Then there is no solution.
Surely you may put "type: section"
rows before each list - but then only these rows are displayed if lists are empty - and then the card will be displayed too since the WHOLE list is not empty.
If itĀ“s really not possible to hide the card when no lists elements exist (still doubt it)ā¦
Why can auto-entities
not realize thereĀ“s no element (consisting of nested, empty sub auto-entities) @thomasloven? This is working on the first level, so just wondering.
You may try to achieve this by using template
option of auto-entities
card.
Actually, LOT OF THINGS are possible with a template. Just learn & doā¦
Sorry for repost, butā¦
I have a question. I want to achieve somewhat simple setup. I want to have fold entities auto populated with auto entity like here:
But with toggles for the sections.
I played with static fold entity and was able to get whatās in the screenshot but I donāt know how to use auto-entity to get entities for the fold row.
I know I could have the toggle for the section if I would for example create light group with all entities for area but I was thinking if there is a way to do it without this step.
Just a tipā¦ I tried to make more items fit in a small space.
This is the css-mod item I added to the code:
type: custom:auto-entities
card:
type: entities
style: |
#states > div {
margin: -15px 0px;
To capture the individual divs under <div id="state">
you have to add ā> div
ā in the css.
Other example: with secondary info (note that the coloring does not work like this. the screenshot was colored with the browser inspector)
card:
type: entities
style: |
#states > div {
margin: 0px 0px;
.secondary, ha-relative-time {
color: #ed2323;
Cheers
DJ
I really love the idea of auto-entities and this is an awesome card!
I was creating a card in another thread using apexcharts-card
and custom-config-card
to create a dynamically changeable plot Dynamic selection.
The only downside being, that I have to manually define the input_select.sensors_to_show
. I think this is were auto-entities could come in and make this far more convenient and future proof.
Would it be possible to use auto-entities to define variables on-the-fly?
My idea was:
includes
for auto-entities (e.g. āareaā, āsensorsā, ādevicesā etc.). These are static anyway and do not change when adding new devices.include
parameter for auto-entities. Auto-entities would then create a list of e.g. all areasWould this be possible?
My current code is
type: vertical-stack
cards:
- type: entities
entities:
- entity: input_select.days_back_to_show
name: Number Of Days To Show
- entity: input_select.sensors_to_show #this is what auto-entities would need to supply
- type: custom:config-template-card
entities:
- input_select.days_back_to_show
- input_select.sensors_to_show
variables:
sensor: states['input_select.sensors_to_show'].state
span: states['input_select.days_back_to_show'].state+'d'
days: |
-states['input_select.days_back_to_show'].state+'d'+'1d'
card:
type: custom:apexcharts-card
graph_span: ${span}
span:
start: day
offset: ${days}
series:
- entity: ${sensor}
stroke_width: 2
group_by:
func: raw
EDIT:
I think it should be something along the lines of this, but I am not sure how auto-entities passes on the entities it uses, so I am not sure if it can populate a series.
cards:
- type: entities
entities:
- type: custom:auto-entities
card:
variables:
days: |
card:
graph_span: ${span}
span:
start: day
offset: ${days}
series:
# - entity: ${sensor} this would need to be populated
stroke_width: 2
group_by:
func: raw
#duration: 1min
entities:
filter:
include:
- domain: sensor
@AleXSR7001 I do not think you will be able to achieve what you want.
First of all, when calling domain: sensor
auto-entities will return ALL of your sensors.
So making graphs for ALL of them at the same time, while trying to preview large time spans, such as 10 days, will definately make your tab crash.
Second, try this as a simple example:
card:
type: entities
filter:
include:
- domain: sensor
options:
graph_span: 1h
span:
start: day
offset: 1h
series:
- entity: this.entity_id ### this is how you achieve auto-entities
### to pass the entity_id
stroke_width: 2
group_by:
func: raw
duration: 1min
You will have this result
As you can see, auto-entities pass the entity_id
twice and apexchars-card does NOT accept an entity value on the main config, so it throws an error that value.entity
is extraneous
What you CAN do, is to use the stock history graph and the hui-element card.
