Anyway you will need using ātemplateā option since you got 2 entities.
Read this.
And multiple-entity-row does not support sliders.
I think this is above me. I tried adapting your linked example to some simple sensors that my HA has, but I failed miserably.
I am surprised at how difficult this is proving to be.
Create any complex card w/o auto-entiies.
Let it be a stack of Entities cards + Glance cards + some graphs, whatever.
Do it in storage mode.
Then open a generated dashboard file - you will find a json code.
Here is a draft of your template ))))
Oh, I was not aware. I will need to give that a try. Is it possible to switch back and forth between storage and yaml mode without creating issues on dashboards?
You may use several dashboards in storage mode & several dashboards in yaml.
Usually yaml is used for ācombatā tasks, storage - for testing.
I just looked at the Multiple Dashboards - Home Assistant documentation and it looks like storage is the default anyway. Never considered moving my dashboards to yaml. But will do now. Much easier to backup than manually.
Thank you, I will check it out this weekend and hopefully learn somthing from the syntax that will help me here.
How can I include an entity based on the state of another entity?
I want sensor.device_a_locked to show up only when device_tracker.device_a is home.
ātemplateā option.
I myself prefer a āall config is in yamlā way & dislike the current trend āmove config to UIā.
Easier to backup, to temporarily include/exclude a code, move a code to another HA instance etc.
Yes. āTemplatingā is like 42: itās the answer to everything, right
No idea how to do this.
Hi! I have created a template that I want to use with auto-entities component. However, instead of creating multiple charts, all entities are thrown into one chart. Thereās probably a crucial step Iām missing, but I canāt for the life of me figure out how to make it work. For reference, this is how the one_line chart looks:
I want to make it shown for every entity returned by the auto-entities separately, like so:
But what Iām getting is this:
Hereās the code:
type: custom:auto-entities
card:
type: custom:apexcharts-card
config_templates: one_line
filter:
include:
- attributes:
unit_of_measurement: W
exclude:
- state: unavailable
And the template:
apexcharts_card_templates:
one_line:
update_interval: 1min
graph_span: 24h
layout: minimal
header:
show: true
show_states: true
floating: true
apex_config:
chart:
height: 60px
offset_x: 200px
card_mod:
style: |
#header {
width: 104px
#graph-wrapper {
margin-left: 120px
.apexcharts-canvas > .apexcharts-svg {
margin-top: -15px
Read this
Use this as a basis:
card:
type: vertical-stack
card_param: cards
filter:
include:
- entity_id: sensor.xxxx_*
options:
type: history-graph
hours_to_show: 1
entities:
- entity: this.entity_id
Thanks! Iām closer now, but not quite there yet. This is the code I have:
card:
card_param: cards
filter:
include:
- attributes:
options:
series:
exclude:
- entity_id: '*shelly*'
- entity_id: '*battery_power'
sort:
method: state
reverse: true
numeric: true
ignore_case: true
And this is the result:
/// apexcharts-card version 2.0.1 /// value.entity is extraneous
entity: sensor.house_power
series:
- entity: sensor.house_power
Solved! I needed to enable the disable_config_validation
option in apexcharts-card:
experimental:
disable_config_validation: true
Got it from your issue, @Ildar_Gabdullin. Thanks!
Now the final apexcharts-template code looks like this:
one_line:
graph_span: 24h
layout: minimal
experimental:
disable_config_validation: true # this fixed the last issue
header:
show: true
show_states: true
floating: true
apex_config:
chart:
height: 60px
offset_x: 200px
card_mod:
style: |
#header {
width: 104px
#graph-wrapper {
margin-left: 120px
margin-top: -15px
ha-card {
overflow: visible !important;
Yes, I observed this here, asked Thomas about this problem here, then asked RomRider about it here. Quite a story )
Thank you that you suffer so others donāt have to, kind sir. Hats off!
I am trying to show multiple picture-entity in a grid setup using auto-entities. I have arrived at this so far but it is complaining that āentitiesā must be specified. What am I missing?
- title: Cameras
path: cameras
icon: mdi:camera
type: panel
badges: []
cards:
- type: custom:auto-entities
card:
type: grid
square: true
columns: 5
card_param: cards
filter:
template: |-
{% for state in states.camera -%}
{%- if state.entity_id | regex_match("camera\.tapo_.*_hd", ignorecase=False) -%}
'type: picture-entity,
'entity': state.entity_id,
'camera_image': state.entity_id,
'camera_view': live,
'show_state': false,
'show_name': false,
'name': state.attributes.friendly_name.split(' - HD')[0]
{%- endif -%}
{%- endfor %}
because of this, no ā'ā.
Hi, I can list all my batteries with this:
card:
title: Batterier
type: entities
filter:
include:
- attributes:
device_class: battery
Buyt when i wanāt to sho only batteries below 80 procent, it dosenāt show anything?:
card:
title: Batterier
type: entities
filter:
include:
- attributes:
battery_level: <80
Whatās wrong?
