Doh! I thought the command-line sensor executed in the context of the OS but I was wrong.
I’ve amended my previous post.
This seems to be the solution to my problems as well, @CentralCommand . However, I can’t get it to work (on HaOS).
In Terminal add-on, I get the following, indicating that the solution should work just fine.
[core-ssh ~]$ jq '.' /config/www/resurser/log.json
"Body": {
"I18N_COMMON_PV_DAYILY_ENERGY_GENERATION": "0.0",
"I18N_COMMON_PV_TOTAL_ENERGY_GENERATION": "316.8",
"I18N_COMMON_TOTAL_YIELD": "--",
"I18N_COMMON_DEVICE_STATUS": "Energy Dispatching Operation",
"I18N_COMMON_BUS_VOLTAGE": "634.0",
"I18N_COMMON_AIR_TEM_INSIDE_MACHINE": "24.1",
"I18N_COMMON_SQUARE_ARRAY_INSULATION_IMPEDANCE": "891",
"I18N_CONFIG_KEY_1001188": "100.0",
"I18N_COMMON_FEED_NETWORK_TOTAL_ACTIVE_POWER": "0.00",
"I18N_CONFIG_KEY_4060": "0.78",
"I18N_COMMON_DAILY_FEED_NETWORK_VOLUME": "0.0",
"I18N_COMMON_TOTAL_FEED_NETWORK_VOLUME": "192.8",
"I18N_COMMON_ENERGY_GET_FROM_GRID_DAILY": "63.7",
"I18N_COMMON_TOTAL_ELECTRIC_GRID_GET_POWER": "4713.0",
"I18N_COMMON_DAILY_FEED_NETWORK_PV": "0.0",
"I18N_COMMON_TOTAL_FEED_NETWORK_PV": "180.1",
"I18N_COMMON_LOAD_TOTAL_ACTIVE_POWER": "0.752",
"I18N_COMMON_DAILY_DIRECT_CONSUMPTION_ELECTRICITY_PV": "0.0",
"I18N_COMMON_TOTAL_DIRECT_POWER_CONSUMPTION_PV": "98.9",
"I18N_COMMON_TOTAL_DCPOWER": "0.00",
"I18N_COMMON_TOTAL_ACTIVE_POWER": "-0.02",
"I18N_COMMON_TOTAL_REACTIVE_POWER": "-0.01",
"I18N_COMMON_TOTAL_APPARENT_POWER": "0.02",
"I18N_COMMON_TOTAL_POWER_FACTOR": "0.937",
"I18N_COMMON_GRID_FREQUENCY": "50.02",
"I18N_COMMONUA": "235.3",
"I18N_COMMON_UB": "234.5",
"I18N_COMMON_UC": "233.1",
"I18N_COMMON_FRAGMENT_RUN_TYPE1": "0.4",
"I18N_COMMON_IB": "0.4",
"I18N_COMMON_IC": "0.4",
"I18N_COMMON_PHASE_A_BACKUP_CURRENT_QFKYGING": "0.1",
"I18N_COMMON_PHASE_B_BACKUP_CURRENT_ODXCTVMS": "0.1",
"I18N_COMMON_PHASE_C_BACKUP_CURRENT_PBSQLZIX": "0.4",
"I18N_COMMON_PHASE_A_BACKUP_VOLTAGE_PEIYFKXE": "--",
"I18N_COMMON_PHASE_B_BACKUP_VOLTAGE_MCDGYUJO": "--",
"I18N_COMMON_PHASE_C_BACKUP_VOLTAGE_SCJZFFCQ": "--",
"I18N_COMMON_BACKUP_FREQUENCY_MPPOWHDF": "--",
"I18N_COMMON_PHASE_A_BACKUP_POWER_BRBJDGVB": "0.000",
"I18N_COMMON_PHASE_B_BACKUP_POWER_OCDHLMZB": "0.000",
"I18N_COMMON_PHASE_C_BACKUP_POWER_HAMBBGNL": "0.000",
"I18N_COMMON_TOTAL_BACKUP_POWER_WLECIVPM": "0.000",
"I18N_COMMON_MAXIMUM_APPARENT_POWER_SIWHFGQY": "10.0",
"I18N_COMMON_METER_GRID_FREQ_AMMAKPKU": "50.02",
"I18N_COMMON_REACTIVE_POWER_UPLOADED_BY_ME_KISYMRKR":
"-221",
"I18N_CONFIG_KEY_3907": "0.000",
"I18N_CONFIG_KEY_3921": "0.000",
"I18N_COMMON_BATTERY_VOLTAGE": "328.6",
"I18N_COMMON_BATTERY_CURRENT": "0.0",
"I18N_COMMON_BATTERY_TEMPERATURE": "16.5",
"I18N_COMMON_BATTERY_SOC": "60.0",
"I18N_COMMON_BATTARY_HEALTH": "100",
"I18N_COMMON_MAX_CHARGE_CURRENT_BMS": "30",
"I18N_COMMON_MAX_DISCHARGE_CURRENT_BMS": "30",
"I18N_COMMON_DAILY_BATTERY_CHARGE_PV": "0.0",
"I18N_COMMON_TOTAL_BATTERY_CHARGE_PV": "37.8",
"I18N_COMMON_DAILY_BATTERY_DISCHARGE": "0.0",
"I18N_COMMON_TOTAL_BATTRY_DISCHARGE": "45.2",
"I18N_COMMON_DAILY_BATTERY_CHARGE": "0.2",
"I18N_COMMON_TOTAL_BATTERY_CHARGE": "73.5",
"MPPT1": "0.0",
"MPPT2": "0.0",
"I18N_COMMON_GROUP_BUNCH_TITLE_AND%@1": "0.00",
"I18N_COMMON_GROUP_BUNCH_TITLE_AND%@2": "0.00",
"I18N_COMMON_REMAIN_BATTERY_POWER": "62.0",
"I18N_COMMON_TOTAL_BATTERY_DISCHARGE_BMS": "67.1",
"I18N_COMMON_BATTERY_OPERATION_STATUS": "Run"
In configuration.yaml
I have the following code, which for some reason does not produce a sensor.
- platform: command_line
scan_interval: 20
command: 'jq ''.'' /config/www/resurser/log.json'
value_template: "{{ value_json[0].Body }}"
json_attributes:
- I18N_COMMON_BATTERY_TEMPERATURE
Any ideas as to why the above does not work? I’ve tried inverting quotes: command: "jq '.' /config/www/resurser/log.json"
The following code solved the issue:
scan_interval: 20
command: 'jq ''.Body'' /config/www/resurser/log.json'
value_template: "OK"
json_attributes:
