[[ P.S. I love that you Have an āArrakisā light. What does it do exactly? ]]
Iām trying to get an action to work that uses an attribute of the entities but nothing ever happens. This is my card code, which does populate correctly
type: custom:auto-entities
filter:
include:
- integration: twitch
state: streaming
options:
type: horizontal-stack
cards:
- type: tile
show_entity_picture: true
entity: this.entity_id
state_content: game
- type: button
tap_action:
action: call-service
service: androidtv.adb_command
command: >-
am start -a android.intent.action.VIEW -d twitch://stream/{{state_attr(this.entity_id, 'friendly_name') }}
entity_id: media_player.android_tv_living_room
icon: mdi:sofa
icon_height: 35px
card_param: cards
card:
type: vertical-stack
I know that the command works if I give it a value manually, so the specific problem is that the {{state_attr(this.entity_id, 'friendly_name') }}
isnāt working.
And not supposed to work since a standard button card does not support templates.
Hi all,
Tried searching and didnāt see anything, so apologies if I missed this. Recently when Iāve tried to update one of my auto-entities cards it has caused Home Assistant to crash. I do have a ton of entities, so perhaps this is why? Is there anything I should be doing differently to avoid this?
Hereās my card yaml:
- type: custom:auto-entities
card:
type: entities
filter:
template: |
{% for sensor in states.sensor %}
{% if (sensor.state|int(0) - states('sensor.average_temperature')|int)|abs > 10 and state_attr(sensor.entity_id,'device_class') == 'temperature' %}
{{ sensor.entity_id}},
{% endif %}
{% endfor %}
exclude:
- name: Outside*
- name: Garage*
- name: OpenWeatherMap*
- name: Filtered*
- name: Processor*
- name: '*Vibration*'
- name: '*Device temperature*'
- name: '*Owlet*'
- state: unavailable
- state: unknown
- name: '*Meat*'
- name: '*Freezer*'
- name: '*Fridge*'
- name: '*Pixel*'
- name: '*Forecast*'
Cannot use these 2 filter options together.
Either:
ā include
ā include + exclude
ā template
Ah, thank you for pointing that out! I swapped it out with the Custom Button Card and itās working perfectly now.
hello i am new to this hoping you can give me some advice
i want to hide/show an entity based on a different entity (sensor) status:
- āmedia_player.androidā should only be displayed when
- āsensor.lg_tv_power_stateā is āonā
this is probably pretty simple with templates but i am struggling with the syntax. maybe somebody can give me a code example of a similar scenario working (i.e. an auto-entity card filtering an entity based on another entityās status)
thank you!
If Iām understanding correctly then you donāt even need the auto-entity card; you can just this with a conditional card. Is this what youāre wanting?
type: conditional
conditions:
- condition: state
entity: sensor.lg_tv_power_state
state: 'on'
card:
type: media-control
entity: media_player.android
im sorry yes forgot to report back. managed it meanwhile with the condition card which proved to be the better way of doing this anyway. thanks
Hi! First, i love this card!
I am triying to automatically create popups with buble card, each of one has inside another autoentites card to create a grid with mushroom template card.
I have been triying many ways but not luck. I donāt even know if this is possible.
Is there any chance that you give a hand?
Million thanks!
This would be the schema:
Is it possible that only the light group is displayed and not the individual lamps in the group. Havenāt found anything about this yet.
With exclude: and group: I can exclude the lamps from the group, but I then have to enter this for each group.
I tried with a wildcard but this works, does anyone know why? Iāve already tried with " ".
show_empty: false
card:
show_name: true
show_icon: true
show_state: false
type: glance
title: Lichter an
state_color: true
columns: 2
filter:
include:
- domain: light
state: 'on'
options:
tap_action:
action: toggle
- type: ''
exclude:
- name: AU_Wand
- group: light. *
sort: null
method: friendly_name
how can i set between each friendlyname missmatch a divider?
card:
type: entities
title: Proxmox LXC
state_color: true
filter:
include:
- device_model: LXC
entity_id: '*status'
options: {}
- entity_id: '*cpu_auslastung'
options: {}
exclude: []
sort:
reverse: true
ignore_case: false
numeric: false
ip: false
Can anybody help me please? I canāt get this combination of cards to work.
