Ariela - Home Assistant Android Client
Hello all,
Application can now be found in PlayStore:
Download: https://play.google.com/store/apps/details?id=com.surodev.ariela
Ionut
Hi, just trying this now and it crashed when searching for WiFi and now crashes every time I open it?
I’m in the latest release of Android P on a Google Pixel if that helps.
Thank you for reporting this. I will investigate the issue.
Is it possible to connect using HTTPS and how are invalid certificates handled?
It will be available on next release.
Coedy: the issue you reported should be now fixed. Please update the app from the play store and let me know how it goes.
I can now discover my instance but failed at the login, think it’s because I did a fresh install and the new auth system has left the normal http field commented out. I’ll add it back in tonight.
But the crash is fixed! Thanks! :grin:
is there anyway to give several home networks instead of 1?
and is there a way to change those settings after you did install?
Coedy: i am glad to hear the crash dissapear
ReneTodo: Can you explain the use case you are thinking about?
Ionut
I use Home Assistant locally (no https no duckdns Nada of that) and with it Ariela, once configured works great.
when I go out of my WiFi (simply out of the house) Ariela (including widget) of course stop working as expected.
Problem is when I go back home /WiFi all widget still do not work back, and I need to reconfigure Ariela…
i got 7 different SSIDs in my home.
right now i can only be connected to home in a small part of my house.
so my problem is that in the other parts of my house i cant connect locally.
and i dont have an outside url because i use a VPN to reach HA from the outside.
Klagio: i will investigate the issue
ReneTode: i will investigate for a solution for the issue you mention
Ionut
ReneTode: I was thinking: use configure external function. Enter the IP address of the server. Using this, whenever you are on other wifi network it should connect properly.
Klagio: can you tell me exact steps to reproduce the issue? Also, if i will send a debug version of the app will you want to test it?
Thank you,
Ionut
Please let us know when the next release is out for https
it should be a workable solution, so ill try it.
a few things i noticed.
  1. i get all groups as tab, except the ones i did set as tab in HA. I think there is a mixup there.
  2. the widgets loose connection quite fast.
  3. the characters for the widgets are so bghi can only use 1x1 when i have less then 4 characters
bachoo786: in about 1 week the https support should be available
ReneTode: thanks for reporting the issues i will investigate
Ionut
OT, why don’t you use same SSID for all different router/extenders?
What is the talk about https, I’m using it with https.
But it ask for home wifi on startup, for location services ? But it doesn’t seem like I’m getting a device_tracker, is it not implemented yet ?
to be able to grant access to network based on location.
guests can get network access on certain places but not on other places.
yrune: the location is only used to retrieve wifi networks for now, but i like your idea of adding a device tracker in the future.
Ionut
device tracker and notifications would be my primary reason to get app. Those features can be a hassle to setup with other solutions. So imo it would make the app more valuable. And of course widgets, but that’s already there.
IMO you should not put a lot of work and effort into UI, with lovelace there is already a brilliant UI.
