I have published an update to this blueprint today that should fix the errors you have experienced. Try updating (if you cannot update, then remove and reinstall).
Give it a try and give me an update if you have more problems.
Hi there, I can’t get this to work. The button actions are happening when I view the logbook, but the actions in the blueprint don’t occur. I’m not sure what to try, I have the WXKG11LM button.
I had the same problem, modified the blueprint and it seems to work now: Aqara Wireless Switch (single, double, hold, release) · GitHub.
^ It’s a new version that uses trigger.to_state.state if available (in addition to trigger.to_state.attributes.action).
Thanks, but I just imported the blueprint again, but the automation still won’t trigger. Oh well the Aqara Buttons All-In-One [Zigbee2MQTT] blueprint is working for me.
Yes, just add filter: key and space it out like the docs suggest for the current format. Don’t have to test anything.
This is the same as all entity and device selectors now all blueprints.
I use this Aquara button (WXKG11LM) with Zigbee2MQTT, and I created an automation who is triggered by the single action of this device, but seems the single action state is to short for fire the automation. So I’am not able to use this button. Have someone have this kind of problem?