However you will not be able to go days back, but only hours back.
cards:
- type: entities
entities:
- entity: input_select.hours_to_show
- entity: input_select.sensors_to_show ### define options such as 'sensor', 'binary_sensor', 'light' etc
entities:
- input_select.hours_to_show
variables:
hours: states['input_select.hours_to_show'].state
sensors: states['input_select.sensors_to_show'].state
card:
card:
type: entities
filter:
include:
- domain: ${sensors}
options:
type: custom:hui-element
card_type: history-graph
hours_to_show: ${hours}
entities:
I am not concerned about the amount of sensors as I would be adding a second and maybe third input_select.
So I would most like have
So in the end it would be around 1-5 sources (same as now).
I think this is a āmissingā feature im auto-entities. It can only handle the parameter āentitiyā and not āentitiesā, so it cannot fill the series: entities:
I will try my luck in the auto-entities github and ask if it could be added as a feature
Hi.
I am in need with auto-entities and showing an attributeā¦ I want to show the IP of a device_tracker item, under developer_tools i can see that attribute is availble but i just canāt seem to get it showing in the auto-entities listā¦
The following code is the working
card:
type: entities
title: Home
filter:
include:
- domain: device_tracker
exclude:
- state: unavailable
- state: not_home
sort:
method: name
I know the following fixed entities card wil work :
type: entities
title: Entities card sample
entities:
- type: attribute
entity: device_tracker.desktop
attribute: ip
Anyone an idea how to get that working with auto-entities ?
Try this:
card:
type: entities
title: Home
filter:
include:
options:
type: attribute
attribute: ip
exclude:
- state: not_home
sort:
method: name
It works if ALL trackers have this attribute.
Otherwise it will show ā-ā for those trackers which do not have.
For example, ASUSWRT-based trackers do have ip
attribute, Life360-based & ping-based (which is strange for me) - do not.
Yessss, it works !.. Thank a lot, i was struggeling for long time now :Dā¦ And indeed some items have a - but that is just fineā¦
Thanks again
Has anyone figured out how to filter by the new entity categories in Auto-entities? Does it need an enhancement to support that?
Hey =)
i have two booleans.
and the second should only be shown when the first is activated ā¦
input_boolean.weekend
input_boolean.task_1
also:
if input_boolean.weekend is active then show me input_boolean.task_1. // if not, then not
that has to go somehow via a template value ā¦ but that just doesnāt want to.
maybe I think wrong too?
card:
type: entities
entities:
- entity: input_boolean.task_01
filter:
include:
- entity_id: input_boolean.weekend
state: '{{ is_state(''input_boolean.weekend', ''on'') }}'
Why not using a stock Conditional row inside Entities card?
can you tell me how ? =)
type: entities
entities:
- input_boolean.test_boolean
- type: conditional
conditions:
- entity: input_boolean.test_boolean
state: 'on'
row:
entity: input_boolean.test_boolean_2
madness ā¦ thatās not more?
Thanks alot!
can we somehow manage that the card is only shown when āinput_boolean.test_booleanā is activated?
now it is so that you can still switch here, and as soon as it is active, the boolean ātest_boolean_2ā is shown.
This is far beyond auto-entities
main topic here, it should not be discussed here.
type: conditional
conditions:
state: 'on'
card:
type: entities
entities:
- type: conditional
conditions:
state: 'on'
row:
Also you may use state-switch
custom card.
Hi everyone,
I opened an issue/feature request on Github but I am not sure if this will be implemented or implementable.
So I was wondering if anybody had any idea if somehow I could use auto-entities to create variables which I could then feed into my target card?
This is what it looks like, but I am having to use input_select for the entity drop-down, something that auto-entities would be ideal for .
type: entities
entities:
entities:
variables:
days: |
card:
graph_span: ${span}
span:
start: day
offset: ${days}
series:
- entity: ${sensor}
stroke_width: 2
group_by:
func: raw
Anybody have an idea?
