Aqara C1 Pet Feeder Onboard Scheduling Config
How did you get 8 times of feeding moments in your set? If I list more than 5 different times it gives an error and sends nothing. But if I limit it to 5 it sends it without a problem.
But our cat is not happy with only 5 times.
And does anyone know if you can display the schedule in your dashboard?
I don’t even use the built-in scheduler and simply let HA handle it for me. My bottomless stomach is happy. The bonus is if he’s sniffing the bowl we can just say “Siri, feed cat” and, presto, two more servings.
It’s a few years later, has there been any movement to get scheduling working via ZHA? I’d rather not switch everything over to zigbee2mqtt, but I’d also really like the ability to push a schedule to the thing and not depend on zigbee connectivity to keep the cat fed.
Same question. Just got my Aqara C1 today and connected via ZHA, no Aqara hub. I can set up automations, but is there any UI to set a schedule that will be saved direct to the device?
Same on acquiring a C1. According to the ZHA quirks, the answer seems to be ‘no’ there is no on board scheduling supported yet. I don’t know what I’m doing, but if it’s parsing a string and writing it back out, should be possible to compare the Zigbee2mqtt quirk and make similar.
