šŸ”¹ Auto-entities - Automatically fill cards with entities
Only by using a ā€œtemplateā€ option as a filter.
Hi, With this card im trying to add and remove devices from my vpn gateway,
Only does the option not work for the template it seams.
Does someone has a solution?
type: custom:auto-entities
card:
  type: entities
filter:
  template: >
      {% for device in states.device_tracker %}
        {% if state_attr(device.entity_id,'ip') |  regex_match('192.168.5.(1[5-9]\d|2[0-4]\d)') -%}
          {% if states('binary_sensor.vpn' + state_attr(device.entity_id,'ip') | replace('.','_')) != "on" -%}
          {{ device.entity_id}},
          {%- endif %}
        {%- endif %}
      {% endfor %}
  options:
      tap_action:
        action: call-service
        service: script.vpn_add
          entity_id: this.entity_id
Thanks for this awesome card, Iā€™m using it to show ā€œabnormalā€ states for my sensors (water, gas, smoke, etc) so that they only will show up if triggered. That works great.
Iā€™m now trying to show my triggered camera images from Blue Iris, but only if it contains a valid camera image, e.g. the camera has triggered an alert in Blue Iris.
I have set up one MQTT camera entity in HA for each of my cameras, and those get the trigger screenshot from Blue Iris through MTTQ. This works just fine, each time a camera triggers an alert the corresponding MQTT camera gets the alert screenshot from Blue Iris.
But I would like to only show the camera image if it contains an actual image, if the corresponding Blue Iris camera has not been triggered the MQTT camera entity will not contain any picture/screenshot of the alert. But I can figure out how to use this card and make a filter that checks if the MQTT camera contains a valid image or not. Iā€™m trying to use a picture-glance card for this, is this even possible?
Example code:
card:
  type: picture-glance
  camera_view: auto
  entities: []
  camera_image: camera.front_door_mqtt
filter:
  include:
    - entity_id: camera.front_door_mqtt
show_empty: false
This will of course show the camera image based on the ā€œincludeā€ filter, or just a blank image if the camera contains no valid image. What I cannot figure out is how to make an ā€œexcludeā€ filter that excludes the camera entity if it does not contain a valid image.
Any ideas on how to achieve that anyone?
Paste your code into Dev Tools ā†’ Template and then post here an output.
May be I am wrong - please correct me.
You have a card:
type: some_type
some_option: camera.some_entity_id
And then you want to show this card only for ONE particular entity dependingly on some conditions, like:
if CONDITION == true for entity_1 -> show a card for entity_1
if CONDITION == true for entity_2 -> show a card for entity_2
What you can do is:
card:
  type: vertical-stack
card_param: cards
filter:
  - include:
      ...some_filter
      options:
        type: some_type
        some_option: this.entity_id
        ...other options for card
or rewrite the same code for using a ā€œtemplateā€ filter (if filtering may be done by templates only).
Responding to myself here, because after digging some more I found a rather simple solution to this.
I added the ā€œavailability_topicā€ attribute to my MQTT cameras and made sure that Blu Iris sends the payload ā€œonlineā€ as well as the image whenever it detects motion. My MQTT cameras will then have the state ā€œunavailableā€ if no motion has been detected, this will change to ā€œidleā€ as soon as it gets an image and ā€œonlineā€ as its ā€œavailability_topicā€. The latter was the key to the solution. Now the ā€œpicture-glanceā€ cards for each of my MQTT cameras will only show if any movement has been detected, in which case it shows the snapshot from the last alert. Not sure if this is the easiest way to achieve this, but it works. :slight_smile:
Working code:
card:
  camera_view: auto
  entities: []
filter:
  include:
      state: idle
show_empty: false
Thanks, yes thatā€™s how it works. :slight_smile:
My issue was that I didnā€™t have something suitable to use as a filter, which I have now solved as per my post below (or above). Thanks again!
This is not a case for auto-entities.
If you have only ONE camera entity and you need to show the card for this only entity_id conditionally - use a standard conditional card.
I donā€™t know if there was an update, but suddenly this doesnā€™t work anymore:
cards:
  - type: custom:mushroom-title-card
    subtitle: Lights switched on ({{states('sensor.aantal_ingeschakelde_lichten')}})
  - type: custom:auto-entities
    show_empty: false
    card:
      type: entities
    sort:
      method: name
      numeric: false
    filter:
      include:
        - domain: light
          options:
            type: custom:mushroom-template-card
            primary: '{{ states[''this.entity_id''].name.replace(''lights'', ''Lights'') }}'
            secondary: '{{ states[''this.entity_id''].state }}'
            icon: mdi:lightbulb
            icon_color: |-
              {% if states['this.entity_id'].state == 'on' %}
                orange
              {% else %}
                grey
              {% endif %}
            tap_action:
              action: toggle
            double_tap_action:
              action: none
      exclude:
        - state: 'off'
        - state: unavailable
        - attributes:
            friendly_name: Group -*
        - attributes:
            friendly_name: Sun blinds
        - attributes:
            friendly_name: LED*
        - attributes:
            type: browser_mod
When I remove the ā€œoptionsā€ part, it worksā€¦but I want the mushroom part.
Any idea ?
