On the edge like that there are so many variables that come into play. Accuracy of the voltmeter itself, the quality of the solder work, an MCU operating at the better end of it’s spec vs the worst end, how snug the battery fitting is, etc, etc.
Where are you getting your batteries from? I got mine from Aliexpress (mistake) and they drain significantly faster than the ones I got from my local supermarket. However the ones from the supermarket are significantly more expensive - I guess because they’re not counterfeit.
I have seen a single genuine CR2032 run a temperature sensor for over a year an still report 30%. Other times I’ve seen a temperature sensor report 1% battery and run for months.
Personally I buy name brand batteries from my local store. I’ve had good luck with Energizer batteries in my Tuya temp sensors. I’m sure those will work just as well with the Aqara sensors.
I received 12 new Aqara temperature sensors last weekend. I installed them, and have noticed that they all dropped to about 50% of their starting charge in the first 2 days. That being said, one I’ve had for months has sat all week at 33% (with a couple of times reporting at 36%). After dropping, they’ve stabilised at a new value. I believe the calculations for battery life are incorrect… so I’m ignoring them for now until they get really low… then I’ll look to replace batteries.
I got one of these 2 days ago. I had to rebuild my homeassistant, I couldnt get the device added. It seems completely dead… I ve swapped batteries etc, but the device is dead, no BLUE led blinking etc.
Is there something I can do other than try another battery?
The first time I added the device it worked like a charm. Strange.
I got mine around the same time as you. No problems with it so far.
I would make sure the battery is making good contact. Remove the battery cover. You should see a metal tab on one side of the battery. Pop the battery out and slightly bend that tab in. Be care not to break it. Pressing the button the LED should blink. Pressing and holding the button should reset the sensor then put into pairing mode blinking the LED rapidly.
I just got these Aqara temperature, humidity and pressure sensor and I am having the same battery indication issue here. I am glad to hear that it might just be a benign reporting issue, versus a flaw with the device. I will keep monitoring mine and update here.
