Argon One Active Cooling and Active Linear Cooling Addon
Today I got my new Argon One M.2 Case (with SSD).
I’m struggling to get things working with the fan. It has been working for I few moments, but after a few reboots it quit and I can’t get it working again. Not even after a fresh install.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: ArgonOne Active Cooling
 Actively keeping your Argon One cool.
 Add-on version: 29c
 You are running the latest version of this add-on.
 System: Home Assistant OS 9.4  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2023.1.0
 Home Assistant Supervisor: 2022.12.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Detecting Layout of i2c, we expect to see "1a" here.
checking i2c port 0 at /dev/i2c-0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
not found on /dev/i2c-0
checking i2c port 1 at /dev/i2c-1
00:                         08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
not found on /dev/i2c-1
checking i2c port 10 at /dev/i2c-10
not found on /dev/i2c-10
checking i2c port 22 at /dev/i2c-22
not found on /dev/i2c-22
I2C Port 255
Argon One was not detected on i2c. Argon One will show a 1a on the i2c bus above. This add-on will not control temperature without a connection to Argon One.
Current Temperature 38 °C
2023-01-05_01:19:42: 38C - Level 1 - Fan 0% (OFF)
Error: Could not open file `/dev/i2c-255' or `/dev/i2c/255': No such file or directory
Failed 98: i2cset -y "${port}" "0x01a" "${fanPercentHex}"
Safe Mode Activated!
Failed 209: return ${returnValue}
I think 1a is at /dev/i2c-1, but it isn’t reconized.
I hope someone can help me.
Regards,
Frank
Looks like something’s wrong with your I2C -1. Every single port is available for communication. That’s not right. You probably have a hardware error of some sort
Hmmm, how can I check it? I’ve already disconnected and connected my board to my Argon.
I honestly don’t know. I’ve never seen that before. You might want to contact argon support.
I have a Raspberry Pi 4 (running Home Assistant OS) with the Argon One Case. I use an SSD via USB and no Micro-SD-Card at all.
For months, the linear cooling addon worked fine for me: I never heard the fan, since the passive cooling was obviously enough to keep the Pi’s temperature below 50 Degrees Celsius.
But now I changed the jumper position to “always on”. The reason are occasional random Raspberry blackouts. I guess the blackouts happen because the regular Raspberry power cable does not provide enough power to the SSD via USB. Until I get an external power source for the SSD, I hope to circumvent the blackouts of the Raspberry with the “always on”-mode of the jumper.
When I am not at home and my Raspberry is not reachable anymore, I can switch a wifi plug off and on again and therefore reboot the Raspberry Pi.
But now, the fan runs always with a 100%, which is very loud.
Here are the logs.
[fix-attrs.d] done.
 Add-on: ArgonOne Active Linear Cooling
 Add-on version: 29c
 Home Assistant Core: 2023.1.1
[cont-init.d] done.
[services.d] done.
/run.sh: line 111: thePort: unbound variable
[cmd] /run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
So I thought I needed to install an run the HassOS I2C Configurator again. But those were the logs:
crw--w----    1 root     tty         4,  29 Jun  2  2022 tty29
crw--w----    1 root     tty         4,   3 Jun  2  2022 tty3
crw--w----    1 root     tty         4,  30 Jun  2  2022 tty30
crw--w----    1 root     tty         4,  31 Jun  2  2022 tty31
crw--w----    1 root     tty         4,  32 Jun  2  2022 tty32
crw--w----    1 root     tty         4,  33 Jun  2  2022 tty33
crw--w----    1 root     tty         4,  34 Jun  2  2022 tty34
crw--w----    1 root     tty         4,  35 Jun  2  2022 tty35
crw--w----    1 root     tty         4,  36 Jun  2  2022 tty36
crw--w----    1 root     tty         4,  37 Jun  2  2022 tty37
crw--w----    1 root     tty         4,  38 Jun  2  2022 tty38
crw--w----    1 root     tty         4,  39 Jun  2  2022 tty39
crw--w----    1 root     tty         4,   4 Jun  2  2022 tty4
crw--w----    1 root     tty         4,  40 Jun  2  2022 tty40
crw--w----    1 root     tty         4,  41 Jun  2  2022 tty41
crw--w----    1 root     tty         4,  42 Jun  2  2022 tty42
crw--w----    1 root     tty         4,  43 Jun  2  2022 tty43
crw--w----    1 root     tty         4,  44 Jun  2  2022 tty44
crw--w----    1 root     tty         4,  45 Jun  2  2022 tty45
crw--w----    1 root     tty         4,  46 Jun  2  2022 tty46
crw--w----    1 root     tty         4,  47 Jun  2  2022 tty47
crw--w----    1 root     tty         4,  48 Jun  2  2022 tty48
crw--w----    1 root     tty         4,  49 Jun  2  2022 tty49
crw--w----    1 root     tty         4,   5 Jun  2  2022 tty5
