{% else %}
{% endif %}
{% set d = {
'-': 14,
'0': 15,
'1': 9,
'2': 14,
'3': 14,
'4': 16,
'5': 15,
'6': 15,
'7': 14,
'8': 15,
'9': 14 } %}
{% endfor %}
{% set d = {
'-': 14,
'0': 15,
'1': 9,
'2': 14,
'3': 14,
'4': 16,
'5': 15,
'6': 15,
'7': 14,
'8': 15,
'9': 14 } %}
{% endfor %}
{% endif %}
{% set templow =
state_attr('sensor.weather_home_daily','forecast')[3].templow|float %} {% if
templow < 10 %}
{% else %}
{% endif %}
{% set tempmax =
state_attr('sensor.weather_home_daily','forecast')[3].temperature|float %}
{% else %}
{% endif %}
{% set d = {
'-': 14,
'0': 15,
'1': 9,
'2': 14,
'3': 14,
'4': 16,
'5': 15,
'6': 15,
'7': 14,
'8': 15,
'9': 14 } %}
{% endfor %}
{% set d = {
'-': 14,
'0': 15,
'1': 9,
'2': 14,
'3': 14,
'4': 16,
'5': 15,
'6': 15,
'7': 14,
'8': 15,
'9': 14 } %}
{% endfor %}
{% endif %}
{{ temp_laenge_max }}
mode: queued
max: 10
Some infos:
- I put the icon mapping in a variable
- The other variable is for having theforecast day and temperatures left aligned but always as right as possiblem. For this I counted the pixcels and calculate the x avalue
- The color coding for temperature and wind is still there
- The wind as well, but nor with visible parameter and not with pushing x and y out of display
- The rounding looks most probaly weired, but I wanted to have german rounding (,5 is 1) but round down on low temperature and round up on high for this display.
much cleaner than my old code, which doesnât work anymore anyway due to the changes in the met.no sensors.
What about the small one?
Here I use now local sensors with forcast deriving from met.no. They are used in the automation.
- trigger:
- platform: time_pattern
minutes: "/30"
- platform: homeassistant
event: start
- platform: event
event_type: event_template_reloaded
- service: weather.get_forecasts
entity_id: weather.home
type: hourly
response_variable: hourly_forecast
type: daily
response_variable: daily_forecast
- name: "Weather Home Hourly"
unique_id: waether_home_hourly
state: "{{ states('weather.home') }}"
attributes:
temperature: "{{ state_attr('weather.home', 'temperature') }}"
dew_point: "{{ state_attr('weather.home', 'dew_point') }}"
temperature_unit: "{{ state_attr('weather.home', 'temperature_unit') }}"
humidity: "{{ state_attr('weather.home', 'humidity') }}"
cloud_coverage: "{{ state_attr('weather.home', 'cloud_coverage') }}"
pressure: "{{ state_attr('weather.home', 'pressure') }}"
pressure_unit: "{{ state_attr('weather.home', 'pressure_unit') }}"
wind_bearing: "{{ state_attr('weather.home', 'wind_bearing') }}"
wind_gust_speed: "{{ state_attr('weather.home', 'wind_gust_speed') }}"
wind_speed: "{{ state_attr('weather.home', 'wind_speed') }}"
wind_speed_unit: "{{ state_attr('weather.home', 'wind_speed_unit') }}"
visibility: "{{ state_attr('weather.home', 'visibility') }}"
visibility_unit: "{{ state_attr('weather.home', 'visibility_unit') }}"
precipitation: "{{ state_attr('weather.home', 'precipitation') }}"
precipitation_unit: "{{ state_attr('weather.home', 'precipitation_unit') }}"
forecast: "{{ hourly_forecast['weather.home'].forecast[:23] }}"
- name: "Weather Home Daily"
unique_id: weather_home_daily
attributes:
forecast: "{{ daily_forecast['weather.home'].forecast[:5] }}"
And the small one is
alias: EPaper Wetter klein
description: ""
- platform: state
entity_id:
to: null
- platform: state
entity_id:
- platform: state
entity_id:
to: home
condition:
- condition: time
after: "03:30:00"
before: "23:30:00"
- if:
id:
- wetter_alles
then:
value_template: >-
as_timestamp(state_attr("automation.epaper_wetter_klein","last_triggered")
metadata: {}
data: {}
entity_id: counter.epaper_wetter_klein_update_counter
enabled: true
entity_id:
background: white
dry-run: false
rotate: 0
payload:
- type: text
value: >-
{{ ['Mo','Di','Mi','Do','Fr','Sa','So'][now().weekday()] }}, {{
x: 9
"y": 4
anchor: la
color: black
- type: text
x: 9
"y": 20
anchor: la
color: black
visible: false
- type: text
value: >-
{% set templow =
{% else %}
{% endif %}
{% set tempmax =
{% else %}
{% endif %}
x: 9
"y": 20
anchor: la
- type: icon
value: >-
x: 144
"y": 9
anchor: rt
color: black
- type: text
value: >
{% set temp =
temp < 10 %}
{% else %}
{% endif %}
{{ temp ~ "°" }}
x: 76
"y": 43
anchor: ma
color: black
- type: icon
x: 146
"y": 84
anchor: ra
color: >
{% if
states('sensor.dwd_wetterwarnung_gemeinde_warning_level')|int
== 3
visible: >
> 0
or states('sensor.dwd_wetterwarnung_advance_warning_level')|int > -0 }}
- type: text
value: >-
~ " L" ~ " / " ~
x: 76
"y": 121
anchor: ma
visible: >
> -10 }}
variables:
var_icon_array: |
{% set array = {
%} {{ array }}
mode: queued
max: 10
I love these price tags!
