I have already pointed you to this page, but it recommends the idf framework for the S3
Try that.
Also if that is your complete log in the first part of your post, where does the last part with the error come from?
Try that.
Thanks, Iâll take a look at that page again.
The last part of my post is the output when I try to compile the yaml. It fails to compile and program due to an error with the assignment of gpio for the RGB LED.
Clearly something has compiled on it though, otherwise it wouldnât be running in the first part of the log.
I can get it to compile, but only when I remove the sections that define the gpio pins.
Thought I would put in my vote of sorts here. Just so someone with the right skills knows others are interested.
Iâm really looking forward to ESPHome working on the AtomS3. I am hoping the BT5 implementation on it will give better BT signal strength than the plane esp32 boards I have used so far. Hopefully closer to a Raspberry pi 4 with its bluetooth 5 experience.
I just got my s3 devices and was able to configure the bluetooth proxy and plug in illuminance sensor using this config. I havenât tried to setup the light and onboard button yet. Hope this helps someone else along the wayâŚ
#M5 AtomS3
esphome:
friendly_name: Device Room Name
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "y7lp0eZgbOp+M+PwPeFq3a17VLDVJNibjp/jn3Y4rVc="
# Over the Air Updates
ota:
password: !secret ota_password
# Wifi Setup
wifi:
ssid: !secret wifi_ssid
# Bluetooth Proxy
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
bluetooth_proxy:
active: true
# Illuminance Sensor
i2c:
- id: bus_a
sda: 2
scl: 1
scan: true
- platform: bh1750
name: "${friendly_name} Illuminance"
address: 0x23
update_interval: 5s
I managed to get my AtomS3 devices working with Bluetooth proxy. All good so far. I would say that Bluetooth performance is not as good as some larger esp32 Iâve used. I occasionally see my temperature sensor data become âUnavailableâ.
I managed to get the onboard button working.
I did quite a bit of investigation on the RGB LED and it seems that fasted is not supported for S3 yet.
What other esp32 boards have you tried with better BT signal range?
Thanks.
The ESP32 DEV KIT DOIT or WEMOS D1 Mini boards seem to work a bit better with fewer dropouts.
Thank you for the code. Helped me get going instantly. Airthings Wave+ was detected seconds after the Atom came online. Truly amazing that it was that easy considering that M5stack doesnât even mention that the AtomS3 Lite even has Bluetooth. Next, I would like to get the LED working if only to know the unit is on. Thinking that it would be nicefeedback to turn the LED Green from HA that way I would know that it is connected and the Airthings Wave+ is up and sitting out data. Thanks -Dave
I was able to get the Atom Lite working on ESPHome with this:
substitutions:
device_name: atomlitedemo
friendly_name: Atom Lite Demo
esphome:
esp32:
board: m5stack-core-esp32
framework:
type: Arduino
logger:
api:
encryption:
key: âxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxâ
ota:
password: âxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxâ
wifi:
ap:
ssid: âAtomlitedemo Fallback Hotspotâ
password: âxxxxxxxxxxxxxxxxxxâ
captive_portal:
light:
Post your yaml properly please.
Hereâs a working config for the M5Stack Atom S3 Lite
this post has been very helpful. I ended up with an M5AtomS3U with the usb A connection as that was all i could get in a reasonable amount of shipping time. After countless issues trying to flash any of the yaml code found here i ended up realizing that the web installer wouldnt see past the jtag programmer when using chrome or edge through a windows machine. I ended up having to plug the thing directly into my HAOS server. It worked to program it initially, but apparently it fails to update OTA. so eveytime i make a change i have to bring it back to the server for programming. anyone else had this issue with any of their m5 devices or is this unique to this specific product.
I am tring to use the Atom S3 Lite with a 4 channel relay. I have loaded the above code and that works well, but when trying to include a I2C portion to talk to the relay not allowing me to use GPIO 21 &22. Says GPIO22 is not valid.
Any ideas on how to use the grove Atom 4 channel relay?
Thanks!
I have the same problem. OTA Never Ever works on the Atom S3 Lite. Either timeout, stuck at 4% or 10%, bricks the device completely.
It does NOT reboot into safe mode. Itâs totally bricked.
Only option is to plug the device into an USB port of a computer and do esphome run XXX.yaml with local (USB) upload.
Itâs so frustrating .
Has anyone been able to use a sensor connected to the groove connector? I have a temp sensor I would like to use.
Iâm playing around with this at the moment. I want to use a GPIO port as an input for a thin film pressure sensor.
If I succeed, Iâll post the resultant yaml.
I have connected several m5stack sensors to the groove port with i2c
fonske/AtomS3_lite (github.com)
