Should be lrwxrwxrwx 1 root root
if Iβm not mistaken
Try running the lxc privileged
Removing that unpriviliged line causes HA not to start, the lxc does though.
Rebooted twice, after putting back that line HA runs fine.
Also tried to change owner/group in the lxc but got a permission denied.
Hereβs my z2m lxc options
Also NO firewall
uhmβ¦ Iβm doing this in my HA contianer
Are you running Home Assistant Supervised or Home Assistant Container?
Iβm still lost in all the different types of setup/names.
Version core-2021.7.1
Installation Type Home Assistant Core
Development false
Supervisor false
Docker false
Virtual Environment true
Python Version 3.8.7
Operating System Family Linux
Operating System Version 5.4.119-1-pve
CPU Architecture x86_64
Yes, I have installed it aside some time ago as a VM but my server is at itβs max of RAM usage, thatβs why I sticked to core.
Is it wrong/impossible/unlogic to run deCONZ in the same lxc as HA and/or is this the reason why Iβm have this problem?i
I think so
Ok, letβs cut it here (have to walk the dog)
THANKS A MILLION MAN for your help and have a nice remains of the day!
Sorry to dig up an old topic, but I just came across this and thought Iβd share what fixed it for me.
I was moving my deconz from a Proxmox KVM to a LXC and to make it more complex deconz is running in docker on the LXC
Everything looked good except it couldnβt βseeβ the stick - the permissions on the below command were the issue
ls -l /dev/serial/by-id/
As @tteck said, the permissions should be root root
not nobody nobody
The fix is to chown on the host
In Proxmox on an unprivileged container for security root user is user 10000 not 1000 as on the host.
Just run on the host
chown 100000:100000 /dev/serial/by-id/*
Then do the ls -l
in the LXC and it will show root as the user and group.
Hope this helps someone.
BTW - deconz in a LXC in docker flies!!!
Cheers
mb
Seems Iβm stuck with the same issue.
Iβve been able to pass the stick through (by-id) and the owner/group is βrootβ
Not sure what to try next
Hi all,
I have the same setup with a conbee II and i am trying to make it work inside a LXC zigbee2mqtt.
I setup the zigbee2mqtt LXC using ttecks awesome scripts. Thank you @tteck for creating these and sharing it with the community.
Here is my setup so far.
I ran the following on the proxmox host as root
Then I ran this
And I get the following message.
total 0
Can you please help
In the Proxmox shell run cat /etc/pve/lxc/104.conf
and share your results
The script that you referred to doesnβt exist any longer.
@tteck thanks for offering help.
here are the results.
arch: amd64
cores: 2
features: nesting=1
hostname: zigbee2mqtt
memory: 1024
net0: name=eth0,bridge=vmbr0,gw=192.168.1.1,hwaddr=XX:XX:XX:XX:XX:XX,ip=192.168.XXX.XXX/24,type=veth
onboot: 1
ostype: debian
rootfs: local-lvm:vm-104-disk-0,size=4G
swap: 512
lxc.cgroup2.devices.allow: a
lxc.cap.drop:
lxc.cgroup2.devices.allow: c 188:* rwm
lxc.cgroup2.devices.allow: c 189:* rwm
lxc.mount.entry: /dev/serial/by-id dev/serial/by-id none bind,optional,create=dir
lxc.mount.entry: /dev/ttyUSB0 dev/ttyUSB0 none bind,optional,create=file
lxc.mount.entry: /dev/ttyACM0 dev/ttyACM0 none bind,optional,create=file
shows nothing?
Should show something similar
root@zigbee2mqtt:~# ls -l /dev/serial/by-id
total 0
lrwxrwxrwx 1 root root 13 Feb 22 13:07 usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_a4766cbfb593eb11b7611b4f3d9-if00-port0 -> ../../ttyUSB0
root@zigbee2mqtt:~#
do i run this in the container or on the host?
Host.
You havenβt connected it to your guest successfully yet.
oh boy! it must be frustrating to deal with noobs like me. I feel for you
on host I do see
lrwxrwxrwx 1 root root 13 Feb 23 18:07 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2488601-if00 -> ../../ttyACM0
