My automations that use input_datetime helpers don’t work correctly, but they do work if the times are hardcoded. Why do they behave differently?
Simple example.
Test 1 uses input_datetime.test_on = 20:15 and input_datetime.test_off = 21:30 entered via lovelace.
This automation never turns off the switch.
- id: '1111111'
alias: Test 1
description: Automation using timedate helpers
- platform: time
at: input_datetime.test_on
- platform: time
at: input_datetime.test_off
- platform: homeassistant
event: start
condition: []
- choose:
- conditions:
- condition: time
after: input_datetime.test_on
before: input_datetime.test_off
- type: turn_on
device_id: 90c6870ff45ef852a4dd0d28207a858c
entity_id: switch.zbplug0
domain: switch
default:
- type: turn_off
domain: switch
mode: restart
Test 2 below is the same as Test 1 but without the helpers, the same times are hard coded instead. This works fine.
- id: '22222'
alias: Test 2
description: Automation using hardcoded times
- platform: time
at: '20:15'
- platform: time
at: '21:30'
event: start
condition: []
- choose:
- conditions:
- condition: time
after: '20:15'
before: '21:30'
- type: turn_on
domain: switch
default:
- type: turn_off
domain: switch
mode: restart
I can’t allow users to edit automation code, so I need to understand what’s wrong with the input_datetime approach.
