Aquarium water quality TDS sensor
finally I gave up for TDS meter since as mentioned:
even if was powered by esp every half hour, pH meter readings were constantly distorted
In thread about pH sensor someone mentioned:
A TDS will alter the PH values without having an isolator if in the same liquid system
I agree. Didn’t check if TDS measured by another ESP will not distort pH readings.
