Seems the last update changed some things. After the update I started to get errors and aarlo would not load. Here is my log, and thank you for all your hard work.
Error during setup of component aarlo
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File “/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py”, line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/usr/local/lib/python3.7/socket.py”, line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 343, in _make_request
self._validate_conn(conn)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 839, in _validate_conn
conn.connect()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 301, in connect
conn = self._new_conn()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 168, in _new_conn
self, “Failed to establish a new connection: %s” % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f3e92aa81d0>: Failed to establish a new connection: [Errno -3] Try again
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 399, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘arlo.netgear.com’, port=443): Max retries exceeded with url: /hmsweb/login/v2 (Caused by NewConnectionError(’<urllib3.connection.VerifiedHTTPSConnection object at 0x7f3e92aa81d0>: Failed to establish a new connection: [Errno -3] Try again’))
File “/config/custom_components/aarlo/pyaarlo/backend.py”, line 61, in _request
r = self._session.post( url,json=params,headers=headers,timeout=timeout )
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 581, in post
return self.request(‘POST’, url, data=data, json=json, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘arlo.netgear.com’, port=443): Max retries exceeded with url: /hmsweb/login/v2 (Caused by NewConnectionError(’<urllib3.connection.VerifiedHTTPSConnection object at 0x7f3e92aa81d0>: Failed to establish a new connection: [Errno -3] Try again’))
File “/usr/local/lib/python3.7/site-packages/homeassistant/setup.py”, line 156, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/config/custom_components/aarlo/init.py”, line 104, in setup
user_agent=user_agent )
File “/config/custom_components/aarlo/pyaarlo/init.py”, line 50, in init
request_timeout=request_timeout,stream_timeout=stream_timeout )
File “/config/custom_components/aarlo/pyaarlo/backend.py”, line 40, in init
self._connected = self.login( username,password )
File “/config/custom_components/aarlo/pyaarlo/backend.py”, line 280, in login
body = self.post( LOGIN_URL, { ‘email’:self.username,‘password’:self.password } )
File “/config/custom_components/aarlo/pyaarlo/backend.py”, line 325, in post
return self._request( url,‘POST’,params,headers,False,raw,timeout )
File “/config/custom_components/aarlo/pyaarlo/backend.py”, line 65, in _request
self._ev_stream.resp.close()
AttributeError: ‘ArloBackEnd’ object has no attribute ‘_ev_stream’
