I’ve hit a wall and maybe you can help @RobDYI. Can you check out MQTT Light/Templating Help . I’m not trying to auto-generate the lights (i may try to do that eventually but i just wanted to get things working) but I can’t seem to get transitions and brightness to work.
could anyone confirm what config entries theyve put on the slave and what on the master - I sort of get it working but then my master instance goes nuts and creates hundreds of entries for each slave entity and almost kills the machine, e.g.
‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’, ‘switch.kerui_k16_homearm_chime_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2_2’,
I think the problem might be that you have discovery on, on the master. (the HA that provides the sensors / switches to the slave) If you don’t want the master to populate any sensors / switches from mqtt config, then set discovery to false or set the discovery prefix to something different than the slave.
mqtt:
broker: 192.168.2.180
client_id: 1212
discovery: true
discovery_prefix: rpi3
Thanks for replying so quickly @RobDYI
Maybe I’m doing this back to front. I have sensors and switches on the slave that I want to be visible and able to be switched on/off from the master.
I don’t want the slave to see any entities that exist on the master.
I have no mqtt config on the master, as I’m using this broker https://www.home-assistant.io/addons/mosquitto/ and I’ve set the integration not to add new devices:
If you can tell me what I’m doing wrong it would be much appreciated! Cheers
On the slave,
mqtt:
client_id: 1212
mqtt_statestream:
base_topic: rpi1
publish_attributes: true
publish_timestamps: true
include:
domains:
- binary_sensor
- sensor
- switch
- light
all the automations above to create configs and control the entities
on the master
mqtt:
client_id: 1212
discovery: true
discovery_prefix: rpi1
you can go to the configuration menu on the front end to delete all the entities that are repeated or erase your storage folder if you can to start fresh.
thanks for the info!
Do i need a broker running on the slave as well as the master?
No, in fact they need to be log into the same one broker. That broker can be on either the slave or master.
I also found it didn’t add all the entities at restart.
If you send to MQTT payloads with the retain flag set then then the entities won’t disappear on restart ![]()
To save processing power, I shut off the automated config creator once I have all the devices setup. It hasn’t been on for months.
Can you share the latest version of this automation? Do you also have it shared on Github? Because I’m not sure if I use pieces of it or complete.
For me trying to use a switch function on the master doesn’t work. It is loading correctly the values from slave to master.
And do you have the brightness function now also included?
Have you looked at this project?
Is there no way in which the MQTT discovery messages are automatically generated ? I want to deploy a ‘remote’ zwave network on a rpi. All entities can be published to the master HA, and should be controllable. I’d hate to modify the config everytime I add a new device
What kind of information does your zwave device reveal about itself?
For example, assume I just added a new device. It reports nothing about itself other than its name and current state. Guess what I added.
That’s the challenge of what you are proposing: to publish a discovery payload, containing information about the device, to a specific discovery topic for a device that reveals next to nothing about itself.
On the other hand, if the device reveals a great deal about itself, then that data can be used to generate discovery information. The challenge then becomes detecting new devices, selecting appropriate data and reformatting it for use with Home Assistant’s MQTT Discovery.
Well if it is a switch, than it is quite trivial? Light is indeed more difficiult
How would you tell the difference if all it reports about itself is ‘xyz987’ is ‘on’?
That’s why I asked how much information does the device reveal about itself. The more the better.
For those interested, I’ve created a blueprint equivalent: MQTT State Stream to MQTT Discovery
Hi all,
I want to turn on my Hall lights when the door opens after sunset.
and when the door is closed again to turn off the lights after 3 minutes.
The automation won’t allow me the for: " 00:03:00" statement.
What am i doing wrong?
- alias: Turn on hall light when door opens
platform: mqtt
topic: shellies/shellydw2-front/sensor/state
payload: "open"
condition:
condition: state
entity_id: sun.sun
state: below_horizon
service: light.turn_on
entity_id: light.hal
- alias: Turn off Hall light after 3 minutes
platform: mqtt
payload: "close"
for: "00:03:00"
service: light.turn_off
Cheers,
Olav
Hi
I want to change preset_mode. but my code is not working
- id: '1002'
initial_state: 'on'
alias: mqtt_command_fan_speed
- platform: mqtt
topic: 'homeassistant/fan/#/speed'
condition:
condition: template
value_template: "{{ trigger.topic.split('/')[4] == 'set' }}"
- service: fan.set_preset_mode
data_template:
entity_id: "{{ trigger.topic.split('/')[1] }}.{{ trigger.topic.split('/')[2] }}"
preset_mode: >
{{trigger.payload }}
what should i do
thx
