APsystem - Solar monitoring
I tried today nod-red with node-red-contrib-solaredge-modbus
The solaredge node read the ECU-C values.
some calculation are wrong.
The source code for Solaredge is on github .
It can be modified for the ECU-C
Good news for everyone who owns a ECU-C.
sunspec Modbus can be activated. Modbus RTU and TCP works.
I managed to read out the values in Node-red.
You have to install the sunspec modebus tcp node.
The se_inverter.json file in the config_json Folder must be adapted.
Here are the register mapping.
https://certifications.sunspec.org/PICS/Altenergy_Power_System_Inc.___single_phase_MicroinverterAPpcs_11-12.xlsx
Have a nice day.
Today fixed and working fine!
JQM1961, How did you enable Modbus on the ECU-C. I don’t have that option on the web interface of the ECU-C.
Hi everyone,
I was wondering how people have enabled Modbus over IP and if possible to do as owner, instead of the installer.
On other matters, I was thinking to start a local version of the APsystems sensor. Basically, the same as the above but querryng the local MCU instead of the cloud. Would people be interested on that?
I love the work from @bgbraga & @synack, but I can see 2 benefits from this. First, my unit has consumed/import sensors as well as the connection to the panels so I could get a few extra data points there. Also, since the queries are local, data could be refreshed more freely than a cloud service. Bear in mind all measurements happen in 5min slots, so there’s no point on anything smaller than that.
To do this I was looking to do HTTP requests to the MCU such as ā€œhttp://<MCU_IP>/index.php/meter/old_meter_power_graph?date=2022-04-07ā€, however I’m unsure whether the same API is in all MCU’s. I only have MCU-C (less than 48h with it), so I’d appreciate if people can confirm it works on others.
So far I have the following entry-points:
  • Power by inverter data: http://<MCU_IP>/index.php/realtimedata/old_energy_graph?date=2022-04-08&period=weekly
  • Energy by inverter data: http://<MCU_IP>/index.php/realtimedata/old_energy_graph?date=2022-04-08&period=weekly
  • Power measured by sensors: http://<MCU_IP>/index.php/meter/old_meter_power_graph?2022-04-07
  • Energy measured by sensors: http://<MCU_IP>/index.php/meter/old_meter_energy_graph?date=2022-04-08&period=weekly
Can anyone confirm wether these work on others?
First, not me but skelgaard did the work, since the data comes only once an hour I want to take a closer look at this project:
Waiting for the ordered hardware.
Is that the old ECU’s? ECU-C seem to be refreshing all(panel info, total generated and meter information) at 5min intervals. I actually have the HW for it, it’s the same as any zigbee2mqtt but I don’t see what’s the advantage between this and what you have in the ECU. As far as I can tell this project also do 5min intervals.
ups, maybe misunderstanding :-), current i get my data from apsystems server and they reduce to 1 hour, therfore i like to switch to a differnent way, but… have a ECU-B
Have you tried GitHub - ksheumaker/homeassistant-apsystems_ecur: Home Assistant custom component for local querying of APSystems ECU-R Solar System
From what I see on the code, it looks like the most comprehensive integration, however only works for ECU-C & ECU-B. Hence I haven’t tested it. It relays on the magic messages from the ACU App but most people seem happy with it
Wow, great, many thanks, perfect integration!!! Have looked around several times but didnt noticed this. Works from 1. try with ECU B and YC600
Take note from this issue though: HA Release 2022.4 causes sensors to fail Ā· Issue #62 Ā· ksheumaker/homeassistant-apsystems_ecur Ā· GitHub
Just confirming this works with 7 pcs. DS3. Some inverters needed to be re-paired a few times to start working.
Does this help? → APSystems Wechselrichter mit Modbus auslesen und beschreiben. YC600, QS1 DS3 usw - Wechselrichter - Photovoltaikforum
