Thanks for the tip. Proper logic to determine whether the sun is coming through the window is really all im looking for
Thanks to your question I just realized there is a mistake in the FOV calculation.
The calculation:
{% set gamma = deg2rad * (win_azi - sun_azi) %}
Should be:
{% set gamma = deg2rad * ((win_azi - sun_azi + 180) % 360 - 180) %}
This template will work as a condition for your automations (set win_azi
to your window azimuth ofcourse)
{% set win_azi = 330 %}
{% set sun_azi = state_attr('sun.sun', 'azimuth') %}
{% set sun_ele = state_attr('sun.sun', 'elevation') %}
{% set sw_diff = (win_azi - sun_azi + 180) % 360 - 180 %}
{{ (sw_diff | abs < 90) and (sun_ele > 0) }}
Glad I could help . Thanks for the template. I’m guessing if true close, if false open. Simple as that?
Yes indeed
Thanks this works.
One last thing - I’d like to send a notification when the blinds are set. This works using the
service: notify.slack
target: "#debug"
message: "{{ cover_entity }} set to {{ cover_height }}"
Unfortunately this translates to
{'entity_id': 'cover.kitchen'} set to 0
Is there a better one to use to get the name of the entity?
Yes, it’s just a python dict. So {{ cover_entity['entity_id'] }}
should work.
gah I didn’t think of that. Still too new to the HA automations section, I’ve been using Nodered sofar.
Visibly it seems to be closing the blind early. The template is returning true but the sun is not close to shining through the window.
Visibly the sun i shining through windows on the right side of my house and the one that incorrectly fired is in the back of my house. I think the sun needs to make it more to the back of my house to be accurate
You can see the sun is shining more on the right side of the house and hasnt made its way to the back
This is the current sun position as of making this post, and the automation just fired on a window azimuth of 196
By default the FOV is 180 degrees, 90 degrees left and right from the window. So if your window has an azimuth of 196 the template will return True
in range [106,286]
. You can reduce the FOV to whatever you like ofcourse.
Ok that makes more sense. In the template you gave:
Which is the fov?
The number 90 in the last line. If you want independent FOV for left and right you’ll have to change that line a little bit (check out the blueprint code which has that)
Looks like the left and right fov is the most intense part of the math you did.
This seems to be the part of the code i need where one if statement is if its on the left and the other if it has passed the right.
{%- if gamma < azi_left or gamma > azi_right or alpha < elev_low or alpha > elev_high -%}
{{ clipv(h2perc(h) | round(0) | int , 0, 100) }}
{% else %}
{{ clipv(h2perc(def_h) | round(0) | int , 0, 100) }}
{% endif %}
Seems gamma
is sw_diff
as in the template u gave earlier and you have also those two other macros which ic an use. However h
and def_h
confuse me. I assume these are different for me since i have dumb blinds. def_h
would be the height of my blind, 2.1 meters, and h
… idk about that one. I thot h
was if i had smart blinds, so i’m unsure how to make the edit. Here is what i have so far:
{% set azi_left = 30 %}
{% set azi_right = 60 %}
{% set def_h = 2.1 %}
{% set d = 0.5 %}
{% set h = (d / cos(sw_diff)) * tan(sun_ele ) %}
{% if sw_diff < azi_left or sw_diff > azi_right or sun_ele < 0 or sun_ele > 90 %}
{% else %}
{% endif %}
Lost my true/false statement too. I have no idea what clipv
1 and h2perc
do. Maybe i don’t need any of that?
{{ sw_diff < azi_left or sw_diff > azi_right or sun_ele < 0 or sun_ele > 90 }}
Am I on track here?
{{ (sw_diff < azi_left) and (sw_diff > -azi_right) and (sun_ele > 0)}}
In case anyone wonders how to use the custom_template to turn it into a sensor:
Add this to your configuration (wherever you have it)
template:
- sensor:
- name: calculated_cover_position
unit_of_measurement: "%"
state: >
{% from 'auto_sun_blind.jinja' import auto_sun_blind %}
{{ auto_sun_blind(azimuth=245, distance=0.1, height=2.30, min_height=1.10, def_height=100, fov_left=45, fov_right=45, elev_min=0, elev_max=90) }}
with the right values for your covers, ofcourse.
Been playing a bit more with the custom template - it kept going just from 100 to 0 to 100, so I figured I was doing something wrong.
Question: on the docs you specify min_height as “The minimum height in meters when the blinds are fully open. This will be 0 in most cases.” - do you mean the bottom height of the window? (in my case, some of the windows are at 1.10m height up to 2.3m height)
So, is it better to specify 1.10 as min_height and 2.3 as height, or 0 and 1.20 respectively?
Do you have distance set to 0? That could cause it to go from 0 to 100.
I would just use 0 and 1.20. That minimum height was intended to be a bit more flexible in defining the height of the window, but it’s not really needed I suppose. We might as well remove it to prevent confusion.
It was set at 0.10 (10cm), which is the minimum also in the slider. I guess I need to keep it a bit bigger than that
I have uploaded a python notebook to github where you can play around with the settings and simulate the behaviour, if you want to test it
Thanks! I’m definitely gonna play with that to get the best values
One thing I’m searching on is a better way to handle the exceptions / conditions.
I have eg. a condition on room temperature - if the room temp > X, the automation can run.
Ofcourse, if then during the day the temperature drops, the automation will never run again and never open the blinds. Currently I’m using a max value of the room temp. but is there some more graceful way to handle this?