crw--w----    1 root     tty         4,  50 Jun  2  2022 tty50
crw--w----    1 root     tty         4,  51 Jun  2  2022 tty51
crw--w----    1 root     tty         4,  52 Jun  2  2022 tty52
crw--w----    1 root     tty         4,  53 Jun  2  2022 tty53
crw--w----    1 root     tty         4,  54 Jun  2  2022 tty54
crw--w----    1 root     tty         4,  55 Jun  2  2022 tty55
crw--w----    1 root     tty         4,  56 Jun  2  2022 tty56
crw--w----    1 root     tty         4,  57 Jun  2  2022 tty57
crw--w----    1 root     tty         4,  58 Jun  2  2022 tty58
crw--w----    1 root     tty         4,  59 Jun  2  2022 tty59
crw--w----    1 root     tty         4,   6 Jun  2  2022 tty6
crw--w----    1 root     tty         4,  60 Jun  2  2022 tty60
crw--w----    1 root     tty         4,  61 Jun  2  2022 tty61
crw--w----    1 root     tty         4,  62 Jun  2  2022 tty62
crw--w----    1 root     tty         4,  63 Jun  2  2022 tty63
crw--w----    1 root     tty         4,   7 Jun  2  2022 tty7
crw--w----    1 root     tty         4,   8 Jun  2  2022 tty8
crw--w----    1 root     tty         4,   9 Jun  2  2022 tty9
crw-rw----    1 root     audio     204,  64 Jun  2  2022 ttyAMA0
crw-------    1 root     root        5,   3 Jun  2  2022 ttyprintk
crw-------    1 root     root       10, 239 Jun  2  2022 uhid
crw-------    1 root     root       10, 223 Jun  2  2022 uinput
crw-rw-rw-    1 root     root        1,   9 Jun  2  2022 urandom
drwxr-xr-x    3 root     root            60 Jun  2  2022 v4l
crw-------    1 root     root      245,   0 Jun  2  2022 vc-mem
crw-------    1 root     root      239,   0 Jun  2  2022 vchiq
crw-------    1 root     root       10, 125 Jun  2  2022 vcio
crw-rw----    1 root     tty         7,   0 Jun  2  2022 vcs
crw-rw----    1 root     tty         7,   1 Jun  2  2022 vcs1
crw-rw----    1 root     tty         7,   2 Jun  2  2022 vcs2
crw-rw----    1 root     tty         7,   3 Jun  2  2022 vcs3
crw-rw----    1 root     tty         7,   4 Jun  2  2022 vcs4
crw-rw----    1 root     tty         7,   5 Jun  2  2022 vcs5
crw-rw----    1 root     tty         7,   6 Jun  2  2022 vcs6
crw-rw----    1 root     tty         7, 128 Jun  2  2022 vcsa
crw-rw----    1 root     tty         7, 129 Jun  2  2022 vcsa1
crw-rw----    1 root     tty         7, 130 Jun  2  2022 vcsa2
crw-rw----    1 root     tty         7, 131 Jun  2  2022 vcsa3
crw-rw----    1 root     tty         7, 132 Jun  2  2022 vcsa4
crw-rw----    1 root     tty         7, 133 Jun  2  2022 vcsa5
crw-rw----    1 root     tty         7, 134 Jun  2  2022 vcsa6
crw-rw-rw-    1 root     root       10, 122 Jun  2  2022 vcsm-cma
crw-rw----    1 root     tty         7,  64 Jun  2  2022 vcsu
crw-rw----    1 root     tty         7,  65 Jun  2  2022 vcsu1
crw-rw----    1 root     tty         7,  66 Jun  2  2022 vcsu2
crw-rw----    1 root     tty         7,  67 Jun  2  2022 vcsu3
crw-rw----    1 root     tty         7,  68 Jun  2  2022 vcsu4
crw-rw----    1 root     tty         7,  69 Jun  2  2022 vcsu5
crw-rw----    1 root     tty         7,  70 Jun  2  2022 vcsu6
crw-------    1 root     root       10, 127 Jun  2  2022 vga_arbiter
crw-------    1 root     root       10, 137 Jun  2  2022 vhci
crw-rw-rw-    1 root     111        10, 238 Jun  2  2022 vhost-net
crw-rw-rw-    1 root     111        10, 241 Jun  2  2022 vhost-vsock
crw-rw----    1 root     netdev     81,   2 Jun  2  2022 video10
crw-rw----    1 root     netdev     81,   6 Jun  2  2022 video11
crw-rw----    1 root     netdev     81,   8 Jun  2  2022 video12
crw-rw----    1 root     netdev     81,   1 Jun  2  2022 video13
crw-rw----    1 root     netdev     81,   3 Jun  2  2022 video14
crw-rw----    1 root     netdev     81,   4 Jun  2  2022 video15
crw-rw----    1 root     netdev     81,   5 Jun  2  2022 video16
crw-rw----    1 root     netdev     81,  12 Jun  2  2022 video18
crw-rw----    1 root     netdev     81,   0 Jun  2  2022 video19
crw-rw----    1 root     netdev     81,   7 Jun  2  2022 video20
crw-rw----    1 root     netdev     81,   9 Jun  2  2022 video21
crw-rw----    1 root     netdev     81,  10 Jun  2  2022 video22
crw-rw----    1 root     netdev     81,  11 Jun  2  2022 video23
crw-rw----    1 root     netdev     81,  13 Jun  2  2022 video31
crw-------    1 root     root       10, 130 Jun  2  2022 watchdog
crw-------    1 root     root      247,   0 Jun  2  2022 watchdog0
crw-rw-rw-    1 root     root        1,   5 Jun  2  2022 zero
brw-rw----    1 root     disk      254,   0 Jun  2  2022 zram0
brw-rw----    1 root     disk      254,   1 Jun  2  2022 zram1
brw-rw----    1 root     disk      254,   2 Jun  2  2022 zram2
/dev/i2c-1
/dev/i2c-0 /dev/i2c-1 /dev/i2c-10 /dev/i2c-22
Found i2c access!  Nothing to do!  You can remove this add-on.
