I agree that this would be a nice new feature, but since the addon is someoneās side project, I donāt expect it to be released soon. So if you are in need of a solution you should pick any workaround with the least friction. Which workaround that is, is a personal preference.
I tested my assumption: I was right. Having
- group containing
- other groups
- which contain entities
and using the root group as include filter (group: binary_sensor.root_group) will only list the root groupsā entities - which are the other groups. Not getting the grandchildren that way. So that workaround is a dead end.
Iāve got around 20 Ring security sensors and they each have 4-5 entities each:
- state
- tamper status,
- battery level,
- āinfoā,
- bypass mode.
Iām to use auto-entities to do a device filter for *Ring*Sensor* and get all the entities⦠but Iām getting 80-100 individual entities which is a bit intense.
Is there a way to use this Lovelace plugin to fetch all Ring sensor entities AND group entities from the same device into one row/item? Maybe using multiple-entitity-row?
I can understand @e-raser s thought on it belonging to the functionality already, given Thomasā own documentation on GitHub - thomasloven/lovelace-auto-entities: š¹Automatically populate the entities-list of lovelace cards
Any filter option can use
*as a wildcard for string comparison
Given that, I suppose an Issue on the repo is in order, maybe Thomas can explain, or fix.
on expanding the nested groups: FR: Add expand on nested groups (lights, switches etc) Ā· Issue #268 Ā· thomasloven/lovelace-auto-entities Ā· GitHub
@luisleonardo.pt Could you share your code? Iām interested in doing the same thing?
As a side note, I found the interface choking on entering direct YAML for my card (specifically on the regex).
I wrote the code up in a separate editor, copy-pasta-ed into the field and saved it. The same exact thing that I keyed into the interface and did not work, now works without a problem.
Auto-entities card displaying battery status:
type: custom:auto-entities
card:
type: entities
title: Button cell battery status
filter:
include:
- name: /.*?[Ss](ensor|witch)\d.*?([Pp]ower|[Bb]attery)/
sort:
method: state
reverse: false
numeric: true
show_empty: true
Does anybody know of a way to simply create a vertical list of areas with any of the stock cards?
The left most column should simply list the areas nameās rather than the full sensor name (here just as place holder a glance card).
type: horizontal-stack
cards:
- type: custom:auto-entities
card:
type: glance
show_state: false
show_icon: false
columns: 1
filter:
include:
- entity_id: sensor.eq3_temp*
exclude: []
card:
type: glance
show_name: false
show_icon: false
columns: 1
filter:
include:
- entity_id: sensor.eq3_temperature*
exclude: []
card:
type: glance
show_name: false
show_icon: false
columns: 1
filter:
include:
- entity_id: sensor.xiaomi_temperature*
exclude: []
card:
type: glance
show_name: false
show_icon: false
columns: 1
filter:
include:
- entity_id: sensor.xiaomi_humidity*
exclude: []
Meanwhile I found it !
For people looking for an example of mushroom integration, he is mine :
type: vertical-stack
cards:
- type: custom:mushroom-title-card
subtitle: Batteries
sort:
method: state
numeric: true
card:
type: entities
filter:
include:
- entity_id: '*battery_level*'
- attributes:
device_class: battery
state_class: measurement
options:
type: custom:mushroom-template-card
primary: '{{ states[''this.entity_id''].attributes.friendly_name }}'
secondary: '{{ states[''this.entity_id''].state }}%'
icon: >-
{% set battery_level = states['this.entity_id'].state |float(0) %}
{% set battery_round = (battery_level / 10) | int(0) * 10 %} {% if
(battery_round >= 100) %}
{{ 'mdi:battery' }}
{% else %}
{% if (battery_round > 0) %}
{{'mdi:battery-' ~ battery_round}}
{% else %}
{{ 'mdi:battery-alert' }}
{% endif %}
{% endif %}
icon_color: >-
{% set battery_level = states['this.entity_id'].state |int(0) %}
(battery_level >= 50) %}
{{ 'green' }}
{% else %}
{% if (battery_level > states('input_number.number_batterij_drempel') |int(0)) %}
{{'orange'}}
{% else %}
{{ 'red' }}
{% endif %}
{% endif %}
tap_action:
action: none
double_tap_action:
action: none
exclude:
- attributes:
friendly_name: '* Battery Level'
sort:
method: state
numeric: true
why use the icon template? youāve selected the device_class: battery, which does that for you
or doesnt the mushroom card show the core device_class? (asking since I dont use the Mushroom cards)
If you donāt specify an icon in a mushroom template card, none will be displayed
I see, thatās not good
though I believe custom:card-button doesnt follow device_class either. pity really.
Did you figure out a way to hide hidden entities? As far as my research goes, there is still no template option (Access hidden entity status from template? - #5 by giorgos).
My workaround so far: I created a group with the hidden elements and excluded this within the auto-entities card.
No, I havenāt done anything with hidden entities - do not have them.
Your solution with a group seems to be OK. If the group may be created automatically - then it would be great.
Is there any way to determine the āhiddenā flag in templates?
Is it possible to use auto-entities with Mushroom Chips cards? The mushroom chip card expects a single entity parameter rather than a list of entities. Auto entities would have to create a separate card for each entity in the list.
Looking for some help - I want a card to show if any devices are playing plex. This is what I have so far.
Things I am looking to add. Sort in order by device name, test implementing with mini media player, Title of movie/show playing. Or looking for what others are doing for this.
card:
type: entities
filter:
include:
- entity_id: media_player.plex_*
state: /playing|paused|'on'/
Canāt help with the rest, not using media_player, but there is a sort option for auto-entities.
options - sort:
@all:
Can anybody think of a way of checking how many entities are being auto created by auto-entities? I would like to make some cards conditional on the amount of entities to be displayed.
Auto-entities does seem to have an internal counter that can be used for count: but I cannot see how to access it in Javascript.
I have problems wrapping my head around this simple task. Instead of displaying āstateā in the Glance-card, I want to display the āshow_last_changedā or ālast-changedā (custom:auto-entities) for all entities showing up in the card.
Any ideas?
show_empty: false
sort:
method: name
card:
type: glance
show_state: false
filter:
include:
- entity_id: binary_sensor.window_sensor*_access_control
state: 'on'
- entity_id: light.dimmer_*
state: 'on'
# options:
# secondary_info: last-changed ???
- entity_id: binary_sensor.smoke_detector*_smoke_alarm_smoke_detected
state: 'on'
- entity_id: binary_sensor.flood_sensor*_water_alarm_water_leak_detected
state: 'on'
If filterering is done by using a ātemplateā option, then a count of filtered items may be calculated.
- Remove ā
show_state: falseā - it prevents displaying ālast-changedā. - If you need a ālast-changedā displayed for every item (not only ā
lightā) then the āoptionsā must be specified for each item. - Use ā
show_last_changed: trueā instead of what you wrote (it is unsupported).
Filtering is done using include/exclude.
