I’ll answer myself as I found the answer from another trail.
(To give credit - it’s based on this answer)
Recap: if my sensor say “off”, it means the freezer door is opened because the temperature inside went up. I want my HAdashboard to switch to a custom dashboard called alert.dash to make sure I see that.
You will need 3 things
- Transform your sensor value to “on” and “off”
- Deploy a small phyton script in appdaemon
- Deploy / modify a small yaml file in appdaemon
In Home Assistant
######Comments##########
# This is in HomeAssistant/config/configuration.yaml
# a binary sensor let you transform a sensor value into something else
# Once HA is restarted, I will get a new entity available called binary_sensor.freezer_on_off
# the "lower: -16" is my threshold. Colder than -16oC, it will sates "on". Otherwise "off"
binary_sensor:
- platform: threshold
entity_id: sensor.shelly_shht_1_e010c7_temperature
lower: -16
The python script in appdaemon
# This is a new file created: appdaemon/apps/freezer_status.py
# the filename is freezer_status.py
# - attention, in some other docs, they say it's in a sub directory of appdaemon/conf/apps
# - for me it was appdaemon/apps
# In theory, you can use this "as is" - no modifications.
# This is NOT where you configure the name of your dashboards
class Navigate(hass.Hass):
# Listen for state changes for the sensor
def initialize(self):
self.listen_state(self.freezer_status_change, self.args["freezer_status_sensor"])
def freezer_status_change(self, entity, attribute, old, new, kwargs):
# Check if the sensor state is on or off.
if new == "on":
self.dash_navigate("/" + self.args["on_dashboard"])
elif new == "off":
self.dash_navigate("/" + self.args["off_dashboard"])
The yaml file in appdaemon
# This is in appdaemon/apps/apps.yaml
# I added the following to this file
# You need to REPLACE "normal" and "freezer_alert" with the names of your dashboards
# do not add the .dash extension
freezer_status_nav:
class: Navigate
module: freezer_status
freezer_status_sensor: binary_sensor.freezer_on_off
on_dashboard: normal
off_dashboard: freezer_alert
Restart appdaemon
Good luck!