I have the exact same problem. It works without the options section included. It also only seems to not work for lights. I have another card that shows active motion sensors and it still works just fine.
So nice! I was looking for something like this for so long :partying_face: !! But what I didnā€™t liked about it was the hardcoded speaker_group entities.
ā€˜speaker_groupā€™: {ā€˜platformā€™: ā€˜sonosā€™,ā€˜show_group_countā€™: true,ā€˜entitiesā€™: [
{ā€˜entity_idā€™: ā€˜media_player.ralfā€™,ā€˜nameā€™: ā€˜Ralfā€™},
{ā€˜entity_idā€™: ā€˜media_player.badā€™,ā€˜nameā€™: ā€˜Badā€™},
{ā€œentity_idā€: ā€œmedia_player.kucheā€,ā€œnameā€: ā€œKĆ¼cheā€},
{ā€œentity_idā€: ā€œmedia_player.wohnzimmerā€,ā€œnameā€: ā€œWohnzimmerā€},
{ā€œentity_idā€: ā€œmedia_player.elternā€,ā€œnameā€: ā€œElternā€},
{ā€œentity_idā€: ā€œmedia_player.annikaā€,ā€œnameā€: ā€œAnnikaā€},
{ā€œentity_idā€: ā€œmedia_player.gasteā€,ā€œnameā€: ā€œGƤsteā€}]
The first part of the code is dynamic, so why not the speaker_group entities part?
Secondly, what I didnā€™t liked about it is that the ā€œMasterā€ is also shown :confused: :thinking::
Screenshot 2022-12-29 225202
So what I wanted is just to show the other speakers :grinning::
Screenshot 2022-12-29 225220
So here is my version :partying_face: :partying_face: :partying_face::
show_empty: true
card:
  type: entities
filter:
  template: >-
    {%- set speakers=expand(integration_entities("sonos"))|selectattr("domain","eq","media_player")|map(attribute="entity_id")|list %}
    [ {% for speaker in expand(speakers) if speaker.attributes.group_members[0] == speaker.entity_id %}
    {%- set speaker_group = namespace(entities=[]) %}
    {%- for member in speakers if member!=speaker.entity_id %}
    {%- set speaker_group.entities=speaker_group.entities+[{'entity_id' : member,'name': state_attr(member,'friendly_name')}] %}
    {%- endfor %}
              'type': 'custom:mini-media-player',
              'entity' : speaker.entity_id,
              'artwork' : 'cover',
              'group': false,
              'hide': {
                'power': true,
                'icon': true,
                'source': true
              'speaker_group': {
                'platform': 'sonos',
                'sync_volume': true,
                'show_group_count': true,
                'entities': speaker_group.entities
    {%- endfor %} ]
And here in action :film_strip::
msedge_HLd12zqF61
Please let me know if you find a solutionā€¦
Solved with the update of today :grinning:
How to change the name of an included entity? Using the options: option with name: ABC or friendly_name: ABC etc. did not work (while it does for secondary_level: xxx etc.).
ā€œoptionsā€ is a proper name
Just a typo. Whatā€™s the solution?
@Ildar_Gabdullin I have 7 camera entities, and I only want to show those that have an active alert. auto-entities now does that perfectly - despite you declaring that ā€œthis is not a case for auto-entitiesā€. :slight_smile:
For one entity (as it was in your 1st post) I would use a conventional conditional card.
But if you have 7 cameras - agree absolutely, auto-entities is a good choice! Saves a lot of code, no problems with margins between hidden conditional cards.
so experimenting with the new Tile card, and aware this might not be the best card to show inside an entities card.
My hope is to auto populate all of my Area subviews with Tile cards of lights, switches, covers and media players.
started out simple, with a auto-entities/cluttering card that can be used on any of these subviews, only using the domain and the area, so the auto-entities in that decluttering card can do the works.
Since not all of the Tile cards have (the same) features, I struggled at first setting a manual line for those in the entities card (always start verbosely), but then wanted to add that to the auto-entities (via the declutteringā€¦)
can not make it happen though, as on any test I did, the dashboard returns an error. this is what I tried in the end:
default:
  - features: null
card:
  card:
    type: entities
    title: '[[title]]'
    card_mod:
      class: class-header-margin
    show_header_toggle: false
  filter:
    include:
      - domain: '[[domain]]'
        area: '[[area]]'
        options:
          type: custom:hui-element
          card_type: tile
          features:
            - type: '[[features]]'
and this is what I get:
Is there a syntax issue I overlook, or cant we simply use the auto-entities card for this feature. Or, should I maybe try to add the whole line to a default value in the declutteringā€¦
  - type: custom:decluttering-card
    template: area_domain
    variables:
      - title: Library lights
      - area: library
      - domain: light
#       - features:
#           - type: '[[features]]' #light-brightness
fwiw, the auto-entities can better be combined with layout card in this case:
card:
  card:
    type: custom:layout-card
    layout_type: masonry
  filter:
    include:
        area: '[[area]]'
        options:
          type: tile
showing the Tile cards individually
Is it possible to only show groups? I put all my lights into groups. I only want to list groups.
Setting the domain as ā€œgroupsā€ doesnt work :frowning: Any ideas?
