Is anyone else’s component broken? It looks like api.aladhan.com is down? @cgtobi, sorry to tag, but are you aware?
2019-05-31 06:13:01 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform islamic_prayer_times
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 80, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 70, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network unreachable
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 354, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.7/http/client.py", line 1229, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1275, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1224, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1016, in _send_output
self.send(msg)
File "/usr/local/lib/python3.7/http/client.py", line 956, in send
self.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 181, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x718f4ef0>: Failed to establish a new connection: [Errno 101] Network unreachable
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 399, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='api.aladhan.com', port=80): Max retries exceeded with url: /timings/1559232000?latitude=xxxxx&longitude=xxxxx&method=3 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x718f4ef0>: Failed to establish a new connection: [Errno 101] Network unreachable'))
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/islamic_prayer_times/sensor.py", line 51, in async_setup_platform
prayer_times = prayer_times_data.get_new_prayer_times()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/islamic_prayer_times/sensor.py", line 157, in get_new_prayer_times
self.prayer_times_info = calc.fetch_prayer_times()
File "/usr/local/lib/python3.7/site-packages/prayer_times_calculator/pray_times_calculator.py", line 38, in fetch_prayer_times
response = requests.get(url)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='api.aladhan.com', port=80): Max retries exceeded with url: /timings/1559232000?latitude=xxxxx&longitude=xxxxx&method=3 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x718f4ef0>: Failed to establish a new connection: [Errno 101] Network unreachable'))
