Yes, just add filter: key and space it out like the docs suggest for the current format. Don’t have to test anything.
This is the same as all entity and device selectors now all blueprints.
Fixed locally and tested, indeed the only change is filter:
I use this Aquara button (WXKG11LM) with Zigbee2MQTT, and I created an automation who is triggered by the single action of this device, but seems the single action state is to short for fire the automation. So I’am not able to use this button. Have someone have this kind of problem?
I think this blueprint is broken because ot the latest z2m update. Certain action are replaced by eventf if I understood it right.
See also other topics with remotes where the authors are making adjustments to their blueprint.
Indeed, needs updating. Enable legacy actions as a workaround.
Based on work done here I’ve tweaked the blueprint as follows.
blueprint:
name: Aqara Buttons All-In-One [Zigbee2MQTT]
description: 'All-In-One package for Aqara Switches.'
domain: automation
input:
mode:
description: https://www.home-assistant.io/docs/automation/modes/
default: parallel
selector:
select:
mode: dropdown
options:
- single
- restart
- queued
- parallel
multiple: false
custom_value: false
sort: false
zigbee_device:
name: Zigbee Device (Aqara Switch)
description: Select the correct Zigbee device to use.
selector:
device:
integration: mqtt
multiple: false
single_action:
description: Single click for devices with one button
default: []
selector:
action: {}
double_action:
description: Double click for devices with one button
default: []
selector:
action: {}
triple_action:
description: triple click for devices with one button
default: []
selector:
action: {}
quadruple_action:
default: []
selector:
action: {}
hold_action:
description: Hold action for devices with one button
default: []
selector:
action: {}
release_action:
description: Release action for devices with one button
default: []
selector:
action: {}
shake_action:
description: Shake action for devices with one button
default: []
selector:
action: {}
single_left_action:
name: Single Left Click
description: Left click for devices with multiple buttons
default: []
selector:
action: {}
double_left_action:
name: Double Left Click
description: Double left click for devices with multiple buttons
default: []
selector:
action: {}
triple_left_action:
name: triple Left Click
description: triple left click for devices with multiple buttons
default: []
selector:
action: {}
hold_left_action:
name: Hold Left Action
description: Hold left action for devices with multiple buttons
default: []
selector:
action: {}
release_left_action:
name: Release Left Action
description: Release left action for devices with multiple buttons
default: []
selector:
action: {}
single_center_action:
name: Single Center Click
description: Center click for devices with three buttons
default: []
selector:
action: {}
double_center_action:
name: Double Center Click
description: Double center click for devices with three buttons
default: []
selector:
action: {}
triple_center_action:
name: triple Center Click
description: triple center click for devices with three buttons
default: []
selector:
action: {}
hold_center_action:
name: Hold Center Action
description: Hold center action for devices with three buttons
default: []
selector:
action: {}
release_center_action:
name: Release Center Action
description: Release center action for devices with three buttons
default: []
selector:
action: {}
single_right_action:
name: Single Right Click
description: Right click for devices with multiple buttons
default: []
selector:
action: {}
double_right_action:
name: Double Right Click
description: Double right click for devices with multiple buttons
default: []
selector:
action: {}
triple_right_action:
name: triple Right Click
description: triple right click for devices with multiple buttons
default: []
selector:
action: {}
hold_right_action:
name: Hold Right Action
description: Hold right action for devices with multiple buttons
default: []
selector:
action: {}
release_right_action:
name: Release Right Action
description: Release right action for devices with multiple buttons
default: []
selector:
action: {}
single_both_action:
name: Single Both Click
