What does automation.robby_heinrich_ist_wach
do? You might as well post it’s config too.
alias: Robby - EG ist wach
description: ""
- platform: state
entity_id:
- group.heini_computerzimmer_rechner
to: home
- platform: state
entity_id:
- device_tracker.henry_pc
to: home
- platform: state
entity_id:
- person.heinrich_xyz
- platform: numeric_state
entity_id: sensor.edel_mi_11_lite_sleep_confidence
above: 50
for:
hours: 0
minutes: 15
seconds: 0
- platform: state
entity_id:
- person.edeltraud_xyz
entity_id: vacuum.valetudo_robby
attribute: battery_level
above: 70
condition:
- condition: or
conditions:
- condition: numeric_state
below: 50
- condition: state
entity_id: person.edeltraud_xyz
state: not_home
alias: Edel schläft nicht oder ist nicht da
- condition: or
conditions:
- condition: state
entity_id: group.heini_computerzimmer_rechner
state: home
- condition: state
entity_id: device_tracker.henry_pc
state: home
- condition: state
entity_id: person.heinrich_xyz
state: not_home
alias: Heinrich abwesend oder Rechner an
above: 50
- condition: or
conditions:
- condition: time
after: "09:30:00"
before: "22:00:00"
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- condition: and
conditions:
- condition: state
state: not_home
- condition: state
state: not_home
- if:
- condition: state
state: cleaning
then:
- wait_for_trigger:
- platform: state
entity_id:
- vacuum.valetudo_robby
continue_on_timeout: false
enabled: true
- service: vacuum.start
data: {}
device_id: 696e85cc0fdf721148e74444b71008d6
enabled: false
- service: mqtt.publish
topic: homeassistant/robby/MapSegmentationCapability/clean/set
payload: >-
{"segment_ids": [ "19", "21", "22"], "iterations": 1, "customOrder":
true}
qos: "1"
enabled: true
- wait_for_trigger:
- platform: state
entity_id:
enabled: true
- service: automation.trigger
skip_condition: true
entity_id: automation.robby_zuruck_basis_oder_ausleeren
- service: automation.turn_off
stop_actions: true
entity_id: automation.robby_heinrich_ist_wach
enabled: false
- service: script.robby_zuruck_basis_oder_ausleeren
data: {}
mode: single
BTW renamed it in automation.robby_eg_ist_wach
Looks like its working in this state:
alias: Robby - Zurück Basis oder ausleeren
description: ""
entity_id: sensor.valetudo_robby_current_statistics_area
above: 100000
- platform: state
entity_id:
to: docked
condition:
- condition: state
entity_id: automation.robby_eg_alle_weg
attribute: current
state: 0
- condition: state
entity_id: automation.robby_eg_ist_wach
attribute: current
state: 0
- condition: state
state: docked
above: 100000
stop_actions: true
entity_id:
- automation.robby_eg_alle_weg
enabled: false
- if:
above: 100000
then:
- if:
below: 50
then:
- service: vacuum.return_to_base
data: {}
- wait_for_trigger:
above: 49
- if:
- condition: or
conditions:
- condition: state
state: returning
- condition: state
state: cleaning
then:
- service: vacuum.stop
data: {}
enabled: true
topic: homeassistant/robby/GoToLocationCapability/go/set
payload: "{ \"coordinates\": { \"x\": 2097, \"y\": 3231 } }"
qos: "1"
- service: notify.matrix_haus_xyz
message: Robby ist fertig mit saugen, bitte Behälter ausleeren!
else:
data: {}
- service: automation.turn_on
data: {}
enabled: false
mode: single
I don’t know why but deactivating a automation in the script let’s crashing it…
