10der
(Oleg Denisenko)
April 4, 2024, 4:09pm
1
Hi!
For example, we have a simple automation.
Sunset - light on
Sunrise - light off
Today sunset at 7:15PM, but at 7:00PM - power outage.
For example, power restored at 9pm.
My question is: how to solve the issue for restoring missed event at 7:15pm?
The same issue with sunrise event as well.
NB: checking for status “is on” + time period every N min is ugly. IMHO.
Thank you!
WBR,
O.
home assistant fires this event when it’s restarted. you can trigger off of that instead of checking every minute. you’d still have to check the expected state tho.
- platform: homeassistant
event: start
10der
(Oleg Denisenko)
April 4, 2024, 4:49pm
4
HASS on the UPS. =) It doesn’t care =) It can work above 10h
10der
(Oleg Denisenko)
April 4, 2024, 5:03pm
5
it’s OK. Thank you Taras.
but. If I have for example 2 lights.* 3 switch.* I should create groups entity that represents multiple entities of the same type and handle lights and switch together via and
is_state('light.exterior', 'on') and is_state('switch.exterior', 'on')
123
(Taras)
April 4, 2024, 5:54pm
6
If you want, you can do it like this:
alias: 'Scheduled Exterior'
- platform: numeric_state
entity_id: sun.sun
attribute: elevation
below: 1.8
entity_id: sun.sun
above: -3.1
event: start
- variables:
e: "{{ state_attr('sun.sun', 'elevation') | float }}"
entities:
- light.one
- light.two
- switch.one
- switch.two
- switch.three
entities_on: >
{{ expand(entities) | selectattr('state', 'eq', 'on')
| map(attribute='entity_id') | list }}
entities_off: >
{{ expand(entities) | selectattr('state', 'eq', 'off')
- choose:
- conditions:
- "{{ e <= 1.8 }}"
- "{{ entities_off | count > 0 }}"
- service: homeassistant.turn_on
entity_id: "{{ entities_off }}"
- conditions:
- "{{ e >= -3.1 }}"
- "{{ entities_on | count > 0 }}"
- service: homeassistant.turn_off
entity_id: "{{ entities_on }}"
default: []
EDIT
Correction. Added missing |
to templates for entities_on
and entities_off
10der
(Oleg Denisenko)
April 4, 2024, 6:20pm
7
OMG! yep, Sir. I forgot what we can define entities via list.
Thank you so much!
10der
(Oleg Denisenko)
April 4, 2024, 6:27pm
8
you miss |
{{ expand(entities) | selectattr('state', 'eq', 'on') |