description: Both click for devices with multiple buttons
default: []
selector:
action: {}
double_both_action:
name: Double Both Click
description: Double both click for devices with multiple buttons
default: []
selector:
action: {}
triple_both_action:
name: triple Both Click
description: triple both click for devices with multiple buttons
default: []
selector:
action: {}
hold_both_action:
name: Hold Both Action
description: Hold both action for devices with multiple buttons
default: []
selector:
action: {}
release_both_action:
name: Release Both Action
description: Release both action for devices with multiple buttons
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/aqara-buttons-all-in-one-zigbee2mqtt/268717
mode: !input mode
max_exceeded: silent
- platform: mqtt
topic: zigbee2mqtt/+/action
variables:
device_name: !input zigbee_device
expected_topic: zigbee2mqtt/{{ device_attr(device_name, 'name') }}/action
condition:
- condition: template
value_template: "{{ trigger.topic == expected_topic }}"
- variables:
command: "{{ trigger.payload }}"
- choose:
- conditions: '{{ command == ''single'' }}'
sequence: !input 'single_action'
- conditions: '{{ command == ''double'' }}'
sequence: !input 'double_action'
- conditions: '{{ command == ''triple'' }}'
sequence: !input 'triple_action'
- conditions: '{{ command == ''quadruple'' }}'
sequence: !input 'quadruple_action'
- conditions: '{{ command == ''hold'' }}'
sequence: !input 'hold_action'
- conditions: '{{ command == ''release'' }}'
sequence: !input 'release_action'
- conditions: '{{ command == ''shake'' }}'
sequence: !input 'shake_action'
- conditions: '{{ command == ''single_left'' }}'
sequence: !input 'single_left_action'
- conditions: '{{ command == ''double_left'' }}'
sequence: !input 'double_left_action'
- conditions: '{{ command == ''triple_left'' }}'
sequence: !input 'triple_left_action'
- conditions: '{{ command == ''hold_left'' }}'
sequence: !input 'hold_left_action'
- conditions: '{{ command == ''release_left'' }}'
sequence: !input 'release_left_action'
- conditions: '{{ command == ''single_center'' }}'
sequence: !input 'single_center_action'
- conditions: '{{ command == ''double_center'' }}'
sequence: !input 'double_center_action'
- conditions: '{{ command == ''triple_center'' }}'
sequence: !input 'triple_center_action'
- conditions: '{{ command == ''hold_center'' }}'
sequence: !input 'hold_center_action'
- conditions: '{{ command == ''release_center'' }}'
sequence: !input 'release_center_action'
- conditions: '{{ command == ''single_right'' }}'
sequence: !input 'single_right_action'
- conditions: '{{ command == ''double_right'' }}'
sequence: !input 'double_right_action'
- conditions: '{{ command == ''triple_right'' }}'
sequence: !input 'triple_right_action'
- conditions: '{{ command == ''hold_right'' }}'
sequence: !input 'hold_right_action'
- conditions: '{{ command == ''release_right'' }}'
sequence: !input 'release_right_action'
- conditions: '{{ command == ''single_both'' }}'
sequence: !input 'single_both_action'
- conditions: '{{ command == ''double_both'' }}'
sequence: !input 'double_both_action'
- conditions: '{{ command == ''triple_both'' }}'
sequence: !input 'triple_both_action'
- conditions: '{{ command == ''hold_both'' }}'
sequence: !input 'hold_both_action'
- conditions: '{{ command == ''release_both'' }}'
sequence: !input 'release_both_action'
Not sure if that helps until an official update come out.
Seems good to me:
This should let you directly import @nwootton changes for this Aqara device:
updated 12/01/2025, it is now using device specific mqtt device triggers
instead of triggering for any mqtt device action.
Works for me!! Thanks
Works, thanks.
WXKG11LM seems not working , in zigbee2mqtt i saw the status changing Single Double etc , but nothing in automation based on the new BP
Cleaner version of the blueprint (in respect to the previous one I posted), click above to import.
the previous blueprint should have worked, unless maybe you have a different zigbee2mqtt mqtt base topic which isn’t zigbee2mqtt.
Either way this doesn’t directly subscript an mqtt topic but uses the device mqtt trigger, so it might work.
hi ! many thanks for this ! it works now like a charm My 10 WXKG11LM are back in the game !
