Hi There,
I’m looking for a way to get a difference value between readings of a single specific sensor, just the last two readings.
Something like this
{{ (states.sensor.ensuite_humidity_sensor_humidity.state - states.sensor.ensuite_humidity_sensor_humidity.previous_state) }}
Looking to turn on a fan based on humidity change, but I really want to do it only if the jump between the two readings is greater than 5%. The trend sensor doesn’t fire when I want it as the humidity sensors seem to update pretty infrequently.
I wasn’t able to find an example for this type of thing.