So, is there really nothing to do? How can I get the addon to work again and setting the fan speed?
Looks like you have a problem with the device. It does not appear to be present on the I2C bus. This may be a hardware failure, or it may be something disconnected.
Thank you for your quick response! So does this mean my Argon One Case is broken? Or my Raspberry Pi?
Could it help to dismantle the case and assemble it again?
I2C is a simple two wire protocol. There’s a clock line, a data line, and ground. It appears the chip has I2C enabled, so the system on a chip itself has I2C working. The culprit would probably be a disconnected line somewhere. I’m not sure how the argon one routes, but you might try disassembling, disconnecting, cleaning, inspecting, and then reassembling. Reassembling. It’s been a very long time since I’ve had to disassemble my argon one, so I don’t really remember much about it. I can tell you that software wise, everything appears to be working properly.
Thank you! I will try! I think a have the manual somewhere, so cleaning should be possible.
Hi.
I have the same problem since the last update?
Add-on version: 29c
Home Assistant Core: 2023.1.2
Regards
What problem? Disconnected line like the person above you?
Yes.
HassOS I2C Configurator has the version 0.13a
Probably a problem with the I²C configurator?
In the overview it says, that the Add-On is stopped:
grafik
But inside the Add-On it is green and running?
Regards
I don’t know what caused the error, but it also made me play with the I²C configurator.
There I might have set the option “Start on boot” by mistake. Is it probably not allowed?
After I restarted the configurator and removed the “Start on boot” flag, then I did a hardware cycle (Power down for some time). After that the system ran again.
Sorry for the inconvenience. Unfortunately I do not know what caused the problem, however I have found a workaround :+1:
Hi, I have an issue here with the Argon One cooling.
Last week I got the addon installed after enabling I2C and it ran really well - for some days.
Yesterday, after a reboot, the cooling isn’t working anymore…?
As far as I understand the log I2C has been found, but somehow Argon One is not found on it. Could somebody support me to get it back running?
[fix-attrs.d] done.
 Add-on version: 29c
[cont-init.d] done.
[services.d] done.
I2C Port 255
Current Temperature 47 °C
2023-01-12_19:39:24: 47C - Level 3 - Fan 66% (Medium)
Thanks for this useful add-on to my brand-new ArgonOne V2 with RPi 4B!
Just a heads up though, I did have some issues with the Argon One Active Linear Cooling add-on not working initially with the add-on’s log showing “Ooops! Something went wrong” related to not finding i2C correctly, despite double-rebooting after enabling the i2C (using the HASSOS I2C configurator add-on) and after verifying i2c was enabled by identifying the appropriate files on my Rpi at /Dev/i2c*. This problem seems similar to multiple other recent posters: V413n10, Frank_Howell, Pittermaennchen, 011V32.
I did a restart of the HAOS after installing your add-on which did not fix the problem. However, after I did a hard reboot, the add-on then worked. Not sure if that really fixed the problem, but just wanted to provide the feedback.
Thanks again.
It seems to be a common thing. I’m not sure how better to communicate the plug must be pulled or hardware restart to get i2c working. It places files that are only worked with during hardware power on.
Does anyone know how to fully shutdown the Argon after shutdown via HA? Or at least the fan?
The fan and the red led stay on, until I hold the power button for 3s.
Maybe use ArgonOne Active Linear Cooling to turn off the fan when receiving event: shutdown?
No. This addon has no external API. You could use a command like docker exec <container-name> i2c-set /dev/i2c-0 1a 0 and fire it from some script which is triggered by a button in HA. I dont know for sure though. It might require supervisor. Its outside the scope of this addon. This addon regulates temperature only. You can move the temp up so it never triggers.
I am having the same problem.
"Ooops! Something went wrong” related to not finding i2C correctly
I have corrected the i2C, with several Host Reboots.
Right now I am installing the Argon add on and trying to reinstall to see if it works.
I am very very new to HA though.
This is my first post too :slight_smile:
