ASUSWRT component installation
I don’t use an ASUS router anymore but from I’d imagine something has probably changed.
can you add the integration with a username and password instead of SSH key? (at least to test and then switch it over after its working)?
I noticed you didn’t have the path to the SSH key in the screenshot, so I’m not sure if that’s impacting it.
Were you able to make any progress with this?
I had this integration working fine for the past year (can’t remember how I configured it), but due to the LastPass breach I had to change all of my passwords including the router login. There was no option I could find anywhere to change the password used for this integration, so I deleted it to start all over again (including having to set up all device trackers again, unfortunately). However, I’m now stuck with a “failed to connect” error when I try to connect via router login (not SSH key). I think I have everything filled in correctly in the integration configuration, and I’ve also enabled SSH in the Asus router settings. I’m pretty sure I didn’t use the SSH key method the last time around…
I use the integration installed via HACS AsusRouter which works very well and better than the native AsusWRT.