Demo movie:
https://dms.licdn.com/playlist/vid/D4E05AQE42PulNwFtig/mp4-640p-30fp-crf28/0/1716144748030?e=2147483647&v=beta&t=LCkBmj2orM5Ex_WbmQuEf-7_3rw07URB5lEZP74CU1k
I love esp. the integration.
For the tags (have lots of them nevertheless) I would like to have more beautiful ones with same border and without bar codes. Saw a lot of prettier ones here in the markets. And the big ones in white instead of black.
Yes, I know, that I can pull the barcode tag, but then I have still the big site and an empty slot with a little hole.
I just made a Nordpool portrait template.
If I could then I would use the landscape versions that has been posted previously here in the thread but since I need it to fit with other displays I need it in portrait mode.
It displays today and tomorrows prices with a maximum of 12 times. Cheapest times are marked with a red bold border, highest prices are written in red.
Here is the template that I added some easy tweaks for different currencies and such also.
alias: Elpriser kĂśksdisplay
description: ""
hours: /1
condition: []
entity_id:
- open_epaper_link.0000021e68ba3b1b
background: white
rotate: 270
payload: >
{% set ns = namespace( text_list = [], line =0) %}
{% set nordpool = "sensor.nordpool_kwh_se4_sek_3_10_025" %}
{% set cheapest = 5 %} {## Number of cheapest times per day to highlight ##}
{% set expensivest = 5 %} {## Number of expensivest times per day to highlight ##}
{% set decimal = "," %} {## decimal separator in currency ##}
{% set currency = "kr" %} {## include space if needed/wanted ##}
{% set position = "trailing" %} {## trailing or leading position of currency ##}
{% set decimal_places = 2 %}
{## No need to change anything below here ##}
{% for day in ["today", "tomorrow"] %}
{% for s in state_attr(nordpool,'raw_' ~ day)-%}
{% if s.end > now() -%}
{%- set ns.text_list = ns.text_list +
[{ "type": "rectangle",
"x_start": 1,
"x_end": 127,
"y_start": 1 + (25*ns.line),
"y_end": 25 + (25*ns.line),
"width": 4 if s.value in (state_attr(nordpool, day) | sort(reverse = false))[0:cheapest] else 2,
"fill": "white",
"outline": "red" if s.value in (state_attr(nordpool, day) | sort(reverse = false))[0:cheapest] else "black"}] +
[{ "type": "text",
"value": ("0" ~ s.start.hour)[-2:3] ~ ":00",
"font": "ppb.ttf",
"x": 5,
"y": 7 + (25*ns.line),
"size": 16,
"color": "red" if s.value in (state_attr(nordpool, day) | sort(reverse = true))[0:expensivest] else "black"} ] +
[{ "type": "text",
"value": (currency if position == "leading") ~ (((s.value | round(decimal_places) ~ "00000")[0:decimal_places+(s.value|string).split(".")[0]|length +1]) |string).replace(".", decimal) ~ (currency if position == "trailing"),
"font": "ppb.ttf",
"x": 58,
"size": 16,
"color": "red" if s.value in (state_attr(nordpool, day) | sort(reverse = true))[0:expensivest] else "black"} ] -%}
{% set ns.line = ns.line + 1 %}
{% endif %}
{%- endfor -%}
{%- endfor -%}
{{ ns.text_list }}
enabled: true
mode: single
Is there any good monospaced fonts anyone has a link to?
Does anyone know if it would be OK to power the 2.9âł STâGR29000 from a 3.3V PSU? My application (medical information) updates every ten minutes and burns through batteries too fast.
This is a really interesting idea. For some of my use cases, I want to update the display every hour, but that drains the battery so fast. I just tried to play around by using 2 AA batteries and it seems to work just fine. (sorry for the horrible setup, but the original red wire from the battery holder got ripped out )