The idea is to have a card that only shows up when thereās an update. If itās an update from HACS, it shows witch update it is (instead of only having a number of how many updates HACS has). The updates from within home assistant are already specified, so they show up as well)
Hereās the code:
show_header_toggle: false
card:
type: entities
title: Add-on & Integratie Updates
filter:
include:
- domain: update
state: 'on'
- entity_id: sensor.hacs
state: '! 0'
show_empty: false
sort:
method: last_triggered
- type: markdown
title: HACS Updates
content: |-
{%- if is_state('sensor.hacs','0') -%}
<b><font color=green>No updates</font></b>
{%- else -%}
<table width=100%>
{%- set hacs_updates = state_attr('sensor.hacs','repositories') -%}
{%- for hacs_update in hacs_updates -%}
<tr><td><b><font color=red>{{[hacs_update][0]['display_name']}}</b></font></td><td>{{[hacs_update][0]['installed_version']}}</td><td>{{[hacs_update][0]['available_version']}}</td></tr>
{%- endfor -%}
</table>
{%- endif -%}
Ofcourse it doesnāt need to be a markdown card at the bottom, if anybody can figure out how to show the attributes in the entities card part, itās cool to. I just want it to show me the specifications of the updates from HACS, when there are updates.
I think i found it, but if anybody has a batter way of doing this, i would like to hear it.
This is what i have now:
filter:
include:
- domain: update
state: 'on'
state: '! 0'
show_empty: false
sort:
method: last_triggerd
card:
type: custom:stack-in-card
mode: vertical
cards:
card:
type: entities
filter:
include:
- domain: update
state: 'on'
show_empty: false
sort:
card:
type: markdown
content: |-
{%- else -%}
<table width=100%>
{%- endfor -%}
</table>
{%- endif -%}
filter:
include:
state: '! 0'
show_empty: false
sort:
Hi, some time has passed since the last message, but now Iām back on my card and I would like to fix it permanentlyā¦
Have you found a new (working) way to monitor all the devices on the network
Hi, yes I have a way of monitoring all my network devices. But it involves my unifi network devices. Never got back to using nmap. Since the unifi integration does enough for me.
I was hoping that i could get some help. I am looking for two things.
I borrowed some of a script from this thread to show all my devices that are lights/on. I have a kasa power strip setup with my cable modem so I can reboot it. However it always is on & needs to be on. The script below shows everything but i cant seem get the exclusion to work.
card:
type: entities
filter:
include:
- entity_id: light.*
state: 'on'
options:
type: custom:mushroom-update-card
entities:
- this.entity_id
tap_action:
service: homeassistant.turn_off
service_data:
entity_id: this.entity_id
exclude:
- device: TP-LINK_Smart Plug_3BFF
While this does work - the cable modem which is the device above - still shows up. I also tried the entity but that doesnt work either.
2nd question:
How can I setup an auto-entities based on an integration?
For example I use the Lutron integration - how can i get it working?
`type: custom:auto-entities
card:
type: entities
filter:
include:
- device_manufacturer: lutron
device: lutron
exclude: []
This for some reason doesnt work. Any ideas?
Hi i have a question: is it possible to fill vertical stacks + child items from one auto entities card?
I try something like this:
show_empty: false
card:
type: custom:layout-card
layout_type: custom:grid-layout
filter:
template: >-
{%- set area = 'Wohnzimmer'-%}
{%- set domains = states | selectattr('entity_id',
'in',area_entities(area)) | map(attribute='domain') | unique | list -%}
{%- for domain in domains -%}
{% set entities = states | selectattr('entity_id',
'in',area_entities(area)) | selectattr('domain', 'eq', domain)
| list -%}
{{{ 'type': 'vertical-stack',
'title': domain,
'cards':
[{'type': 'entity',
'entity': 'light.bad'}]}}},
{%- for entity in entities -%}
{{{ 'type': 'entity',
'entity': entity.entity_id, }}},
{%- endfor %}{%- endfor %}
This gives me a vertical stack for every domain i have. The only entity in the stack is ālight.badā which i manually put in there. The other loop gives me all other entities but there are single cards not put into the vertical stack.
any way to achieve every domain + entities of that domain go into a vetical stack?
PS: i have a working example but with two auto entities card. so one creates another and i think this slows down the generating
how can i count all entities through this nested loop?
{%- set areas = states.light | selectattr('state','eq', 'on') |
map(attribute='entity_id') | map('area_name') | unique | reject('none') |
list -%} {%- for area in areas -%} {%- set entity_filter = ''
%} {% set entities = states.light | selectattr('state','eq',
'on') | selectattr('entity_id', 'in', area_entities(area)) |
rejectattr('entity_id', 'in', entity_filter) | list -%}
{{entities | length }}
gives me the output
how to ged 6 instead of 5 and 1?
