I have an idea I’d love some advice on. As I have about 12 airports in my house serving up audio in each room, I was thinking to try using this as the foundation of a room tracker, so that it would have a device tracker that would say which airport the device was connected to rather than just saying “home”…
Do you think such a thing would be possible? To read the name/mac/IP of the airport which is reporting connection to the tracked device and then put that as the state of the device tracker?
This would be pretty cool, because I could potentially have my music follow me around the house.
pls check my GitHub repo. without syslog server, we can use another python script to handle the syslog messages directly. This script is running on the host.
if u want to all-in-one in the docker container, maybe u can modify the docker image manually.
I’ve been working on trying to get this to run with hass.io as a local add-on.
Small steps so far, as I really don’t have much python or docker knowledge, but hey I’m trying. Fixed a few errors here and there, and so far I’ve managed to get the add-on to run using the airconn.py script, and I believe it is receiving the syslogs from the airport router, as I only see logs in the add-on once I connect or disconnect a device from the wi-fi, so it would appear to be triggering the script. The current traceback begins at either line 37 or 42, depending on whether i have connected or disconnected a device to the router.
File "/airconn.py", line 37, in <module>
post('http://127.0.0.1:8123/api/services/device_tracker/see',data=postData,headers=headers)
File "/usr/lib/python2.7/site-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python2.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python2.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python2.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python2.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='127.0.0.1', port=8123): Max retries exceeded with url: /api/services/device_tracker/see (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x764b9dd0>: Failed to establish a new connection: [Errno 111] Connection refused',))
It appears to be an issue connecting to the hass API.
I have tried setting "homeassistant_api": true in the add-on config.
Would anyone on the thread more knowledgable than me have any ideas as to where to begin with with fixing this? I’m not sure whether I need to be looking at the add-on docker environment, or if i need to open up additional ports. I.e. if it is the hass API refusing the connection, or if the add-on container itself isnt letting the request through.
I’d appreciate any pointers or info that might help me figure it out.
Hey, I am trying to set this up as well. I followed the guide on github as is.
I get this error: Platform error device_tracker.apple_airport - Integration ‘apple_airport’ not found.
I modified the configuration as suggested by Sevift.
The “netstat -tulpn | grep rsyslog” output is as expected.
Another error when testing from another device: echo ‘<54> <133>Feb 11 22:32:00 timecapsuleu pppoe: Disconnected.’ >/dev/udp/10.0.1.23/514
outputs: no such file or directory: /dev/udp/10.0.1.23/514
However, on same device, I don’t get any output.
MY DEVICES DOES SHOW UP on the known_devices.yaml file.
Any recommendations on how to start debugging this issue?
