As of 2025.4 Error Talking to OpenAI
Its a compound problem. The client isn’t sending something the server needs to setup the conversation. So the server doesn’t respoyin kind unfwwe just haven’t figured out what that thing is yet.
Im pretty sure it’s in the integration as the session is getting created. If the experiment @mirbusak does yields fruit I’d suggest opening a github issue with that information. They’ll probably be able to figure out what’s going on with what you’ve collected so far.
I’m not using the recommended model settings, I already have that turned off and I’ve tried changing the models, still the same result. I’m giving up and will settle for the extended open AI for now, even though it’s a lot slower.
Would you at least open a git ticket? Becowhat I think you’re hitting is a bug. And without people reporting it it won’t get fixed.
I enabled another model, the exact one the log message referred to, and still the same result, I also tried gpt 3.5 turbo, the same thing,
my allowed models:
while gpt-4o-mini still has a shared subgroup, see screen
Yep there’s something about your config I’d love to know what…
Open that ticket
Now I don’t know exactly what you want from me? :slight_smile:
I opened the link, but what about it, I don’t speak English and I translate everything and that’s a big problem. :slight_smile:
Use your own language, describe the issue you’re having. Run it thrkoa translator and put it in a new issue there.
I think you have found a legit bug. And if it is ever going to be fixed. That’s how it happens.
You can opt not to but they don’t fix issues people do not report.
Here, i created an issue: OpenAi Conversation doesn't work anymore (Unexpected Error during Intent Recognition) · Issue #142424 · home-assistant/core · GitHub
btw. i got the same logs
Thanks Dennis I’m not able to get mine to do it… If they need comparative logs lmk.
Since yesterday afternoon, chatgpt has been working by itself again. So it looks like there was a problem, probably on the open AI side.
Can’t say that for my system…
Mysterious stuff. Had to allow gpt-4o-mini-2024-07-18. Take a look at the Issue, to see how you can change it. Fixed it for me.
