pip
[Unit]
Description=AppDaemon
[email protected]
[Service]
Type=simple
User=homeassistant
ExecStart=/usr/local/bin/appdaemon -c /home/homeassistant/.homeassistant/conf/
[Install]
WantedBy=multi-user.target
pip
[Unit]
[email protected]
[Service]
Type=simple
User=homeassistant
[Install]
journalctl output
Jan 15 23:16:47 ReinasServer systemd[1]: Stopped appdaemon.
Jan 15 23:16:47 ReinasServer systemd[1]: appdaemon.service: Start request repeated too
Jan 15 23:16:47 ReinasServer systemd[1]: Failed to start appdaemon.
Jan 15 23:16:47 ReinasServer systemd[1]: appdaemon.service: Unit entered failed state.
Jan 15 23:16:47 ReinasServer systemd[1]: appdaemon.service: Failed with result 'exit-code'.
systemd propertioes
-rwxrwxrwx 1 root root 218 Jan 15 23:15 [email protected]
drwxr-xr-x 2 root root 4096 Dec 29 2017 bluetooth.target.wants
lrwxrwxrwx 1 root root 9 Jan 27 2018 brltty.service -> /dev/null
lrwxrwxrwx 1 root root 37 Dec 29 2017 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
lrwxrwxrwx 1 root root 40 Dec 29 2017 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
lrwxrwxrwx 1 root root 40 Dec 29 2017 dbus-org.freedesktop.ModemManager1.service -> /lib/systemd/system/ModemManager.service
lrwxrwxrwx 1 root root 53 Dec 29 2017 dbus-org.freedesktop.nm-dispatcher.service -> /lib/systemd/system/NetworkManager-dispatcher.service
lrwxrwxrwx 1 root root 32 Dec 8 23:26 display-manager.service -> /lib/systemd/system/lxdm.service
lrwxrwxrwx 1 root root 9 Nov 9 12:39 epmd.service -> /dev/null
lrwxrwxrwx 1 root root 9 Nov 9 12:39 epmd.socket -> /dev/null
service file
[Unit]
[email protected]
[Service]
Type=simple
User=root
[Install]
i cant help you with services, but i can help you by pointing out that others can help you better if you present code, logfiles, yaml, etc. as a codeblock (as is mentioned at the top of every forum)
Sorry, I will edit now that is a discovery… I love it
I finally found the issue.
Just reporting for others: I installed AppDaemon in a virtual env and was not entering it before startup.
So added a line like this:
ExecStartPre=source yourpathtovirtualenv/bin/activate
fixed it
If you specify in the exec line the binary inside the venv, you do not need to activate the virtual environment separately, so this works
[Unit]
Description=appdaemon for homeassistant
After=network.target
[Service]
Type=simple
User=homeassistant
Environment=PYTHONPATH=/home/homeassistant/.homeassistant/python_modules:${PYTHONPATH}
ExecStart=/home/homeassistant/appdaemon_venv/bin/appdaemon -c /home/homeassistant/.homeassistant
SendSIGKILL=no
Restart=on-abnormal
[Install]
thanks! I will do like that
I just noticed I still have the PYTHONPATH set in that snippet. It isn’t needed to start up, unless you have your own python libraries you want to include.
