Attribute as trigger isn't working
Thank you all guys to help me out… Have learned something also… not always you can change value to test your automation :smiley:
Now that you have changed the testing procedure and confirmed this works in a condition
{{ trigger.to_state.attributes.stock_available == true }}
have you tried to confirm if this works in a trigger?
      to: true
      attribute: stock_available
Yes I have didn’t work, after that I tried the conditions part and that worked.
But let me check it again to be sure
Yes. This is working also!! Thanks guys!!
