Automation and Script Debugging?
@petro I’ve noticed another little problem with the automation.
Whenever I press any of the Opple switch buttons, the following error appears in the logs:
2021-12-02 14:50:33 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: homeassistant.helpers.template.Wrapper object has no element -2 when rendering '{{ items[-2] }}'
Could this be happening when the action playload is empty?
yep, change the event variable to
      event: >
        {{ trigger.payload_json.action or 'button_0_invalid' }}
That fixed it - thank you again!
Thanks for editing your post with the fix - could you add the right arrow ‘>’ next to the button variable too please?
Github issue for the ‘show trace’ link bug for reference.
And if going back to see another original problem in the message, only storing 5 traces, you can store as many traces as you would like now. Here is the Docs on the subject:
