Apexcharts and Openweathermap Forecast examples
This is a working example of the 3 (for me) most important values of a forecast: temperature, cloud-coverage and precipitation-probability. if you use another weatherforecast integration than openweathermap the naming of the values could vary (sorry for the german wordings, but I guess you get what is behind)
type: custom:apexcharts-card
header:
  show: true
  title: Vorhersage
  show_states: false
  colorize_states: true
now:
  show: true
span:
  start: hour
graph_span: 36h
apex_config:
  dataLabels:
    enabled: true
all_series_config:
  stroke_width: 1
yaxis:
  - id: degrees
    decimals: 1
  - id: prozent
    opposite: true
    decimals: 1
    min: 0
    max: 100
series:
  - entity: weather.openweathermap
    yaxis_id: degrees
    data_generator: |
      return entity.attributes.forecast.map((entry) => {
        return [new Date(entry.datetime).getTime(), entry.temperature];
    unit: °C
    color: red
    yaxis_id: prozent
    data_generator: |
            return [new Date(entry.datetime).getTime(), entry.precipitation_probability];
    color: blue
    unit: '%'
    yaxis_id: prozent
    data_generator: |
            return [new Date(entry.datetime).getTime(), entry.cloud_coverage];
    color: orange
    unit: '%'
Perhaps include a screenshot to show your work off?
Please don’t apologise for this - it’s appreciated that you are sharing :smile:
Here are mine:
template sensors
# temp forecast ----------------------------------------------------------------
      - name: Weather temp
        unique_id: weather_temp
        device_class: temperature
        unit_of_measurement: '°C'
        state: "{{ state_attr('weather.openweathermap','temperature') }}"
        attributes:
          forecast_state: |
              state_attr('weather.openweathermap', 'forecast')
              | map(attribute="temperature")
              | map("float")
              | map("round",1)
              | list
          forecast_time: |
              (state_attr('weather.openweathermap', 'forecast')
              | map(attribute="datetime")
              | list)[0:48]
# rain forecast ----------------------------------------------------------------
      - name: Weather rain
        unique_id: weather_rain
        device_class: precipitation
        unit_of_measurement: mm
        state: "{{ states('sensor.openweathermap_rain') }}"
        attributes:
          forecast_state: |
              | map(attribute="precipitation")
              | map("float")
              | list
          forecast_time: |
              | list)[0:48]
# pressure forecast ------------------------------------------------------------
      - name: Weather pressure
        unique_id: weather_pressure
        device_class: pressure
        unit_of_measurement: hPa
        state: "{{ state_attr('weather.openweathermap','pressure') }}"
        attributes:
          forecast_state: |
              | map(attribute="pressure")
              | map("int")
              | list
          forecast_time: |
              | list)[0:48]
# wind forecast ----------------------------------------------------------------
      - name: Weather wind
        unique_id: weather_wind
        device_class: wind_speed
        unit_of_measurement: mph
        state: "{{ (state_attr('weather.openweathermap','wind_speed')*0.62)|round(1) }}"
        attributes:
          forecast_state: |
                | map(attribute="wind_speed")
                | map("float")
                | map("multiply", 0.62 )
                | map("round",1)
                | list
              )[0:48]
          forecast_time: |
                | list
              )[0:48]
Have not used this in a while so still looking for the corresponding apex-chart dashboard yaml
Bildschirmfoto-20240318140036-682x473
this is the apexchart that is being produced. no additional sensor is required
is this still working? After the latest ha upgrade, mine was unavailable, seems the function was deprecated and removed.
I followed this workaround, in case it helps anyone:
when creating the new template sensor, I replaced forecast-home with openweathermap, so I now have:
 - trigger:
      - platform: time_pattern
      #  hours: "/1"
        minutes: "/1"
      - service: weather.get_forecasts
          type: hourly
          entity_id: weather.openweathermap
        response_variable: hourlyforecast
      - name: "Forecast Home Hourly"
        unique_id: bis202312041810
        icon: mdi:weather-cloudy-clock
        state: "{{ now().isoformat() }}"
        attributes:
          forecast: "{{ hourlyforecast['weather.openweathermap']['forecast'] }}"
will change the trigger back to hours. This one was just for not having to wait one hour to check…
Then, in the apex chart config, replaced entity weather.openweathermap with
- entity: sensor.forecast_home_hourly
Done. For now…
Apologies. I am not so experienced with HA. Where do I create this - trigger in YAML? I’ve been using same Apexchart / forecast solution and trying to fix it.
It’s a trigger-based template sensor, so goes into configuration.yaml (unless you have split it out). The full header looks like this:
template:
  - trigger:
      - name:
Simple as that… thank you so much! Working fine again :slight_smile:
I am trying to get it right since hours, but I can’t figure out what is actually the problem. I setup the template sensor as described above. My sensors forecast attribute is looking like this:
[{'datetime': datetime.datetime(2024, 6, 2, 17, 0, tzinfo=datetime.timezone.utc), 'precipitation': None, 'precipitation_probability': None, 'cloudcover_percentage': 100, 'cloudless_percentage': 0, 'cloud_area_fraction': 100, 'cloud_area_fraction_high': 100, 'cloud_area_fraction_medium': 2, 'cloud_area_fraction_low': 21, 'fog_area_fraction': 0, 'seeing_percentage': 75, 'transparency_percentage': 35, 'lifted_index': -4, 'condition': 41, 'precipitation_amount': 0.0, 'calm_percentage': 74, 'wind_speed': 4.2, 'wind_bearing': 'NW', 'temperature': 17.8, 'humidity': 85}, {'datetime': datetime.datetime(2024, 6, 2, 18, 0, tzinfo=datetime.timezone.utc), 'precipitation': None, 'precipitation_probability': None, 'cloudcover_percentage': 100, 'cloudless_percentage': 0, 'cloud_area_fraction': 100, 'cloud_area_fraction_high': 100, 'cloud_area_fraction_medium': 19, 'cloud_area_fraction_low': 44, 'fog_area_fraction': 0, 'seeing_percentage': 65, 'transparency_percentage': 0, 'lifted_index': -1, 'condition': 35, 'precipitation_amount': 0.1, 'calm_percentage': 75, 'wind_speed': 4.1, 'wind_bearing': 'NW', 'temperature': 17.3, 'humidity': 86},..]
When trying to use the apex charts as I used to and as described above, the chart states “loading…”. Is this related to the date being stored as python date format? When I call the service I receive normal datestring, but it looks like storing it as a template saves it in this python date format that js cannot understand.
For completeness, here is the chart I am using, which worked before the update (replaced the entity with my template sensor):
header:
  show: true
  title: ApexCharts-Card
  show_states: true
now:
  show: true
graph_span: 48h
span:
  start: hour
  offset: '-1h'
series:
  - entity: sensor.astroweather_hourly_forecast
    unit: K
    data_generator: |
        return [new Date(entry.datetime).getTime(), entry.lifted_index];
And here is my template sensor:
# Astroweather
- trigger:
      hours: /1
        entity_id:
          - weather.astroweather
        type: hourly
      response_variable: hourly_forecast
    - name: Astroweather hourly Forecast
      unique_id: astroweather_hourly_forecast
      icon: mdi:hours-24
      attributes:
        forecast: "{{ hourly_forecast['weather.astroweather']['forecast'] }}"
