i have no clue how the new authentication works.
so i cant tell you if there will be a workaround.
Andrew will create something in a way he sees best, with the best possible options.
i know andrew and if something is optional he will make it optional.
at least you can be sure that when you dont want the port opened continously, it will be possible to just open it during the install and then close it again.
Hi @ReneTode
I just migrating from RPi3 to Intel NUC via Virtualbox
I installed the image 2.9 with updated to v. 0.87.1 then I discovered Appdaemon do not start…
it show me
2019-02-16 22:42:29.828109 INFO AppDaemon: HASS: Connected to Home Assistant 0.87.1
2019-02-16 22:42:29.841593 WARNING AppDaemon: HASS: Error in authentication
