I get some connection errors sometimes when I open hass UI, with the camera pictures not loading at first. The camera pictures always get displayed after a delay after what I assume is a retry to connect. They appear at random when I open the UI, sometimes no error and camera pictures at first load.
Do any of you get the same error?
2017-06-25 09:29:28 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 386, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 382, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.4/http/client.py", line 1172, in getresponse
response.begin()
File "/usr/lib/python3.4/http/client.py", line 351, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.4/http/client.py", line 313, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/lib/python3.4/socket.py", line 371, in readinto
return self._sock.recv_into(b)
File "/usr/lib/python3.4/ssl.py", line 745, in recv_into
return self.read(nbytes, buffer)
File "/usr/lib/python3.4/ssl.py", line 617, in read
v = self._sslobj.read(len, buffer)
ConnectionResetError: [Errno 104] Connection reset by peer
File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 438, in send
timeout=timeout
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/packages/six.py", line 685, in reraise
raise value.with_traceback(tb)
chunked=chunked)
response.begin()
requests.packages.urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
File "/home/homeassistant/.homeassistant/deps/aiohttp/web_protocol.py", line 421, in start
resp = yield from self._request_handler(request)
File "/home/homeassistant/.homeassistant/deps/aiohttp/web.py", line 303, in _handle
resp = yield from handler(request)
File "/usr/lib/python3.4/asyncio/coroutines.py", line 143, in coro
res = yield from res
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/ban.py", line 58, in ban_middleware_handler
return (yield from handler(request))
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/__init__.py", line 424, in handle
result = yield from result
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/camera/__init__.py", line 249, in get
response = yield from self.handle(request, camera)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/camera/__init__.py", line 269, in handle
image = yield from camera.async_camera_image()
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/camera/arlo.py", line 60, in camera_image
return self._camera.last_image
File "/srv/homeassistant/lib/python3.4/site-packages/pyarlo/camera.py", line 88, in last_image
self.update()
File "/srv/homeassistant/lib/python3.4/site-packages/pyarlo/camera.py", line 158, in update
self._attrs = self._session.refresh_attributes(self.name)
File "/srv/homeassistant/lib/python3.4/site-packages/pyarlo/__init__.py", line 195, in refresh_attributes
data = self.query(url).get('data')
File "/srv/homeassistant/lib/python3.4/site-packages/pyarlo/__init__.py", line 132, in query
req = self.session.get(url, headers=headers)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 531, in get
return self.request('GET', url, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 518, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 639, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 488, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
