Are stateless Matter/Thread buttons supported? Tuo button only shows battery state
I have integrated a TUO Smart Button directly into Home Assistant as a Matter device with the HA app and scanning the Matter code. Now I am facing the problem described above.
Then I added another TUO Smart Button to Apple HomeKit via Matter and I then see the three states to choose from (short, double and long press) available in HomeKit.
Then I integrated the TUO Smart Button integrated before in Home Assistant into Apple HomeKit using the Matter pairing code. All three events are also available to me for this device in HomeKit.
So, there is definitely an error in the Home Assistant Matter integration, which should be fixed soon. Small manufacturers like TUO rely on Matter and can quickly go out of business due to such problems.
I have just bought one of these Tuo (now Arre) buttons and find that in HA I can get single press and long hold events. But the double press doesn’t seem to register an event at all, not even the initial press of the pair. This makes me think HA is receiving the double press as a discrete event and “eating” it rather than passing it through to the log or event handlers.
Which type of trigger did you select to get that form?
