I have been using the no neutral version of the Aqara switch for over a year in a few rooms in my house with absolutely no issues.
The small current flowing through the circuit doesn’t give my downlights any problems. No flickering, no lights on at all unless the relay is active.
They don’t act as zigbee routers (maybe the neutral version does?)
Hi @apmillen do you know if in the case of the double no neutral switch, if only one of the switches is physically connected, the other one still sends the Zigbee signals when pressed?
I would like to get the double one, but only connect actually one for my ceiling lamp and use the other one for whatever I want
Yeah, I only have the double no neutral switches. They have 2 relays, one for each switch.
If you use the Xiaomi hub apparently you can use the switches in “decoupled mode” which stops them from controlling the relay.
I use deconz and that isn’t available. However I have one switch controlling the ceiling lights (wired in) and the other controlling the lamps which have ikea bulbs in (not wired in) and just use the on/off state of the switch in HA to determine whether to turn the bulbs on or off.
I’ve been looking all over for info on whether this would be possible. I’ve got three dual gang switches, one which will control a “dumb” light and the other a smart bulb and I was hoping I could wire the dumb one and leave the other side as a Zigbee controller. So the fact you’ve made it work gives me confidence! Thanks
The capacitor is installed in parallel with the bulb(s) and it is used as a load.
Or you could buy a bypass from other manufacturers like Fibaro, Shelly, TEM or any other.
I think I’m starting to understand how the aqara switch works. I’m curious then how it applies to smart bulbs. Aqara has a detached mode which only allows switching via zigbee. The smart bulb should be constantly powered anyway. Does it make sense to buy aqara switches with no neutral in this situation?
