I see this in my log:
Script script.anti_thief_light already running.
I see this now, then i am using script.turn_off
AttributeError: 'NoneType' object has no attribute 'is_on'
you probably have the wrong spelling for the script in your turn off service.
- service: script.turn_off
entity_id:
- script.anti_thief_light
The scripts is
anti_thief_light:
sequence:
- delay:
seconds: 10
- service: switch.turn_on
My script runs now, but the script.turn_off does NOT stop the script then i am home again, if i then leave my house, the script does not run from start again, its in a delay that i put in my script, so its stuck until the delay is over, howto fix this?
Please post your code as it stands now. Youâre asking us to do a lot of guessing about what exactly you have.
EDIT: I mean please donât just post snippets. Post the entire automations, scripts, configuration, etc. thatâs related to this topic.
Hi
The script and automation is working.
The only issue i got is then the script is running, after 1 minute in the automation, the script will try to run, but it cannot, because its already running.
How can i minimize this?
Some solutions, but not good solution is to change the interval from 1 minute to x minutes, as long the scripts are running, but the bad thing about this, is that the script will first run after x minutes again.
As I said before, please post all the related code. We canât be expected to remember all your details, or guess at what you might have done.
I did some changes about this anti thief light automation.
Simple actually, i created a automation that turn the script on then below_horizon and turned it off then above_horizon, no time_pattern needed.
