I tried the “Linear” version, removing everything and reinstalling, unplugging dozens of times and then, it worked last time out of sympathy … but, after upgrading HA to ver. 2023.8 no longer worked; I’ve done the tedious shutdown and restart many times but it doesn’t work.
If there’s anything I can do to help you, give me basic instructions.
Are you running supervisor channel beta?
No Beta release and no Supervisor Beta
I have the same issue. sensor is gone.
I’m having the same issue after installing version 30… I was once able to get the sensor back after several restarts of the addon but seems i cannot repro it again.
It’s a work in progress currently. The v30 series is going to contain the fixes. I’m working through a few issues. The end result will be the app is going to be even more efficient than before. You can see progress on the GitHub issue.
Installed the 30a version and it seems to be working again…
Indeed. 30a fixed the missing fan entity issue. Thanks
Version 30a installed: for the first time it works!!
Thank you very much
I just bought an Argon One M.2 case for my Raspberry 4 that I was using with an external SSD drive and a passive cooling case.
I installed ArgonOne Active Linear Cooling add-on and I had the “Cannot find I2C port. You must enable I2C for this add-on to operate properly” message in the log.
I installed HassOS I2C Configurator add-on, and the error message disappeared from Argon One add-on but when I now start it, I get that in the logbook and the add-on stops working.
I tried to uninstall it, re-install it, and tried different things I read here but it’s not working and I always get the same errors.
It seems it cannot find the I2C port.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: ArgonOne Active Linear Cooling
Actively keeping your Argon One cool.
Add-on version: 30a
You are running the latest version of this add-on.
System: Home Assistant OS 10.4 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.8.2
Home Assistant Supervisor: 2023.08.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Detecting Layout of i2c, we expect to see "1a" here.
ls: /dev/i2c-*: No such file or directory
[cmd] /run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.```
EDIT:
How can I enable it?
I found out how to enable it and it’s now working!
Hello, what did I do wrong?
[fix-attrs.d] done.
curl: (7) Couldn't connect to server
[23:20:09] ERROR: Something went wrong contacting the API
[cont-init.d] done.
[services.d] done.
checking i2c port 1 at /dev/i2c-1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- 1a -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
found at /dev/i2c-1
I2C Port 1
Settings initialized. Argon One Detected. Beginning monitor..
Current Temperature 38 °C
2023-08-28_23:20:12: 38C - Level 2 - Fan 33% (Low)
/run.sh: socket: Permission denied
Failed 79: exec 3<> /dev/tcp/hassio/80
Safe Mode Activated!
Failed 80: echo -ne "POST /homeassistant/api/states/sensor.argon_one_addon_fan_speed HTTP/1.1\r\n" 1>&3
Failed 81: echo -ne "Connection: close\r\n" 1>&3
Failed 82: echo -ne "Authorization: Bearer ${SUPERVISOR_TOKEN}\r\n" 1>&3
Failed 83: echo -ne "Content-Length: $(echo -ne "${reqBody}" | wc -c)\r\n" 1>&3
Failed 84: echo -ne "\r\n" 1>&3
Failed 85: echo -ne "${reqBody}" 1>&3
Failed 86: timeout=5
/run.sh: line 79: /dev/tcp/hassio/80: Permission denied
/run.sh: line 80: 3: Bad file descriptor
/run.sh: line 81: 3: Bad file descriptor
/run.sh: line 82: 3: Bad file descriptor
/run.sh: line 83: 3: Bad file descriptor
/run.sh: line 84: 3: Bad file descriptor
/run.sh: line 85: 3: Bad file descriptor
/run.sh: line 55: 3: Bad file descriptor
I’m not sure what you did here. I don’t know what would cause that. Looks like your network is locked down somehow. That’s not expected on HAOS.
Could this be the problem? Shouldn’t save mode be deactivated?
Hello, Sir,
I am so interested in your argon one m2 and I do not know if it work on home assistant OS on raspberry pi.
I already installed but it doesn’t work and it turn off and every time I have to hit start.
May I ask you any tips or help
Hi Adam and maybe @ TheHolyRoger
I’ve been using the fork from TheHolyRoger since about May of 22 posted on this one. We got a script going I believe for temp scraping privately. Memory fade with time
I was just looking and I no longer have a temperature of fan sensor or temp. States page confirms.
I look at the logs for the Active Cooling addon and it seems fine.
[fix-attrs.d] done.
Add-on: ArgonOne - Debian GNU/Linux 11 (bullseye)
Add-on version: 28.0
System: Home Assistant OS 10.5 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.8.4
[cont-init.d] done.
[services.d] done.
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Current Temperature 118 °F
2023-09-01_18:38:58: 118F - Level 3 - Fan 3% (Quiet Medium)
Current Temperature 116 °F
Do you have any ideas? I’ve scrolled thru posts and only found a post from Nettuno69 on Aug 2, 2023 that seems similar to my case.
Did something that change that I wasn’t aware of?
Is Adams working better than HolyRogers? Thought I saw that Adam tried to merge the two?
Many thanks… rock on!
I had forgotten about that. Looks like he hasn’t updated for a while. Might be a good idea to switch back. You have a few choices, I prefer linear personally.
good to know thank you Adam for your response… Will give yours a try again, much thanks
