- service: script.auto_an_szenen ## or whatever your script is named now
name: konzentrieren ## scene nick name == name of the scene in the Hue-App
You can also change the default settings directly in the script by changing the following passage:
szene: |-
## placeholder because we want to assign 2 values to each other:
## a certain Hue scene to a certain light
{%- set x = namespace(szenen=[]) %}
## loop: does the assignment for us
{%- for
#—> given variable for the result of the following code block
hue
#—> only evaluate domain light
in states.light
#—> only select existing hue groups == "Zimmer" in the Hue-App
|selectattr('attributes.is_hue_group', 'defined')
#—> only take lamps into account which are on
|selectattr('state', 'eq', 'on')
#—> pick up the object_id to use it later as variable 'hue'
# == everything behind the first dot of an entity id
# e.g. light.garden = entity_id, garden = object_id
|map(attribute='object_id')
#—> ignore everything defined in the above variable "ignore"
|reject('in', ignore)
#—> display the result as a list
|list %}
{%- set x.szenen =
#—> put it all together to build the entity_id of the target scene
# slugify ensures that the "normal" name of the Hue scene
# used in the variable "name" can be processed into its
# entity_id.
# Super very simply put, slugify converts a name into an entity_id
x.szenen + ['scene.' ~ hue ~ '_' ~ name|slugify]
|list %}
## end of loop
{%- endfor %}
## result
{{ x.szenen }}
No, because you wanted to control only those lamps which are already on.
I don’t think that you can use Hue scenes for a single light without before having it defined as zone, but I never tried.
