Great. I would need:
Scene Low Speed
switch 3 off
switch 2 off
switch 1 on
Scene Med Speed
switch 3 off
switch 1 off
switch 2 on
Scene fast speed
switch 1 off
switch 2 off
switch 3 on
Thank you for the work you did on this, itās been very helpful and a really straight forward copy and paste to get my esp8266 devices up and running on HASS.
In an attempt to reduce the wifi in my house and get more things hardwired I have been trying to modify your code to work with the ethernet shield W5100 but have not been very successful. Do you by any chance have any relays connected through ethernet and would you be so kind as to share that code with us?
Guys, you ought to save yourself the custom programming work and try the TASMOTA firmware for wemos D1 (primarily for sonoff but compatible with wemos). It uses MQTT messaging, as well as controls for relays, switches, buttons, sensors.
BTW, if you need to control mains operated device, I assume ceiling fan is, get yourself the sonoff product.
my apologies for the very late response, i was away on break and the mrs will not allow me to touch any keyboard while away on holiday.
I have not tried the direct fix connection so, i could not really share any experience on that. Hopefully someone from the community can chip in on this.
nonetheless, in my opinion, it should be very straight forward (i maybe wrong), all you will need to do:
replace the wifi connectivity routine, with a direct dhcp client session to secure an IP address for your ethernet shieldā¦
@olegunnar: Thanks for the update on erickjoaquin“s project. I“ve used it on an ESP8266 controller and it is working very well.
Unfortuantly when the ESP is powered on it publish a wifi-network you can connect to. You cannot do anything on the network but maybe if you have better IT-skills than me you could āhackā into the entire home-network. So my question is how do I disable the ESP to publish a wifi-network?
That discussion has fueled in me the desire to realize a kind of gateway for my systems!
Foreword: For about a week I entered the world of HA and I purchased a Raspberry Pi Zero W which the Chomecast audio driver and, through Broadlink RM Pro, both the air conditioner and the iRobot Roomba as well as have set the temperature detection always through RM Pro.
That being said, I have the motors and light switches of the Nice SPA and are piloted by radio-control knobs, so I would like to realize a kind of spartan gateway using this project by piloting relays directly with the keys of a radio control. Doable?
Sorry for my bad English! : P
Thanks for posting this. Iām just starting out with HA and this setup was perfect for my sonās chameleon enclosure. Is there an easy way to add or include a DHT11 or 22 to the Arduino Sketch? I have tried to merge the sketches but Iām not sure where to add certain parts.
I have not done the merging in the past, but it should be straight forward.
With my Relay sketch post (or best using @olegunnarās code , you can easily identify the block of codes belonging to which purpose (function) (OTA, RELAY, WIFI).
Analyse the sketch used by the project below to add in all the DHT related codes (init, setup, loop) to the Relay sketch. Note that you will not need to replicate the MQTT initialization part as it is already created in the original code above. (e.g⦠you will need to introduce the DHT topic as per below approach.)
It should be do-able. there are lots of projects shared by the HA community on how to do bits and pieces of what you would like to achieve. Use the forum search function to look for projects similar to yours. Start with Broadlink RM.
The search function has been my best friend on this project. Thanks for the info, it is very helpful. If I get it working I will share it with the group.
Thanks again for the help.
