Auto-entities with else card within vertical stack
  1. Suggest to ask/raise similar issues in the dedicated auto-entities thread.
  2. The issue what you described seems to be a bug. Check this issue.
  3. The “filter” in you card contains only 2 entities with same “options” and for 2 possible entities (“test_boolean”, “testing_boolean”) may be optimized like:
    filter:
      include:
        - entity_id: /input_boolean.(test|testing)_boolean$/
          options:
            type: custom:template-entity-row
            color: >-
              {% if is_state('this.entity_id','on') %} green {% else %} red {%
              endif %}
      exclude:
        - state: 'on'
