I want to know how to do this as wellā¦
how can I do this:
- type: custom:auto-entities
card:
filter:
include:
- group: group.z_wave_switches
options:
type: vertical-stack
cards:
- type: custom:decluttering-card
template: update_zwave_switches
variables:
- id: *object _id of switch in the group*
this is a work in progress, so the top card is not yet set, (do I need the vertical stack there, or ?).
to give you an idea what the manually configured stack look like for a couple of entities:
- type: vertical-stack
cards:
variables:
- id: afzuigkap_zolder
variables:
- id: amp_right_auditorium
variables:
- id: dorm_studenten
variables:
- id: freezer_garage
variables:
- id: freezer_bijkeuken
where each decluttering card is a horizontal stack of 3 button cards
cut it short: I need to template the object_idās of each group member and auto fill these in the decluttering card
something like this pseudo-code:
card:
cards:
filter:
template: |
{{ expand('group.z_wave_switches') | map(attribute='object_id') | list }}
hope this is clearā¦
Why not use grid card with column: 3
as option instead of vertical+horizontal? And then decluttering card as the card inside it using filter, which will give a grid with 3 button cards horizontally.
yes, I could do that too, my config is from before the grid card
will try and rebuild that, might be better. thanks for the suggestion.
but my main question is not about the layout, it is about the selection of the entities, and how to use the object_id in the auto-entities cards filter / decluttering-card
filter:
include:
card:
cards:
variables:
- id: this.object_id
doesnt work but gives a better Idea maybeā¦
Use case: I have several custom:auto-entities
inside an entities card. If none of the auto-entities show up, I have a blank entities card.
Q: How can I hide the whole card, if none of the auto-entities cards inside that card show anything?
example:
card:
type: entities
title: šŖ TĆ¼ren, Fenster & Co
state_color: true
show_header_toggle: false
show_empty: false
entities:
show_empty: false
unique: true
sort:
method: last_changed
reverse: true
If you want someone to help you, you should simplify a task.
200 lines in your code.
Start with TWO simple lists in your entities card.
The sense of the code is just to visualize what my words were talking about
Should be much easier to read meanwhile. Now IĀ“m sure the help will come shortly
Then do not put auto-entities
INSIDE entities card:
card:
type: entities
title: some title
state_color: true
unique: false
show_empty: false
filter:
include:
- entity_id: sensor.ac68u_snmp_mem*
options:
secondary_info: last-changed
sort:
method: name
reverse: false
ignore_case: true
- entity_id: sensor.cleargrass_1_*
options:
sort:
method: state
reverse: false
numeric: true
- entity_id: sensor.cleargrass_2_*
options:
sort:
method: state
reverse: false
numeric: true
There are three lists inside.
In your case you will probably get an empty card since you do not have entities sensor.ac68u_snmp_mem*
, sensor.cleargrass_1_*
, sensor.cleargrass_2_*
As I need a title for each list (for each custom:auto-entities
) I think I need to put them inside an entities card. This is what you could (have) see(n) in my initial post with full yaml code (200 lines, you remember :-D).
TITLE FOR WHOLE CARD
- Subtitle (Title of auto-entities card)
... List elements
... List elements
... List elements
... List elements
... List elements
... List elements
WhereĀ“s the difference in your code snippet compared to mine?
You use single entities within ONE auto-entities card, I need to nest several of them because I visually combine several lists to one card.
Again, main question: How can I hide the whole card, if none of the auto-entities cards inside that card show anything?
Hope I described the issue good enough.
Strange you do not see the difference.
You got Auto-entities inside Auto-entitiesā¦
Dream inside a Dream (āInceptionā)
Then there is no solution.
Surely you may put "type: section"
rows before each list - but then only these rows are displayed if lists are empty - and then the card will be displayed too since the WHOLE list is not empty.
If itĀ“s really not possible to hide the card when no lists elements exist (still doubt it)ā¦
- ā¦maybe itĀ“s at least possible to show a text āCurrently thereĀ“s no element active.ā e. g. by using GitHub - thomasloven/lovelace-template-entity-row: š¹ Display whatever you want in an entities card row..
- ā¦maybe there are other ideas too (like putting all list elements into one group and use condition card to show the card at all). So there are ways, itĀ“s just they are pretty/unnecessary complicated.
Why can auto-entities
not realize thereĀ“s no element (consisting of nested, empty sub auto-entities) @thomasloven? This is working on the first level, so just wondering.
You may try to achieve this by using template
option of auto-entities
card.
Actually, LOT OF THINGS are possible with a template. Just learn & doā¦
Sorry for repost, butā¦
I have a question. I want to achieve somewhat simple setup. I want to have fold entities auto populated with auto entity like here:
But with toggles for the sections.
I played with static fold entity and was able to get whatās in the screenshot but I donāt know how to use auto-entity to get entities for the fold row.
I know I could have the toggle for the section if I would for example create light group with all entities for area but I was thinking if there is a way to do it without this step.
Just a tipā¦ I tried to make more items fit in a small space.
