I have some trouble wrapping my head around the cancel_timer().
This works:
Warn me if the espresso machine is left "on" for more than 45 minutes.
Notify every 15 minutes.
After 1.5 hours, turn off and notify.
Set times is app config (apps.yaml)
import datetime
class ApplianceStatus(hass.Hass):
def initialize(self):
Initialize the timers and set listen_state
self.starttime = datetime.datetime.now()
self.timer = None
self.listen_state(self.StartTimer,"switch.switch")
def StartTimer(self, entity, attribute, old, new, kwargs):
Cancel timer if entity is turned offself.
Otherwise note the time, and start the loop (SendNotification)
if new == "off":
self.cancel_timer(self.timer)
else:
self.timer = self.run_in(self.SendNotification,self.args["start_after"])
def SendNotification(self, kwargs):
Otherwise notify me about leaving the switch on every "time_between_notifications" secondsself.
After "end_after" seconds, automatically turn off, and notify me.
delta = datetime.datetime.now() - self.starttime
seconds = int(datetime.timedelta.total_seconds(delta))
minutes = round(seconds/60)
self.log(str(minutes) + " " + str(seconds)) # for troubleshooting
if self.get_state('switch.switch') == 'off':
elif seconds < self.args["end_after"]:
self.call_service("notify/home_aephir_bot", message="Espresso machine has been on for " + str(minutes) + " minutes", data={"inline_keyboard":"Turn Off:/espresso_off, I Know:/removekeyboard"})
self.log("Espresso machine has been on for " + str(minutes) + " minutes")
self.run_in(self.SendNotification,self.args["time_between_notifications"])
else:
if self.args["switch_off"]:
self.turn_off(self.args["entity"])
switchofftext = ", i turned it off."
self.turn_off('switch.switch')
else:
switchofftext = "."
self.call_service("notify/home_aephir_bot", message="Espresso machine has been on for " + str(minutes) + " minutes" + switchofftext, data={"inline_keyboard":"Turn back on:/espresso_on, OK, thanks!:/removekeyboard"})
self.log("Espresso machine has been on for " + str(minutes) + " minutes" + switchoffftext,)
But this does not (only change being what is commented out in the SendNotification
import datetime
self.timer = None
if new == "off":
else:
# if self.get_state('switch.switch') == 'off':
# self.cancel_timer(self.timer)
else:
else:
switchofftext = "."
The latter keeps sending notifications even after the switch is turned off. Could anyone explain the cancel_timer() a bit more in detail than in the documentation? Why does the cancel_timer()
in the StartTimer
not cancel the timer when the switch turns off?
