Hi Tomas,
I added the styles.js and the two .png files.
Unfortunately, that does not change; when I do f12, no error appears.
I wonder if my googlemaps.yaml file is correct:
The googlemaps.yaml file is ok. I am not using any configuration fields or icons in the widget, so nothing need to be changed. Did the error in the javascript console change?
I didn’t add the layout. If I add it, I have this message in the javascript console:
jquery-3.1.1.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery-3.1.1.min.js:4
common.js:38 no window definitions match http://192.168.2.66:5050/Googlemaps
common.js:38 detection has already been attempted