TO:
This is the css-mod item I added to the code:
card:
type: entities
style: |
#states > div {
margin: -15px 0px;
To capture the individual divs under <div id="state">
you have to add ā> div
ā in the css.
Other example: with secondary info (note that the coloring does not work like this. the screenshot was colored with the browser inspector)
card:
type: entities
style: |
#states > div {
margin: 0px 0px;
.secondary, ha-relative-time {
color: #ed2323;
Cheers
DJ
I really love the idea of auto-entities and this is an awesome card!
I was creating a card in another thread using apexcharts-card
and custom-config-card
to create a dynamically changeable plot Dynamic selection.
The only downside being, that I have to manually define the input_select.sensors_to_show
. I think this is were auto-entities could come in and make this far more convenient and future proof.
Would it be possible to use auto-entities to define variables on-the-fly?
My idea was:
- Create an input_select with the
includes
for auto-entities (e.g. āareaā, āsensorsā, ādevicesā etc.). These are static anyway and do not change when adding new devices. - Use this input_select as
include
parameter for auto-entities. Auto-entities would then create a list of e.g. all areas - Create a variable of the auto-entities list and forward it to the next card.
Would this be possible?
My current code is
cards:
- type: entities
entities:
- entity: input_select.days_back_to_show
name: Number Of Days To Show
- entity: input_select.sensors_to_show #this is what auto-entities would need to supply
- type: custom:config-template-card
entities:
- input_select.days_back_to_show
- input_select.sensors_to_show
variables:
sensor: states['input_select.sensors_to_show'].state
span: states['input_select.days_back_to_show'].state+'d'
days: |
-states['input_select.days_back_to_show'].state+'d'+'1d'
card:
type: custom:apexcharts-card
graph_span: ${span}
span:
start: day
offset: ${days}
series:
- entity: ${sensor}
stroke_width: 2
group_by:
func: raw
EDIT:
I think it should be something along the lines of this, but I am not sure how auto-entities passes on the entities it uses, so I am not sure if it can populate a series.
cards:
- type: entities
entities:
card:
variables:
days: |
card:
graph_span: ${span}
span:
start: day
offset: ${days}
series:
# - entity: ${sensor} this would need to be populated
stroke_width: 2
group_by:
func: raw
#duration: 1min
entities:
filter:
include:
- domain: sensor
@AleXSR7001 I do not think you will be able to achieve what you want.
First of all, when calling domain: sensor
auto-entities will return ALL of your sensors.
So making graphs for ALL of them at the same time, while trying to preview large time spans, such as 10 days, will definately make your tab crash.
Second, try this as a simple example:
card:
type: entities
filter:
include:
- domain: sensor
options:
graph_span: 1h
span:
start: day
offset: 1h
series:
- entity: this.entity_id ### this is how you achieve auto-entities
### to pass the entity_id
stroke_width: 2
group_by:
func: raw
duration: 1min
You will have this result
As you can see, auto-entities pass the entity_id
twice and apexchars-card does NOT accept an entity value on the main config, so it throws an error that value.entity
is extraneous
What you CAN do, is to use the stock history graph and the hui-element card.
However you will not be able to go days back, but only hours back.
cards:
- type: entities
entities:
- entity: input_select.hours_to_show
- entity: input_select.sensors_to_show ### define options such as 'sensor', 'binary_sensor', 'light' etc
entities:
- input_select.hours_to_show
variables:
hours: states['input_select.hours_to_show'].state
sensors: states['input_select.sensors_to_show'].state
card:
card:
type: entities
filter:
include:
- domain: ${sensors}
options:
type: custom:hui-element
card_type: history-graph
hours_to_show: ${hours}
entities:
I am not concerned about the amount of sensors as I would be adding a second and maybe third input_select.
So I would most like have
- days to show
- area to show
- device type/domain to show
So in the end it would be around 1-5 sources (same as now).
I think this is a āmissingā feature im auto-entities. It can only handle the parameter āentitiyā and not āentitiesā, so it cannot fill the series: entities:
I will try my luck in the auto-entities github and ask if it could be added as a feature
Hi.
I am in need with auto-entities and showing an attributeā¦ I want to show the IP of a device_tracker item, under developer_tools i can see that attribute is availble but i just canāt seem to get it showing in the auto-entities listā¦
The following code is the working
card:
type: entities
title: Home
filter:
include:
- domain: device_tracker
exclude:
- state: unavailable
- state: not_home
sort:
method: name
I know the following fixed entities card wil work :
type: entities
title: Entities card sample
entities:
- type: attribute
entity: device_tracker.desktop
attribute: ip
Anyone an idea how to get that working with auto-entities ?
Try this:
card:
type: entities
title: Home
filter:
include:
options:
type: attribute
attribute: ip
exclude:
- state: not_home
sort:
method: name
It works if ALL trackers have this attribute.
Otherwise it will show ā-ā for those trackers which do not have.
For example, ASUSWRT-based trackers do have ip
attribute, Life360-based & ping-based (which is strange for me) - do not.
